External transmission filter source
Old 07-26-2010, 07:52 AM
totaledTL's Avatar
Came across an aftermarket filter source for less if anybody needs one. Typed 25450-P7W-003 in Amazon to see what happened:
http://www.amazon.com/Transtar-Indus...0145941&sr=8-1
Anybody ever used one of these?
New inline cooler return filters for various Honda and Acura applications. Axiom # A30013(Ref. # 25450-P7W-003)Acura 3.2TL 2000-03 (M7WA, B7WA)
Old 07-26-2010, 12:26 PM
acutee's Avatar
Thanks for sharing. Good to know there is an alternative option.
Old 07-26-2010, 05:51 PM
kgovett's Avatar
Is this filter mounted on the driver side of the trans in a canaster?
If not were is the best location to add ann external filter?
Thanks, Kevin
Old 07-27-2010, 09:04 AM
acutee's Avatar
This external atf oil filter is for 00+, it is next to the oiljet where the aft stick is, on the driver's side.
very easy to replace with a 10mm, I think, offset tool, and an adjustable wrench.
Thanks, Kevin
Old 07-27-2010, 10:18 AM
2003 TL
webmastir's Avatar
ya know..this got me thinking.
after i got my tranny rebuilt by the wrong type of person last year, i never thought to think if my external oiljet kit, which was installed during recall period, was still/left on there
is this something that can easily be seen w/o taking anything out /and/or dropping tranny to check?
Old 07-27-2010, 11:22 AM
JDM Inspired's Avatar
We need Kris in here!
Old 07-27-2010, 12:35 PM
acutee's Avatar
External oiljet kit and external aft oil filter are two different things. If your tranny was rebuilt by a private shop, chances are they replaced the internal parts and re-used the casing with the external oiljet kit intact. Acura most likely to repace the whole casing with an internal oiljet. you should be able to see the external oiljet kit by looking down where the air intake is, in front of the brake fluid.
This one is oiljet
https://acurazine.com/forums/2g-tl-1999-2003-98/what-hose-atf-785249/
Old 07-27-2010, 12:53 PM
2003 TL
webmastir's Avatar
read this thread wrong, thx
LeVeL
10-18-2015 04:19 PM
lanechanger
10-13-2015 10:56 AM
joflewbyu2
10-08-2015 11:16 AM
flyromeo3
09-24-2015 11:24 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: External transmission filter source
