'04 RSX Headlight Problem!?
Old 09-27-2009, 10:58 PM
Gigi377's Avatar
I have replaced my left dim headlight for my 2004 Acura RSX, four (4) times within a 12 month period. It has again gone out after being replace last month. The local dealership says I may have to spend hundreds or thousands of dollars to try to find the problems..and it may not be found!...? Is there anyone that has had this problem, and does anyone have any suggestions..Any help is appreciated.
Old 10-05-2009, 12:25 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
What type of bulbs are you replacing? Are you touching the bulbs with your bare hands? Could be a bad ground or wiring issue as well
Old 10-05-2009, 01:45 PM
I can divide by zero
C25A1guy's Avatar
The RSX is really finicky when it comes to replacement bulbs for some reason. You best bet would actually be to upgrade to HID's.
Old 02-18-2010, 02:28 AM
Acura2006Rsx's Avatar
sorry to nerco the thread. but this happened to me. my bulb died out after a month of replacement then got a new bulb and replaced it again at an autoshop and i was there watching them replace it and stuff and nothing seems to went wrong. but then after like a week, the bulb died out, and the guy told me, i should just upgrade to HID instead of using the regular stock bulb, and once i got those HID it seems to be just all fine. been using those hid for about a month now also.
cycdaniel
12-17-2019 10:58 AM
MistaWet
09-15-2015 08:26 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
darknite123
Integra
08-30-2015 03:00 PM
Quick Reply: '04 RSX Headlight Problem!?
