how do I remove the glove box on 05 tl?
Old 09-02-2009, 04:58 PM
Pureadrenaline's Avatar
I need to tighten the u shaped bracket that the glove box comes to when shutting it. It sounds like the screws holding it are loose and it vibrates on bumpy roads etc.
So can someone please easily describe how to safely remove it without damaging anything. it sounds like there are clips to remove???
Please help, want to fix this rattle today.
Thanks so much an advance!
Chad
Old 09-02-2009, 05:08 PM
The DVD-A Script Guy
Adobeman's Avatar
https://acurazine.com/forums/showthr...move+glove+box
This thread is how to replace the cabin air filter but to do that you first need to remove the glove box. Pictures are in the thread
Old 09-02-2009, 11:43 PM
dude you ROCK! Thanks for this find. I'll report back when the rattle is gone!
Old 09-03-2009, 12:05 AM
Ok, I'm choked. My tl doesn't have the tabs on the inside of the box to use the flat head screwdriver to pop off. It's different? What year of tl is that in the pics?
What am I missing???
Old 09-03-2009, 08:40 PM
Adobeman's Avatar
Yeah, those picks are an 04. I just looked in my 05. No tabs, just squeeze in the same area of the glove box and you will see the tabs you need to clear. After that it's pretty much the same as I recall from when I did my cabin filter.
Old 06-03-2010, 03:47 PM
mrsimeon's Avatar
Chad
HEY did you ever Fix the RAttle in the Glove box...Mine is rattling and looks like it is coming from the right side of the glove box. IF i press the door shut hard enough the rattle stops.....????
anyone else have this problem?
Old 06-03-2010, 05:01 PM
csmeance's Avatar
Received 1,988 Likes on 1,412 Posts
Yes, the clips can come out or become loose, take out the glove box and then the trim piece behind it (the one that comes out to change the air-filter). Check to make sure all the clips are there, and if they are carefully put the piece back (make sure the tab on the side goes in properly) and hit it to make sure it's in place. Put the glove box back and and see if it rattles!
Old 06-04-2010, 07:34 AM
Q('.')=O
imj0257's Avatar
Yea what they ^ posted above. I was weary doing it my first time to replace my cabin filter but it is easy as pie.
Old 06-04-2010, 01:45 PM
Musky300's Avatar
Just go slowly when you take the back of the glovebox (trim piece) out...making sure how the tabs/clips come out. And be sure to take your time putting them back in slowly to make sure they are all in.
Going out...start from right and work your way left.
Going in...start from left and work your way right.
Be sure to use some strong force to get them to pop back in, but go slow and if it doesn't feel right, don't overly force it.
I was too anxious the first time I did this, pulled it all out...broke a clip, and then had a bear of time figuring out how it snapped back in. Not hard, but just took some time.
Old 06-04-2010, 03:28 PM
cowboys9193's Avatar
This is unrelated but do any of you know how to replace the vanity mirror lights? I would appreciate the help
SidhuSaaB
05-30-2020 12:40 AM
LoneRonin
01-04-2016 01:03 AM
eastsideride
10-15-2015 04:26 AM
STL TL-S
09-23-2015 08:52 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: how do I remove the glove box on 05 tl?
