Air Conditioner blows cool but not cold air - AcuraZine Community
Old 05-29-2010, 5:53 PM   #1
usaf2008
Points: 3,570, Level: 37
Points: 3,570, Level: 37 Points: 3,570, Level: 37 Points: 3,570, Level: 37
My A/C blows barely cool but not cold air. I took it to an A/C shop and they evacuated and recharged the R134 refrigerant. It was at .22 lbs and I guess it holds 4 or 5 lbs. But the A/C is still not cold. It used to be colder. Could it be my compressor? I'm not sure what else to do. Thanks for any help or suggestions you have.
P.S. I use the recirc button and I have closed off my rear and side vents. Still just barely cool.
05 WDP TL AT NAV/Wood Shift Knob/CCFL Plate Light/Interior LED lighting/LED footwell lights/Navi Hack/Rear Lip Spoiler/Chrome Grill/Chrome Handle Accents/Chrome Rims/Headlights Cleared/TL-S Tail Lights&sidemarkers/Switchblade Key/Tint/Debadged/Racing Pedals
usaf2008 is offline   Reply With Quote
Old 05-29-2010, 7:06 PM   #2
avs007
avs007's Avatar
Points: 9,723, Level: 66
Points: 9,723, Level: 66 Points: 9,723, Level: 66 Points: 9,723, Level: 66
Activity: 0.3%
First things first, why was it at .22 pounds? That means there is a leak in the system somewhere.. Was that fixed? Otherwise it could be two things... One, check the clutch on your compressor to see if it engages.. You should be able to look at your compressor, and see if the front of the pulley is rotating. I'm not sure if the TL has a variable speed clutch, like my other car, but if it does you can check to see if the clutch is fully engaged or just partially engaged, by looking at how fast the front of the pulley is rotating in comparison to the pulleys around it...
Otherwise, it could be a stuck temperature door. I've had that happen before in my other car... The hot air door would not fully close, making it so the air was only barely cool...
avs007 is offline   Reply With Quote
Old 05-29-2010, 10:05 PM   #3
Turbonut
Trader Rating: (1)
Points: 13,310, Level: 75
Points: 13,310, Level: 75 Points: 13,310, Level: 75 Points: 13,310, Level: 75
Activity: 17.5%
Activity: 17.5% Activity: 17.5% Activity: 17.5%
System capacity is 1.1-1.2 lbs.
Turbonut is offline   Reply With Quote
Old 05-29-2010, 11:29 PM   #4
Dino81
Dino81's Avatar
Points: 4,249, Level: 41
Points: 4,249, Level: 41 Points: 4,249, Level: 41 Points: 4,249, Level: 41
Im no AC expert but I am going thru something similar. took it to get the AC checked out and I was told my "low" side wasnt low enough? i guess it was in the 50 psi range, when it shoulda been in the 30's.
anyhow, I was told the compressor was getting weak, so I just ordered a new compressor, drier, and expansion valve. HOPE I was told right and it cures my problem.
Ill let u know how it goes.
04' NBP/camel, A-spec body kit, Wood acc. wheel, Blacked & cleared HL, oem vent visors, roof spoiler, accord fogs,5% tint, debadged, keyhole delete,18x9,18x10 Work vs-xx, F&F type 1, progress RSB, UR pulley, RV-6 V1+Race Pipe, Comptech catback, Injen CAI, Rotora bbk,.
Dino81 is offline   Reply With Quote
Old 05-30-2010, 6:02 AM   #5
Turbonut
Trader Rating: (1)
Activity: 17.5%
Not the compresssor, at least in my opinion. Didn't they try and add refrigerant to lower the reading, and do you know the high side reading?
Just remember, if they change the compressor, evac and fill with correct refrigerant weight and it works properly, doesn't indicate it was the compressor, but was low on charge.
Old 05-30-2010, 9:02 AM   #6
Dino81
Dino81's Avatar
yea sorry, I forgot to mention they DID evac and refill. The high side reading was somewhere in the mid 200psi range, i do believe..sorry I cant get any more specific, seeing as how I dont remember what they said.
they did tell me the correct amount of freon was in there to begin with. but like i said they did an evac and refill anyways. BTW mines an 04' with 90k.
Thanks for your input though, and just for my wallets sake (bc I ordered everything already), I hope your wrong! lol
It would suck if I spent all that money on shit I didnt need..It coulda went toward a CAI and pulley
Old 05-30-2010, 10:00 AM   #7
Turbonut
Trader Rating: (1)
Activity: 17.5%
Never heard of a weak compressor, valves will leak/stick, seals will leak, but not a weak compressor. There are other items that can cause the low side to be high.
Old 05-30-2010, 2:23 PM   #8
Dino81
Dino81's Avatar
Quick google search yielded me this......
Usually the compressor will show the inability to generate enough suction and pressure at or near idle speeds.
If engine speed needs to be substantially increased to bring pressures in range, that's a sign that the compressor is getting weak. Often the complaint is... only cools when the engine is reved - or - only cools when driving down the road.
Sometimes it's very simple. If we hook the gauges up and see 80 psi on the low side, and 80 psi on the high side, and the compressor hub is spinning, it's likely that compressor is done. It's not producing suction, and it's not producing pressure. We could add or remove refrigerant and still nothing would happen. The compressor must be able to pull a vacuum, and create pressure. Compressors that use a variable stroke are often misdiagnosed as being defective, when only the internal pressure control device is at fault.
Mine, however doesnt seem to matter if Im at idle or 3k RPM. I did explain that to the tech also. I used a infared thermometer and i was getting 60F at the vents.
I want the A/C to be like opening a freezer and sticking my head in it! lol
Old 05-30-2010, 3:17 PM   #9
usaf2008
Well it seems my thread has been somewhat hijacked. I don't have pressure problems. My R134 was low and they refilled it because it was at .22 lbs. However, the refill didn't fix the problem. So I have to go back to the shop to have it looked at again. I was just trying to get an answer as to what it could be. My guess is a leak.
Old 05-30-2010, 4:24 PM   #10
Turbonut
Trader Rating: (1)
Activity: 17.5%
As it is a closed system, if level is low, there is a leak.
[COLOR="Lime"]Usually the compressor will show the inability to generate enough suction and pressure at or near idle speeds. If engine speed needs to be substantially increased to bring pressures in range, that's a sign that the compressor is getting weak. Often the complaint is... only cools when the engine is reved - or - only cools when driving down the road.
You can Google all you want, but:
ďWhen engine rpm is increased to bring pressures in range thatís a sign of a weak compressorĒ needs some work, it may mean a weak A/C unit, but that is a far cry from a weak compressor.
There are many factors when servicing an a/c system, many of which one canít debate unless the system has been evacuated, filled with the proper weight, and gauges viewed, however, warmer air at idle can be from low gas, blocked air flow, fan/fan motor not working, and at higher engine speeds, as the refrigerant is circulating quicker and more air flow over the condenser, the air becomes colder, so a weak compressor is out of the picture. There is testing that can be done using the ambient temp, humidity, outlet temp while keeping the engine at 1500RPM. Itís in the FSM. Iíve also seen a defunct heater control valve cause a problem along with doors that arenít operating properly because of non working activators, not necessarily on a TL, but in general.
Good luck and let us know how you make out.
Old 09-28-2010, 8:59 PM   #11
usaf2008
sorry to take so long to update you all, but the problem was that the seal around the cap was not intact. They replaced the seal and all was good, apparently the coolent was blowing out of the cap.
Old 09-28-2010, 11:57 PM   #12
01tl4tl
Points: 40,286, Level: 100
Points: 40,286, Level: 100 Points: 40,286, Level: 100 Points: 40,286, Level: 100
Activity: 66.8%
Activity: 66.8% Activity: 66.8% Activity: 66.8%
dont close the rear or side vents off- air still gets blown thru the tubes and trapped air = moisture can collect--bateria--mold--lots of fun stuff for your lungs to absorb
change your cabin air filter--book says ever year!
Old 05-21-2012, 1:59 AM   #13
Falen
Falen's Avatar
Points: 5,240, Level: 46
Points: 5,240, Level: 46 Points: 5,240, Level: 46 Points: 5,240, Level: 46
Which seal and which cap ??? thank you
Falen is offline   Reply With Quote
02, ac, acura, air, blowing, blows, car, cold, conditioner, cool, high, hot, low, read, side, tl
