Headlight HID Prob. - Turns on, Flickers, Then Dies.
Old 01-27-2011, 03:15 PM
9th Gear
honda_nerd's Avatar
So I have a problem with my 04 TSX. I recently just replaced the HIDs on my low beams and everything went fine. When I tested the HIDs, the bulbs would turn on and be fine for like 10 seconds, then start to flicker (sometimes one would flicker first then the other or sometimes both start to flicker at the same time), and then would die in less than a minute. It happens to both sides and both would eventually die out. Does anyone know what could be wrong with the setup I have? I bought HID bulbs from hidextra.com. Any input would be appreciated. Thanks.
Old 01-27-2011, 04:47 PM
CGP Ebony
xenonhid's Avatar
What happens if you put in the OEM HID bulbs back? If the oem ones work fine, then you can deduce its the aftermarket hid bulbs as the issue.
Old 01-29-2011, 04:42 PM
9th Gear
honda_nerd's Avatar
My oem HIDs went out, that's the only reason I am getting another set. Any other ideas?
Old 01-29-2011, 07:07 PM
PaHonda's Avatar
Are the low and high headlight relays identical relays?
If they are identical, switch them. Then see if the low beam lights stay on and the high beams quit when turned on?
Old 02-05-2011, 12:48 PM
dreloc's Avatar
Some people replace their fuse with a higher amperage when they have this problem with HIDextra kits, i returned the ballasts under warranty and they sent me a new ones promptly. Good customer service but product quality may need improvement a bit
Old 02-10-2011, 12:17 PM
ziboy's Avatar
This problem can be caused by the relay, or the ballast. Changing the fuse won't have effect except if the fuse is burning. (by the way I don't recommand to change the fuse for a bigger one)
Did u buy the same voltage and wattage as oem ?
If your light flicks, it's because it doesn't have enough power to the light.
Old 02-12-2011, 06:50 PM
arahim32's Avatar
to me it sounds like the ballasts
Old 02-14-2011, 06:28 AM
cassinova73's Avatar
i am having the same problem.. OP did you fix your problem... mine only happens on the driver side.. i have 6000K and they worked great upon until recently. the passenger which has a 6000K doesnt give a problem so i dont believe its the bulb
Old 02-15-2011, 08:07 PM
Chris M's Avatar
New Ballaster and Ignitor
I just took my 04 TSX to the dealership for the fix on the high pressure power steering hose and had them also look at my HID Low Beams because i'm having pretty much the same issue. My passanger side light might come on might not, most of the time my driver side does come on, but if I turn the lights off for 10 sec and then back on, none of them work. After 90.00 to have them test to see if it's the bulbs, they gave me a quote 1,200.00 for two new ballaster's and ignitors, plus 200.00 per bulb, for a total of ~1,600. So when I got home I went to e-bay and found a seller with new ballasters and ignators for 198.00 each, so needless to say i'm going that route and from my readings it fairily easy to take the front bumper off and take out the headlights to get to the ballaster.
http://cgi.ebay.com/ebaymotors/ws/eB...m=250772589481
Old 03-09-2011, 11:52 AM
CometVR4's Avatar
That's your problem, I purchased bulbs from there too for my TL. Right away both bulbs started flickering when I switched them on. I quickly put in Morimoto from theretrofitsource.com before it killed my ballast and they worked perfect. I 100% positive it's the bulbs. I think they got a bad batch or something. There are several members on clublexus forums that are having same problem with OEM replacements as well.
Old 03-14-2011, 10:32 AM
dalco2208's Avatar
Just wondering what you did to fix this. My new HID's are doing the same thing.
Old 04-03-2011, 11:42 PM
BERTSX's Avatar
Hello, anybody remedy this problem. i purchased D2S 6000k bulbs from HIDExtra and i'm having the same issues with the bulbs flickering on both sides within a minute. I've emailed them many times and they keep referring me to there FAQ's on there website. I could understand if i bought a kit from them, but this is just a bulb replacement. I've reinstalled my OEM bulbs and no problems what so ever with flickering. Hopefully they replace my bulbs or refund my money.
Old 04-12-2011, 01:06 PM
PACman's Avatar
Any feedback on how these are? I'm in the same situation, but can't afford to get these parts from the dealer.
Old 05-06-2011, 08:29 AM
Chris M's Avatar
PACman, i've had these in my car for that past 4+ months and have had no problems.
Old 05-06-2011, 06:14 PM
PACman's Avatar
Old 05-22-2011, 12:35 PM
Quest227's Avatar
I had the same problem, diagnosed by Bosch Service Centre as poor OEM ground...stronger ground was created and she works fine now.....my RHS HID low beam was arcing with the high beam alongside trying to find a stronger earth.
Hope this helps someone
tman570
06-11-2019 07:56 AM
JnC
09-11-2015 06:06 AM
Phambam12
09-06-2015 06:57 PM
voigt
09-02-2015 10:44 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Headlight HID Prob. - Turns on, Flickers, Then Dies.
