Transfer case gear oil: Is 75W-90W OK?
Old 03-14-2010, 08:39 PM
2005 MDX & 2006 RL
cbrose's Avatar
At some point, when the east coast weather gets a bit warmer, I'll do my tranny and transfer case. The repair manual suggests API G4/G5 in the SAE 80W-90W range. Seeing that it rarely gets below 0 degrees in the Philly suburbs, 90W hypoid gear oil is the requirement. However, I have a bottle of Valvoline synthetic 75W-90W gear oil in my garage (http://www.valvoline.com/products/br...er/gear-oil/59). Would this be OK to use? Does the weight range matter in this case? Would this oil be too thin? Thanks!
Old 03-19-2010, 10:04 AM
2005 MDX & 2006 RL
cbrose's Avatar
75w90 may work fine in transfer case
After some reading/searching, I found some comments from people asking the same question with their vehicles. Here's a response from Mobile 1 on using 75w90 where 80w90 or 90w is called for:
http://www.mobiloil.com/USA-English/...Viscosity.aspx
Could be propaganda from Mobil 1, but makes sense it's still 90w at operating temperature and it meets the GL-5 EP rating. Comments?
Old 03-19-2010, 12:28 PM
JPSMAN's Avatar
I have used the Mobil 1 product before, as long as it meets the API GL5 its fine....that is the standard that is required etc.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
hpfiend
09-27-2015 06:59 AM
AcuraKidd
09-26-2015 04:10 PM
Quick Reply: Transfer case gear oil: Is 75W-90W OK?
