03 cl-s seat wiring diagram?
Old 12-05-2010, 07:24 AM
low97accord's Avatar
hey everybody. names Phil. i drive an accrord coupe (we are like sisters! lol) and im tryign to wire these seats into my car. got everything bolted up all secure i just dont know how to wire them up...does anybody have this? ive been searching all over for one with no luck.
Old 12-05-2010, 10:24 AM
Regional Coordinator (Texas)
nspec_ya4's Avatar
i'll see if i can scan it and post it up for u. give me some time
Old 12-05-2010, 11:06 AM
nspec_ya4's Avatar
I looked through what i had on the computer this is the only thing i could find on the power seat wiring.
Old 12-05-2010, 10:44 PM
thanks. ill save it and give it a look. i figured out the pass seat pretty easy. the driver seat is a diff story, especially since the plug was cut sighhhh... luckly i was able to jump the harness and atleast set the chair to a comfortable position lol
Old 12-07-2010, 06:22 PM
nspec_ya4's Avatar
even better info. I was looking at the service manual
Grn/Yel and Grn = front motor up/down
Blu/Yel and Blu = slide motor
Red/Yel and Red = Rear motor up/down
Yel/Grn and Yel = Recline Motor
On the diagram, it looks like ur really just need to power the Blue and Red wires and ground the black ones on the connector. I think the seat belt sensor wires should be the same.
Passenger Side
Blu/Yel and Blu = Slide motor
You will probably need to setup some relays to make the motors work with the factory switch if you are not using the factory power seat control unit on the passenger side.
*** got this info off of a 01 setup but it should be pretty much the same.
Old 12-08-2010, 12:49 PM
thanks ill give it at look today and see if that works. i appreciate it a lot man
Old 12-10-2010, 01:07 PM
chtrcy's Avatar
Nspec...You da man!
Old 12-10-2010, 11:33 PM
nspec_ya4's Avatar
no problem. Charles, i thought urs was an 01?
MrHeeltoe
20
02-23-2023 01:54 PM
Pham Alvan
05-18-2021 06:48 AM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: 03 cl-s seat wiring diagram?
