O'Reilly Full Synthetic Oil?? Anyone tried it?
Old 05-03-2010, 03:11 PM
N.I.toHTown's Avatar
I saw this ad
http://www.oreillyauto.com/site/c/currentad/get.oap
And wondered if anyone had used the new O'Reilly Full Synthetic Oil? Seemed like a decent price but i don't know much about it.
Old 05-03-2010, 03:19 PM
A Black TL
TL|GTX's Avatar
Just stay with mobil1
Old 05-03-2010, 04:04 PM
Turbonut's Avatar
With all the oil threads, the answer is always the same, use whatever you you want and you'll have no problems, as long as it's API certified and the correct viscosity. Synthetic or Dino!
Old 05-03-2010, 06:39 PM
oreillys and kragen are the same company- considering how many specials they run on oil it would not be surprising if they are owned somehow by a major oil company
and they market an in house brand thats a name brand in a different bottle? cool
Old 05-18-2010, 04:08 PM
iceman1110's Avatar
You have already found an answer, I was just doing some forum browsing and came across this question. I work for O'Reillys and this past week did some research because I was wondering the same thing. It is packaged by Omni Industries but they use oil from exxon/mobil and shell.
Old 01-17-2011, 04:31 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
I just bought a 5 gallon jug of this with a Fram filter. It cost me $20.60 after tax. Can't beat that price for a "full" synthetic.
Old 01-17-2011, 04:58 PM
scottyrocket53's Avatar
I used it in my wife's Pacifica but I haven't done a change yet in my 06 TL (just bought it). A BMW mechanic told me that he uses the Oreilly brand in his BMW's and swears by it.
Old 01-17-2011, 06:14 PM
nfnsquared's Avatar
Here's the website for their fluids. The OMNI plant is in Shreveport, LA. You shouldn't have any worries using this oil:
http://oreillylubetech.com/
Old 01-17-2011, 06:17 PM
Although I'm not worried, I'm curious to see what the specs are on this oil compared to other "full" synthetic oils.
$20.60 for 5 quarts + filter? You can't beat it, even if it wasn't "full" synthetic.
I meant, "quart".
Old 01-17-2011, 06:30 PM
nfnsquared's Avatar
They have an abbreviated spec sheet on the website. Wish it had HTHS specs.
http://oreillylubetech.com/PDS/Synth...Multigrade.pdf
Old 01-17-2011, 08:07 PM
Chapter Leader (San Antonio)
TheChamp531's Avatar
Old 01-19-2011, 10:04 PM
nfnsquared's Avatar
Called their tech support. HTHS for their O'reilly synthetic 5W20 is 2.63, which is a little lower than M1 5W20 (2.77).
Also learned they will have 0W20 in stores starting the first week in Feb.
Old 01-20-2011, 08:02 AM
LoveMyTL-S's Avatar
May have to give this a try in the CR-V.
Old 01-27-2011, 03:26 AM
4drs just wanna have fun!
Accord_V6_400m's Avatar
was going to get the Ford 5-20 syn blend until I saw this on the Kragen circular.
Looks pretty good, some people didn't like it on bobistheoilguy.com
VVV
Analyzed by Holt Cat at their San Antonio lab
All elements not included are 0.
5w20:
Pb 1
Si 3
Na 456
B 1
Mo 1
Ca 1815
Mg 3
Zn 767
P 694
Vis @100C 9.9 (???)
TBN 8.0
ISO 22/15
Lab said the particle counts were high on this oil(?!?) Considering that and the viscosity I'd like to see this sample re-run.
5w30:
Si 2
Na 431
Ca 1413
Mg 3
Zn 695
P 623
V @100C 11.0
TBN 8.0
ISO 19/14
I have the 5w30 in my car now. It seems to be slightly nosier on cold startup (there are some noises of concern but they didn't start with this fill). Once it's hot though, it purrs like a kitten, smoothest it's ever been. Probably the thickest 30wt that it's had at 11.0.
Old 01-27-2011, 05:48 AM
nfnsquared's Avatar
^^^ I wouldn't necessarily be discouraged by a single VOA. It's probably fine for the average driver.
I've run M1 5w20 exclusively for 106K miles and it's been great. I did a UOA on my last oil change which came out excellent.
I decided to give M1 0w40 a try on my last oil change due to it's high HTHS and full syn properties. So far, it looks like it's costing me about 2 mpg due to the higher VIS. Going to run it for the same interval as the last oil change (8150 miles) and do another UOA just for comparison, but probably will switch back to 5w20.
I may try Honda's 5w20 syn blend (made by ConocoPhillips, SN/GF-5) on the next change. It's only $3.09 (with military discount, normally $3.43) at my local Honda dealer.
Old 01-27-2011, 09:47 AM
jrod08TLS's Avatar
Honda just released there "Ultimate" Full Synthetic oil with API ratings (SN/GF-5) which are the most recent standards adopted by the American Petroleum Institute. It seems to be really good so far. They make in 0W-20, 5W-20, 5W-30 and 10W-30 so far. On paper it on par with Mobil 1. I have ran Mobil 1 5W-30 in my Type-S for 20,000 and considering a change, but I will let other people review Honda's Full Syn a little more before I decide to change or not.
This PDF guide gives a real good explanation of oil ratings:
http://www.api.org/certifications/en...010_120210.pdf
Old 01-27-2011, 10:06 AM
nfnsquared's Avatar
I saw the thread on BITOG, but I talked with my Honda parts guy and he says Honda doesn't carry a full syn oil. ConocoPhillips is now making the Honda oil and neither the 0w20 or 5w20 bottles that I looked at were full syn.
Maybe it's not yet been released to the dealers?
The Honda 5w20 blend that I posted on 2 posts ago meets the SN/GF-5 specs and it's only $3.43/qt. The 0w20 blend is over $7, go figure. Also, the bottles didn't say "Ultimate" on them, but they just arrived in the new packaging last week. (Old packaging had ExxonMobil on the back).
Old 01-27-2011, 10:29 AM
nfnsquared's Avatar
^^^^ correction. My parts guy couldn't find the "Ultimate" because the new part numbers (08798-9037/8/9) haven't yet been loaded into their system. They can't even order it yet through Honda, but have to go straight to ConocoPhillips.
It is indeed full syn. However, according to the pictures in this thread, the bottles are not labeled for SN or GF-5???
http://www.honda-tech.com/showthread.php?t=2873437
Retail is $7.65/qt.
Old 01-27-2011, 12:09 PM
LoveMyTL-S's Avatar
Honda offers a Military discount? What percentage? And is this just for parts?
Old 01-27-2011, 12:17 PM
nfnsquared's Avatar
The local dealer up here does (this is a military town though) for parts.. 10% and/or they'll usually meet acurapartswarehouse.com (or similar online wholesaler) pricing.
I'm leaving right now to pick up a case of the Honda 5w20 syn blend for $3.10/qt (plus tax)...
FYI, my parts guy told me that the 5w20 blend price is going up in Feb. He didn't know how much. That's why I decided to grab a case now....
Old 01-27-2011, 12:18 PM
LoveMyTL-S's Avatar
The local dealer up here does.. 10% and/or they'll usually meet acurapartswarehouse.com (or similar online wholesaler) pricing.
FYI, my parts guy told me that the 5w20 blend price is going up in Feb. He didn't know how much...
Good to know. Tks.
Old 01-27-2011, 01:26 PM
I hate cars's Avatar
Marketing at it's best. A "syn blend" or "semi-synthetic" is nothing more than a grpIII blended with a grpII or grpI oil. Or in other words it's a bunch of dino oils blended together with a higher price tag. This is common place regardless of the label. Most any oil is a blend of different groups but sometimes they choose to label different and charge more.
Any oil will work fine and you're not going to notice a difference in the way it runs.
My car is a rolling experiment. I've used only two oils in it since new not counting the factory fill. I used Amsoil ACD for the first 65,000 or so miles. And it's going to be Redline 5w-30 for the rest of it's life. So at teardown time I will be able to see exactly how the oil did.
I prefer an oil that is not API certified so there are no limits on the amount of ZDDP the oil can have. This is why Redline and some Amsoil oils are not certified. If they were, they would not be as good. They have 2-3 times the amount of allowable ZDDP additives which is a good thing if you're concerned about the engine lasting a long time.
Why change from one mediocre oil to another? Mobil One is a great grpIII oil that's very cheap if you shop around. There just isn't much difference between these types of oils listed but at least you know M1 is a quality product and is all you will ever need.
If you want a significant change you're going to pay. A true synthetic grp IV oil like Royal Purple and many Amsoil brands will start around $8 a quart and a grpV oil like Redline starts around $10 a quart. There just aren't many true synthetics out there.
Old 01-27-2011, 02:03 PM
nfnsquared's Avatar
^^^^Not telling me anything I don't already know.
And yes, for the avg driver, any of today's oil (dino, blend, full syn) changed at reg intervals will be fine. That fact, along with a VOA that indicates the Honda blend is on par with M1 for only $3.10/qt is why I'm going to give it a try. Even at the full retail of $3.43/qt, the price is hard to beat.
Again, I'm not advocating for/against any oil, just providing info on options available to users.
Old 01-27-2011, 02:10 PM
nfnsquared's Avatar
Honda 5w20 syn blend available for $2.45/qt
Just got back from my local Honda dealer. The Honda (ConocoPhillips) 5w20 syn blend is available from their bulk stock for $2.45/qt (their full retail price for bulk). Just bring in a jug and they'll fill it.
I can't vouch for other Honda dealers, but this is a great deal if your Honda dealer will do the same.
Old 01-28-2011, 01:19 AM
rully1012's Avatar
ive tried it out and at first it seemed a little thinner but i cant tell much difference compared to mobile 1 its a decent oil at a decent price in my opinion
Old 01-28-2011, 01:29 AM
Ya seems a little thinner, I had a similar feeling with Royal Purple back in the day but RP is still better.
Its running pretty good so far changed it out today, had Penzoil Platinum syn 5-20 for ~3100miles and I felt an improvement when the new stuff went in.
Old 01-28-2011, 08:29 AM
If an oil says 5w-20 it has a certain viscosity range it has to fall in. You're not going to be able to see a viscosity difference with your eyes when pouring with the same weight oil. As for feeling a difference especially with the same weight, pretty much impossible. If you went from a 0w-20 to a 50wt, you might be able to feel a difference if you were really paying attention.
Old 01-28-2011, 05:35 PM
jrod08TLS's Avatar
Retail is $7.65/qt.
The labels on the back are labeled SN and GF-5. I just checked them out. We got the 10w-30 and 5w-20 in stock last week.
Old 02-18-2011, 10:33 AM
Chapter Leader (Houston)
TLDude876's Avatar
So has anyone tried Oreilly's synthetic oil?
Old 02-18-2011, 03:16 PM
taker777's Avatar
They're kinda pretty much the same
Old 02-18-2011, 04:26 PM
yeah look up a few posts
Still good I think I have almost 1500 miles on it so far
Old 02-18-2011, 06:30 PM
nfnsquared's Avatar
FYI, you should be able to get the Honda syn blend 5w20 for $2.45qt from your local Honda dealer's bulk supply...cheaper than O'reilly and similar/same specs (which is also pretty much equivalent to M1 5w20).
Old 04-09-2012, 12:37 PM
callen's Avatar
While O'Reilly's front label says "Full Synthetic", the back label states that it is a "blend of base oils". I do not think it can be both full and blend. So I am not really sure what is in their bottle. You might want to check it out.
IBankMouse
06-13-2020 12:53 PM
acuratl26
04-23-2020 07:30 PM
lanechanger
10-13-2015 10:56 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: O'Reilly Full Synthetic Oil?? Anyone tried it?
