Windshield washer fluid - AcuraZine Community
Old 12-27-2010, 5:28 PM   #1
pyckuu23
Question Windshield washer fluid
my windshield washer fluid stopped working, wipers go on, but no fluid comes out. Do you think this is a pump problem? Suggestions to what i should look for?
Any help is greatly appreciated.
Thank you!
pyckuu23 is offline   Reply With Quote
Old 12-27-2010, 5:32 PM   #2
Noober
Noober's Avatar
Trader Rating: (5)
Nooberr
Points: 5,055, Level: 45
Points: 5,055, Level: 45 Points: 5,055, Level: 45 Points: 5,055, Level: 45
Activity: 7.0%
Activity: 7.0% Activity: 7.0% Activity: 7.0%
fill it up.
2007 Acura TL-S || Comptech Supercharger || TE37SL|| AEM|| BC Racing|| Skunk2/Ingalls||RV6 JPipe/PCD/TD Exhaust||VIS||ARC/SARONA||HONDATA||
Noober is offline   Reply With Quote
Old 12-27-2010, 5:42 PM   #3
apnorm
apnorm's Avatar
Trader Rating: (3)
Points: 8,125, Level: 60
Points: 8,125, Level: 60 Points: 8,125, Level: 60 Points: 8,125, Level: 60
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
you should be able to hear the pump going...if not, check your fuse first and hope it's a quick fix.
If the pump is working and you have fluid in your reservoir, it could be that there's some ice blocking the sprayer.
apnorm is offline   Reply With Quote
Old 12-27-2010, 5:42 PM   #4
pyckuu23
forgot to mention it is water is filled up
Old 12-27-2010, 5:44 PM   #5
pyckuu23
@apnorm good call i will check the fuse. I don't recall hearing the pump going ... I will let you know tomorrow. thx
Old 12-27-2010, 6:00 PM   #6
nfnsquared
nfnsquared's Avatar
Points: 14,353, Level: 77
Points: 14,353, Level: 77 Points: 14,353, Level: 77 Points: 14,353, Level: 77
Activity: 28.9%
Activity: 28.9% Activity: 28.9% Activity: 28.9%
Is the green light in your mirror out? If so, it's the fuse...#20. Replace with 10A.
04 6MT, Navi, WDP, chrome wheels, Clifford Matrix 50.7X RS/Alarm, Huper Optik ceramic tints
nfnsquared is offline   Reply With Quote
Old 12-27-2010, 6:04 PM   #7
TKO1
Points: 3,185, Level: 34
Points: 3,185, Level: 34 Points: 3,185, Level: 34 Points: 3,185, Level: 34
Water? That might be your problem if you live someplace cold.
TKO1 is offline   Reply With Quote
Old 12-27-2010, 6:55 PM   #8
pyckuu23
TKO1 - sorry its windshield washer fluid rated for -20F
Old 12-27-2010, 6:56 PM   #9
pyckuu23
nfnsquared - i will check it out thanks for the info
Old 12-29-2010, 10:29 AM   #10
pyckuu23
thanks for your help guys, it was fuse #20 (7.5 amp)
Old 12-29-2010, 10:35 AM   #11
nfnsquared
nfnsquared's Avatar
Activity: 28.9%
You bet...Replace it with a 10A fuse...
And keep a spare fuse or two handy in case it happens again. The fluid froze in the lines for some reason and the pump over amps the circuit when it can't pump fluid...
Old 12-29-2010, 8:57 PM   #12
04WDPSeDaN
Elladas- S/C 6MT TL
2004 Acura TL
04WDPSeDaN's Avatar
Trader Rating: (1)
Points: 20,169, Level: 89
Points: 20,169, Level: 89 Points: 20,169, Level: 89 Points: 20,169, Level: 89
Activity: 12.6%
Activity: 12.6% Activity: 12.6% Activity: 12.6%
If you put water in there AND IT'S WINTER outside... that's the wrong move.
Water freezes.. Washer fluid doesn't
Water freezes and jams up the washer motor.
Which blows the fuse...
Put good known washer fluid in, check fuse and proceed to see if washer works. If not and the fuse is good, then remove your bumper and replace the washer located on the right front under the head head assembly.
[]C0mptech Exhaust[]AEM CAI[]Tein SS[]TL-S Tails markers & Mirrors[]Decklid Lip[]Black'd 0ut, ZWK projectors,Sm0ked ambers Headlights[]UR Pulley[]thermo gaskets TB spacer[]Optium Red top[]Black R0of []5% tint windows][LED Lic/Int lights[]19" Stagger'd GoldVS-XX[]Comptech Swaybar[]Rotora Combination rotors[][Shaved key-hole[]Rear RDX brake covers[]6MT/NAVI/A-spec[]Type-S Front end[]A-spec Rims[]Interior C/F pieces[]DeBadged[]ATLP J-pipe
04WDPSeDaN is offline   Reply With Quote
Old 12-29-2010, 9:48 PM   #13
nfnsquared
nfnsquared's Avatar
Activity: 28.9%
^^^post #8
Old 03-30-2011, 11:29 AM   #14
tj19855
2007 TL
tj19855's Avatar
Points: 4,245, Level: 41
Points: 4,245, Level: 41 Points: 4,245, Level: 41 Points: 4,245, Level: 41
Activity: 2.6%
Activity: 2.6% Activity: 2.6% Activity: 2.6%
Wiper fluid not working all of the sudden
Mine stopped working yesterday, I can hear the pump and wipers come on but no fluid comes out, I filled it up today and still nothing.
2007 Acura TL, 5% Tint all around, Lip spoiler, K&N Air Filter, Kumho Ecsta AST, Front signal LEDs Switch backs, Rear LED turn signals, Super White Reverse & license plate LEDs, Acura window visors. WINDSHIELD REPAIR & HEADLIGHT RESTORATION CERTIFIED TECH.
tj19855 is offline   Reply With Quote
Old 03-30-2011, 12:41 PM   #15
VQPower37
VQPower37's Avatar
Points: 11,113, Level: 69
Points: 11,113, Level: 69 Points: 11,113, Level: 69 Points: 11,113, Level: 69
Activity: 3.3%
Activity: 3.3% Activity: 3.3% Activity: 3.3%
is there a large piece of ice at the bottom of ur reservoir? that could be the problem ... even if u filled it, none of that fluid will be able to get to the pump that it needs to get to in order to be sprayed on ur windshield
2007 CBP TL Type S|18x8 Gunmetal A Spec Wheels|245/40/18 Continental ExtremeContact DWS|R1 Concepts Eline Cross-Drilled & Slotted Rotors|Duralast Gold Cmax Brake Pads|Stage 3 Exhaust - Magnaflow Mid-Muffler|Michelin Stealth Wiper Blades|Rockblocker Headlight and Foglight Protection|15% Solar Gard Window Tint|UA7 SQUAD MEMBER #28|19UUA76587A008153
2012 BRP SHAWD TL Tech
VQPower37 is offline   Reply With Quote
Old 04-01-2011, 2:06 PM   #16
tj19855
2007 TL
tj19855's Avatar
Activity: 2.6%
No weather here is 80F, I figured out what the problem was, on the 3rd gen TLs if you take all the plastic covers off the engine on the passenger side, the windshield wiper fluid rubber tube runs near the wiper fluid reservoir up to the windshield next to the fender. The tube was detached so I just put it back on. Now it works again
2004, acura, failure, fliud, fluid, frozen, pump, ratings, tl, tsx, washer, windshield, winshield, wiper, work
