Garmin Mount?
Old Sep 8, 2010 | 09:44 PM
TLingham's Avatar
Garmin Mount?
I have a base '07 TL and a Garmin with a suction cup mount. I'm looking for a place to mount it other than the windshield. The best place I've found is about where the factory nav would be, in the center of the consol. The problem of course is that the suction cup is stuck to the dash display where the ac temp and compass are located. I'm worried mounting to this area wil crack the display. Any suggestions?
Old Sep 8, 2010 | 10:24 PM
AMUA6's Avatar
ScoobyZINE
I lay mine in front of the gear shifter.. Although it tends to slide around a little bit and could possibly get in the way if you're 6MT. Fab up a mount to use one of the compartments in front of the gear shifter?
Old Sep 8, 2010 | 11:38 PM
TLingham's Avatar
Thanks AMUA6. That's about the only place I've found and the power supply is right there which keeps the wire from getting in the way of other things.
I just tried the flat area in front and to the sides of the clock. It's a great location for the Garmin but the suction cup only holds for a few seconds. I don't want to drill anything into my dash.
Old Sep 9, 2010 | 01:26 AM
RBeachTL's Avatar
Check this out:
http://www.amazon.com/Arkon-GN047-Re...cmu_pg__header
I use this when I'm renting.
Old Sep 9, 2010 | 09:51 AM
jda123's Avatar
Dogmatic Dinosaur
I stuck the suction cup plate onto the flat shelf just below the clock on my 06 base - the unit will not suction onto the shelf since it is not smooth enough. It is to the right of the clock. The wires run up the left side. It is a decent spot.
Old Sep 9, 2010 | 05:23 PM
ScorpioNAtl's Avatar
Originally Posted by RBeachTL
Check this out:
I have this setup and it works nicely.
Old Sep 9, 2010 | 08:27 PM
TLingham's Avatar
Thanks for this suggestion. I found the suction cup plate (aka dashboard disc.) I may give that a try.
Old Sep 9, 2010 | 08:35 PM
TLingham's Avatar
Thanks to both of you. Another good suggestion.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Froid
Sep 27, 2015 06:16 PM
