Need tire size and speed rating advice for 05 TL
Old 12-06-2010, 05:05 PM
9th Gear
cg54249's Avatar
Unhappy Need tire size and speed rating advice for 05 TL
I have a 2005 acura TL and was looking to get new tires and realized that v-rated tires are alot more expensive and have a lower tread warranty than what h-rated tires have. That being said I've done some research and people seem to indicate unless you drive your car like your on a race track h-rated are just fine. So I've been researching H-Rated tires and have had trouble finding them in the size needed (235/45/17). I also did research and people mentioned you can deviate from the suggested size but I'm not really sure by how much. If anyone could clue me in what sizes I could put on my TL and if it really is ok to go with H-Rated tires it would be GREATLY appreciated as I clearly know nothing. Also, if anyone could suggest a good tire for under $100/per that has 50k+ tread warranty that would be helpful as well as I plan on getting these in the next week or so!
Old 12-06-2010, 05:20 PM
nfnsquared's Avatar
It ain't gonna happen for under $100...And I'd start by saying I don't recommend you downgrade to an "H" tire.
Where do you live? Do you need an all season tire? Go to tirerack.com and do a tire search by OEM size (235/45/17). There are a few under $100, but none with a 50K warranty. For a little over $100, you can get a quality tire with meets OEM specs....
Old 12-06-2010, 06:40 PM
9th Gear
cg54249's Avatar
I live in Charlotte, NC so I'm not concerned about snow. Nice weather except for the occasional heavy rains. Why do you say you wouldn't recommend going down to H-Rating? Is it something to do with handling or how they work with the car?
Old 12-06-2010, 09:37 PM
Turbonut's Avatar
H is fine if you're not going to be cruising over 130 MPH. Michelin Exalto H rated, a great tire, but they aren't available for under $100. The load rating of 94 is higher than the OE 93, just not the speed rating.
Just do some reasearch on the various brands.
GhostTL09
09-19-2015 01:57 PM
PortlandRL
09-14-2015 12:01 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Need tire size and speed rating advice for 05 TL
