Cam seal and valve cover gasket leaks - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL Community > First Generation TL (1996-1998)
Old 05-20-2010, 2:32 PM   #1
twentynothing
New Member
I had my timing belt & water pump replaced on my '98 TL yesterday, and was told by the dealer that my rear cam seal and valve cover gaskets are leaking for sure. He quoted me $650 to replace them and clean the motor up, to see if there is other leaks.
Thinking the price is too high, I declined it. Today I looked up online and found that the cost for replacing the seal and gaskets is mostly labor, and he is already there when replacing timing belt!!! Why hasn't the dealer told me this?
Do you guys think $650 is too high? What is a reasonable price to get the leaks fixed? Thanks!
Also he mentioned "sth." is soaked in oil because of the leak. I didn't hear exactly what. What could be soaked? Does it damage the engine or anything?
twentynothing is offline   Reply With Quote
Old 05-25-2010, 6:43 PM   #2
desired_speeds
desired_speeds's Avatar
Points: 9,915, Level: 66
Points: 9,915, Level: 66 Points: 9,915, Level: 66 Points: 9,915, Level: 66
Activity: 0.4%
well considering that the mechanic has to pull the timing belt again, as well as the valve covers, rocker arms, and cams, I'd say $650 is in the ballpark.
. k e n
desired_speeds is offline   Reply With Quote
Old 05-26-2010, 2:37 AM   #3
myisanog
1998 Acura TL
myisanog's Avatar
shouldve changed it the same time as the timing belt . would've been ridiculously cheaper since its already out
'98 3.2 TL
myisanog is offline   Reply With Quote
Old 06-06-2010, 9:31 PM   #4
SeabeeGuy
More likely the O ring for the distributor is where the leak is coming from and not the camshaft. Is the leak at the rear of the engine by the firewall? If so most likely the distributor O ring.....you can see the oil on the top of the tranny housing at rear of engine. The O ring and the valve cover gasket are pretty cheap and easy to install, recommend you do it yourself.
SeabeeGuy is offline   Reply With Quote
Old 06-06-2010, 11:03 PM   #5
7 Tl
7 Tl's Avatar
Points: 4,624, Level: 43
Points: 4,624, Level: 43 Points: 4,624, Level: 43 Points: 4,624, Level: 43
Activity: 0.5%
$650...damn thats pricey!! I got both valve gaskets left/right replaced for 140 including labor
7 Tl is offline   Reply With Quote
Old 06-07-2010, 12:03 AM   #6
desired_speeds
Activity: 0.4%
cams seals are expensive though.
. k e n
99, acura, belt, cam, camshaft, cl, coming, cover, gasket, leak, leaking, oil, rear, seal, sealent, timing, tl, valve
