Loud rear tire noise humming? - AcuraZine Community
Old 06-19-2010, 12:00 AM   #1
davewhodavedunn
2006 Acura TL
davewhodavedunn's Avatar
Points: 11,556, Level: 70
Points: 11,556, Level: 70 Points: 11,556, Level: 70 Points: 11,556, Level: 70
I have a 06 TL. I recently put 19inch wheels on it, and 3 months later I am noticing a weird hum from the rear tire area, it almost sounds like I am running on a REAR flat tire, but my tire pressure is fine.
It vibrates the floors lightly in the car as well. This happends 60 percent of the time I am driving the car, but not all the time, what could this be? I have searched everywhere!
REPRESENTIN CANADA!
davewhodavedunn is offline   Reply With Quote
Old 06-19-2010, 6:37 AM   #2
Turbonut
Trader Rating: (1)
Points: 13,292, Level: 75
Points: 13,292, Level: 75 Points: 13,292, Level: 75 Points: 13,292, Level: 75
Activity: 17.5%
Activity: 17.5% Activity: 17.5% Activity: 17.5%
If they are the same size, switch the rears to the front and give it a try. Naturally, if the noise is now at the front, tire/wheel problem, balance, bent/cracked wheel, bad tire. When switching the tires, check for irregular tread wear, uneven tread side to side, or feathered edge. If still at the rear, mechanical problem with the car.
Turbonut is offline   Reply With Quote
Old 06-19-2010, 8:49 AM   #3
davewhodavedunn
2006 Acura TL
but the problem is 100 percent of the time? does it sound like a possible wheel bearing?
REPRESENTIN CANADA!
Old 06-19-2010, 10:10 AM   #4
Turbonut
Trader Rating: (1)
Activity: 17.5%
Could be the tires! Many years ago, I had tires (Falken) that sounded like a rear wheel bearing was going, but it was just the tires. The sound would even change with the dips in the road, but it was just the tires. I found out the hard way as I changed the wheel bearing and had the same noise. Installed another set of tires and it was gone completely. I wasn't too happy.
Old 06-19-2010, 10:34 AM   #5
nfnsquared
nfnsquared's Avatar
Points: 14,327, Level: 77
Points: 14,327, Level: 77 Points: 14,327, Level: 77 Points: 14,327, Level: 77
Activity: 28.1%
Activity: 28.1% Activity: 28.1% Activity: 28.1%
When was the last time you had your alignment checked? Does it come from one side in particular? It could be one of your rear tires starting to cup due to misalignment. I had that happen (left rear). I too thought maybe a bearing was going bad, but my rear toe was out and it caused the left rear tire to cup. Take a real good look at your rear tire wear on both side. If you have uneven wear on one or both tires, you have an alignment issue.
04 6MT, Navi, WDP, chrome wheels, Clifford Matrix 50.7X RS/Alarm, Huper Optik ceramic tints
nfnsquared is offline   Reply With Quote
Old 06-19-2010, 8:10 PM   #6
davewhodavedunn
2006 Acura TL
I doubt it could be the tires as they never made this noise when i put on the new tires and rims. It started out rarley happening then getting worse.
If i go over 50 kilometers (canadian) the noise will start and get louder, as i go slower it gets quieter. Ugh its driving me nuts.
REPRESENTIN CANADA!
Old 06-19-2010, 8:35 PM   #7
Turbonut
Trader Rating: (1)
Activity: 17.5%
Ever hear of tires making noise after they wear, guess not, so forget about the tires.
Old 06-19-2010, 9:54 PM   #8
nfnsquared
nfnsquared's Avatar
Activity: 28.1%
I seriously doubt it's a wheel bearing. They very rarely go bad on TLs. On the other hand, TLs are somewhat notorious for causing uneven wear on the rear tires when only slightly out of alignment.
You didn't answer my questions: When did you last have the alignment checked (in miles) and are both tires wearing evenly?
Old 06-19-2010, 11:05 PM   #9
davewhodavedunn
2006 Acura TL
I have never had alignment on the car since i bought with 94,000kms i now have 110,000kms on it. Usually i thought u didnt have to have an alignment unless you did suspension work. Also that doesnt explain why when i put the wheels on they didnt make this noise and now they do and it seems to be getting worse.
I will check the tire wear tomorow and let you know.
REPRESENTIN CANADA!
Old 06-19-2010, 11:53 PM   #10
davewhodavedunn
2006 Acura TL
Also I realized tonight from the passenger rear tire their is excessive heat and a weird smell. Their is also a wear rubbing noise from the rotor/pad area when braking and going 0-5 km...I trying hard to figure this out as it is driving me nutz!
REPRESENTIN CANADA!
Old 06-20-2010, 10:43 PM   #11
davewhodavedunn
2006 Acura TL
i know this is a tough one guys, but ineed your help!
REPRESENTIN CANADA!
Old 06-20-2010, 10:51 PM   #12
nfnsquared
nfnsquared's Avatar
Activity: 28.1%
Have you confirmed no uneven wear on your tires?
It's possible one of your p-brake shoes is rubbing. Could have a broken a release spring.
Old 06-21-2010, 7:05 AM   #13
LandonZ
LandonZ's Avatar
Trader Rating: (1)
Points: 2,989, Level: 33
Points: 2,989, Level: 33 Points: 2,989, Level: 33 Points: 2,989, Level: 33
Activity: 0.3%
check the inside of the tread, check for waving patterns. You can even rub your hand along it. Its either and bearing or Cupping on the tires. Both of those get louder as you drive. Lack of Rotation and Alignment are the reasons for this! take a picture of the inside of your tread for me
LandonZ is offline   Reply With Quote
Old 06-21-2010, 1:46 PM   #14
davewhodavedunn
2006 Acura TL
landonZ pm me, and send me your email address I will send pics, anyone else who wants pics pm me as well..the tires seems to wear evenly so I cant tell, maybe u can by pics...
REPRESENTIN CANADA!
Old 06-21-2010, 2:02 PM   #15
JMillerUA6
Chapter Leader (New England)
1998 BMW M3
JMillerUA6's Avatar
Trader Rating: (1)
jbmiller616 JMillerUA6
Points: 7,887, Level: 59
Points: 7,887, Level: 59 Points: 7,887, Level: 59 Points: 7,887, Level: 59
Activity: 0.4%
I had the same problem.....ended up being a shifted belt that caused a large bubble on my tire.
JMillerUA6 is offline   Reply With Quote
Old 06-21-2010, 2:47 PM   #16
davewhodavedunn
2006 Acura TL
where was this bubble? a shifted belt? what did you have to do to fix it?
REPRESENTIN CANADA!
Old 06-21-2010, 2:55 PM   #17
davewhodavedunn
2006 Acura TL
below is a pic of both tires side by side, and then both tires from a further distance...they look fine to me? let me know what you think
REPRESENTIN CANADA!
Old 06-21-2010, 10:38 PM   #18
I hate cars
Points: 36,290, Level: 100
Points: 36,290, Level: 100 Points: 36,290, Level: 100 Points: 36,290, Level: 100
Activity: 30.7%
Activity: 30.7% Activity: 30.7% Activity: 30.7%
Tires look good. Next time it's humming, pull the parking brake slightly and see if it makes a difference either way.
'06 TL Dynaudio182/430/110 2x ID Max15s 2x JL HD600/4, HD750/1, PS8..255/40 NT05s..H&R FSB..Progress RSB..A-spec+Konis..Stoptech 13" BBK..Redline 5w-30..Redline ATF PSF '84 GN602rwhp 620lbs tq 3,000lbs.Awaiting the heart transplant..4.5L 2,300hp in 2015.
'14 Giant Trance SX
I hate cars is offline   Reply With Quote
Old 06-21-2010, 11:43 PM   #19
davewhodavedunn
2006 Acura TL
I will do that and report back to you guys...any other ideas of what it could be? I think we have narrowed it down to wheel bearing and p-brake shoes is rubbing or a broken a release spring
REPRESENTIN CANADA!
Old 06-22-2010, 7:17 AM   #20
Ramrodthrusterpuppy
2008 Acura TL Type-S
My Garage
Ramrodthrusterpuppy's Avatar
Points: 6,728, Level: 53
Points: 6,728, Level: 53 Points: 6,728, Level: 53 Points: 6,728, Level: 53
Sticky rear caliper/e-brake cable. Sounds like the pads are dragging & heating up and burning....get it looked at ASAP.
2010 Raptor SVT 6.2L
Ramrodthrusterpuppy is offline   Reply With Quote
Old 06-22-2010, 10:38 AM   #21
nfnsquared
nfnsquared's Avatar
Activity: 28.1%
From that angle, the tires look good. However, you need to check the full circumference of the tires for uneven wear, not just what is viewable from that angle to be sure. When my alignment started to cup my left rear tire, I had the noise but didn't detect any issue with tire wear. Two weeks and 500 miles later, my tire was severely cupped. If this noise just started, it could still be an alignment issue causing tire noise due to unusual geometry/force placed on the tire/tires from an out of spec alignment. It just hasn't had time to show up as wear yet.
You may still very well have a p-brake issue instead of a tire/alignment issue. Do what IHC suggests and see what happens. You can also jack up the rear end and spin the right rear tire and see what you hear. If both of those procedures point toward a p-brake issue and you're somewhat mechanically inclined, you can pull the rear rotor to check the p-brake mechanism. There are a couple of good DIYs in the 3G Garage with pics and service manual scans. If it's as simple as a broken release spring, you'll be out about $2, assuming the shoes are not severely worn.
Old 06-22-2010, 11:18 AM   #22
TLer trash
Points: 7,531, Level: 57
Points: 7,531, Level: 57 Points: 7,531, Level: 57 Points: 7,531, Level: 57
Activity: 3.5%
Activity: 3.5% Activity: 3.5% Activity: 3.5%
x2
TLer trash is offline   Reply With Quote
Old 06-22-2010, 4:12 PM   #23
LandonZ
LandonZ's Avatar
Trader Rating: (1)
Activity: 0.3%
i cant PM yet, take another pic along the top of the tire showing the inner part from the side, do you understand what that means? HAHA. Not sure how to explain it. Tires looks good from that angle
2007 TL Type S- MRP
Old 06-22-2010, 5:00 PM   #24
davewhodavedunn
2006 Acura TL
So i jacked up the car and spun the wheel, it spun freely then i pushed the brakes and spun he wheel again and the wheel was very hard to try and spin. I took apart the caliper lube lubed it up put the wheels on and same thing. I ended up buying a new caliper as the other one was seized and it seemed to fix the problem.
REPRESENTIN CANADA!
Old 06-26-2010, 8:20 AM   #25
LandonZ
LandonZ's Avatar
Trader Rating: (1)
Activity: 0.3%
With the tire jacked into the air. spin it and watch the inner part of the tire, see if it seems to be moving up and down. Cupping is explained as each tread is a different height. One is higher then the next on and so on. That can make hella noise while driving. This can also happen on the outside of the tire if the alignment is not perfect and the tires are not rotated.
2007 TL Type S- MRP
Old 06-27-2010, 10:36 PM   #26
davewhodavedunn
2006 Acura TL
Thanks for the help but I think I got it...read post 24
REPRESENTIN CANADA!
acura, back, cl, due, hum, humming, irregular, left, noise, rear, rubbing, tire, tl, tyre, wear, wheel
