DIY- Remove Top Console Cover (also Replace Cup-holder) - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine RDX Community > First Generation RDX (2007-2012) > DIY & FAQ
Old 01-02-2011, 1:26 AM   #1
737 Jock
haole kama'a-ina
737 Jock's Avatar
Points: 13,313, Level: 75
Points: 13,313, Level: 75 Points: 13,313, Level: 75 Points: 13,313, Level: 75
Activity: 0.6%
Perform Do-It-Yourself auto maintenance at your own risk. You can kill or injure someone or damage the car. Work or raise an auto only on a level, concrete floor. Do not go under any auto unless you are completely certain that it is secure. You and only you, are responsible for your work and safety.
Before removing the top console cover you must remove the shift knob and boot assembly. Go here first: DIY- Remove/Replace Shift Knob and Shift Indicator Light
Front and rear, left and right is ALWAYS related to the car itself, NOT how you are facing it:
LEFT is always the DRIVER side.
RIGHT is always the PASSENGER side.
Text relates to the picture below the text.
Tools and parts needed:
1. 10 mm wrench.
2. Plastic auto body prying tools (a few bucks at Harbor Freight). Plastic is less likely to damage or scratch anything.
3. Eye protection, face protection, gloves and protective clothes.
Plastic prying tools are about 15 cm long and look like this:
Warning; there is electrical wiring inside the console, including SRS Airbag wiring. Begin by disconnecting the negative battery cable:
With the shift knob and boot assembly previously removed, the console top cover can be removed. Begin by gently prying up the silver, left side console trim piece. Start at the rear and work forward. As it comes loose, rotate the rear upward and pull the front clips straight out to the rear:
Do the same on the right side, silver console trim piece:
Here is the silver trim removed, showing how the clips go into the console:
Open the console lid for clearance. Starting at the left side, gently pry to release the console top cover clips. Note the clip at the rear under the lid:
Do the same on the right side. Again, note the clip at the rear, under the lid:
The top cover is fairly tight against the lower front panel (seat heat and power outlet). Gently work it loose and lift it off:
If you need to replace the cup-holder, it simply unscrews from the bottom of the top cover:
Installation is the reverse of removal.
If you are accessing the console light wire, continue.
Go to "DIY- Replace Console Light, and Fix Short Console Light Wire"
737 Jock is offline   Reply With Quote
The Following User Says Thank You to 737 Jock For This Useful Post:
dr427 (02-09-2013)
Old 01-02-2011, 3:14 AM   #2
737 Jock
haole kama'a-ina
737 Jock's Avatar
Activity: 0.6%
Link: DIY- Replace Console Light and Fix Short Console Light Wire
Old 01-14-2013, 9:14 PM   #3
SinCity
Points: 6,038, Level: 50
Points: 6,038, Level: 50 Points: 6,038, Level: 50 Points: 6,038, Level: 50
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
'86 190e (AMG exterior resto), '08 RDX, '09 C63 AMG w/ Kleemann K1 tune, K2 exhaust manifolds w/200 cell cats, and 19" staggered Kleemann MS11s. "ROW" AMG airbox tops, SMERC upper tie bar, and MBH X-pipe.
SinCity is offline   Reply With Quote
Old 05-28-2013, 11:21 AM   #4
genesis211
New Member
Points: 272, Level: 5
Points: 272, Level: 5 Points: 272, Level: 5 Points: 272, Level: 5
Can anyone tell me how to remove the leather for replacement from the 2008 RDX console lid., The three screws don't do it.
genesis211 is offline   Reply With Quote
Old 07-05-2013, 10:50 AM   #5
SinCity
Activity: 1.7%
+1
Old 06-09-2014, 1:59 AM   #6
matttrue
2007 Acura RDX
matttrue's Avatar
Matt True
Points: 2,815, Level: 32
Points: 2,815, Level: 32 Points: 2,815, Level: 32 Points: 2,815, Level: 32
Did you ever find an answer to this? I need to replace mine.
2007 Acura RDX AWD Tech Package with Iphone intigration.
matttrue is offline   Reply With Quote
Old 06-09-2014, 9:49 AM   #7
737 Jock
haole kama'a-ina
737 Jock's Avatar
Activity: 0.6%
Console Armrest Cover Tearing/Delamination
What happens in space-time, stays in space-time.
2007, acura, console, cover, cup, cupholder, holder, holders, lid, mdx, remove, removing, replace, rl, rsx
