Malfunction Lamp - P0685
Old 02-10-2011, 07:45 AM
rxtwo83's Avatar
(TSX 2004 w/ nav)
My Malfunction indicator lamp came on. Took it to my mechanic (not dealer) and the code was P0685. He said to get an ECM relay from the dealer and he would fix it.
When I called Acura to order the part, they want me to come and have them check it out (& I'm sure they want me to use their expensive services instead.)
Is my mechanic right - that all I need is the ECM relay? I don't want to be taken advantage of by the dealer or my mechanic.
BTW, my navigation system has been restarting itself as i'm driving. Are the 2 issues related? Thanks!
Old 02-10-2011, 11:20 PM
in the 24th and a half...
DuckDodgers's Avatar
Hum...."P0685 - Engine Control Module (ECM)/Powertrain Control Module (PCM) Power Control Circuit Malfunction"
Diagonostic procedure clears the DTC and sees if it reoccurs. Intermittent DTC indicates a loose connection in IGP line connectors...if the DTC does reoccur, "intermittent failure, the system is OK at this time"...if it reoccurs "Update ECM/PCM if it does not have the latest software, or substitute a known-good ECM/PCM, then recheck. If the symptom/indication goes away with a known good ECM/PCM, replace the original ECM/PCM."
Note that the HDS is required for these actions, does this independent mechanic have a HDS?
There are actually 2 ECM relays, at about $35 each...and one ECM at about $540...
You can tell the dealer no, but the relays are yours and yours alone after you buy them (that's the usual electrical parts policy). If it's a relay, figure the diagnostic cost should about cover the repair...if it isn't, your independent can't save you any money if he doesn't have access to an HDS unit. Even then, it's not likely to be a massive cost savings. I like independent mechanics, but this screams dealer.
On the Navi, not sure. That is not a listed error, try entering diagnostic mode and checking things out:
If battery has not been disconnected (you are not at code or gps aquire screen);
Ignition switch on, press and hold "Menu", "Map/Guide", and "Cancel" buttons together for 5 seconds...it will go to diagnostic screen.
If the battery was disconnected and you are at either screen above; hold down "Menu" and "Zoom out" buttons, then at "Navi Link Screen" push joystick to get to "Functional Setup menu", the touch "Return" icon to get the menu.
It's a very useful trick!
Old 10-02-2011, 02:04 PM
Regional Coordinator (Texas)
nspec_ya4's Avatar
did you ever figure out exactly what the problem was?
Old 10-03-2011, 11:00 AM
rxtwo83's Avatar
I took it back to the dealer and it turns out that is was my battery. I got a battery from O'Reilly's and apparently it was bad. (Acura did the battery check and I wasn't getting the power I should have been). so fortunately it turned out to be a very inexpensive problem.
Old 07-13-2018, 04:24 PM
ese epik's Avatar
Just had the same issue. Battery.
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Eggs999bacon
09-24-2015 10:08 AM
09-21-2015 08:44 AM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Malfunction Lamp - P0685
