Fuel Injectors (s2k)
Old Aug 23, 2009 | 02:37 PM
Rejckt's Avatar
When upgrading to s2k injectors, do you use the
2000-2003 S2k Injectors or the 2004-2005 S2k Injectors?
And correct me if I'm wrong, but the 00-03 are 360cc and the 04-05 is 370cc?
Plus any recommendations / suggestion / opinions on other injectors are appreciated as well, just that searching around... s2k seems like it has less hassle to install.
Old Aug 25, 2009 | 09:39 PM
Rejckt's Avatar
close this thread, no one knows the answer.
Old Aug 25, 2009 | 09:42 PM
MurdaZ's Avatar
rajca can chime in? i thought he swaped with s2k injectors....or someone else?
Old Aug 26, 2009 | 08:42 AM
Rejckt's Avatar
regardless, i bought the injectors already. so ima just hope for the best.
Old Aug 26, 2009 | 09:56 AM
phee's Avatar
I got the Shifts
why dont u tell us which injectors u bought?
Old Aug 26, 2009 | 10:08 AM
andrew070489's Avatar
^ yeah if you find it works post so others know
Old Aug 26, 2009 | 10:12 AM
Rejckt's Avatar
I bought a set of used 2006-2008 oem injectors off of s2ki's forum. I'll update to let others know about fitment issue when it arrives. If they're dirty, I'll send them to rc for cleaning and that way, we'll know the flow rate as well.
Old Aug 31, 2009 | 05:35 PM
CL-S6's Avatar
Turbo 6 Speed
Its the 2000-03 s2000 injecotrs that work in our j32`s. I was using them with my turbo setup.
Old Aug 31, 2009 | 06:58 PM
02type-s's Avatar
-Arsenic-
Without a tune and a lot of mods, it would be useless, right?
Old Sep 1, 2009 | 07:56 PM
CL-S6's Avatar
Turbo 6 Speed
Yes it would. You atleast need some sort of FI to warrent the need for bigger injectors.
Old Oct 15, 2009 | 09:58 AM
gerzand's Avatar
Whats the stock cc/min output for stock 2G TL injectors? Are they the same as the 3G's 250cc?
Old Oct 15, 2009 | 12:34 PM
Rejckt's Avatar
I believe they are 270cc. I have 8 s2k injectors sitting under my bed, been to lazy to install them.
Old Oct 15, 2009 | 01:32 PM
gerzand's Avatar
I was wrong. 2G's are 250's and 3G's are 270.
Just ordered some RDX 410's for my high flowing 3G TL. Cant wait to modify 'em to fit.
This should be interesting
Old Oct 17, 2009 | 07:12 PM
Rajca's Avatar
wham bam thank you ma'am
2nd gen tl/ cl are 290
s2k are 370
rdx are 410
rdx injector will need to be modified to fit the 2nd gen tl/cl and u will need to buy 6 scion tl injector clips
Old Oct 17, 2009 | 07:37 PM
gerzand's Avatar
thanks Raj. Yup, clips already ordered thru Toyota. So pumped....my 3G is goona be pushin 360 to 370 to the wheels with those rdx 410's, cams, PnP'd everything, lots of head work. And best of all...NA
Old Oct 17, 2009 | 07:54 PM
Rajca's Avatar
nice. just make sure that u put the wires in the right places. i switched two of them around and had a misfire code in all cyl. what a fuckin headache that was to find.
Old Nov 6, 2009 | 10:11 AM
Rejckt's Avatar
Okay so, it seems that the ap2 s2k injectors clip onto our stock clips with no problem. I'm pretty sure fitment isn't going to be an issue... but does anyone know if the s2k injectors being drive by wire will affect the functioning of the injector?
I mean if it clips and fits, it should be okay... right?
Old Nov 6, 2009 | 10:13 AM
gerzand's Avatar
Yeah man, a honda compatible injector is just that... a honda compatible injector. As long as the electrical voltage range used is the same (which all honda's are), it'll work fine
Old Nov 6, 2009 | 12:07 PM
Rajca's Avatar
^x2. All will be good
Old Nov 12, 2009 | 02:08 PM
Rejckt's Avatar
fitment is an issue, im sitting here boreing out the fuel rails =/
Old Nov 12, 2009 | 02:11 PM
gerzand's Avatar
^^ ur not the only one.... im doing RDX injectors. Ive got to bust out the dremel :P
Old Nov 12, 2009 | 09:30 PM
Rajca's Avatar
i didnt need to use a dremel when i put in teh rdx injectors. just needed to trim some useless plastic on the injector and swap o rings. a guy has been running the same exact setup (hes the one that helped me) for thousands of miles while boosted with out any problems
Old Nov 13, 2009 | 12:04 AM
gerzand's Avatar
well... yeah. I mean, I'm going to use a dremel sanding bit to remove the 1/4 inch of plastic. How did you trim it then?
Old Nov 13, 2009 | 04:22 AM
Rajca's Avatar
i trimmed the injectors with a dremel. i though u were enlarging the holes in the fuel rail
Old Nov 13, 2009 | 05:26 AM
NVA-AV6's Avatar
BANNED
If you guys are opening up the rails (which I have done to fit RDX injectors) do yourselves a big favor and plunk down the $50 to get a 13.5mm fine reamer from a tooling/industrial supply house (I got mine from McMaster Carr), the last thing you want is a rough surface inside to destroy the o-ring during install. I first carefully expand the existing 12mm hole with a 9/16" deming drill bit then foloww thru with the reamer a very low speed and then use some 1000 grit sand paper on a wood dowl to finish the rail and end up with a near factory finish....
Also, a injector electrically is just a coil of wire (like a solinoid) and does not have polarity, how did reversing the wires cause misfires unless you cross connected two wires from two different injectors??
Old Nov 13, 2009 | 06:48 AM
Rajca's Avatar
I've been wondering about something, if u put in larger injectors will u need to get a tune right away? Or will the computer and fpr adjust the amount needed
Old Nov 13, 2009 | 08:52 AM
NVA-AV6's Avatar
BANNED
Depends....
With a 2nd gen TL/CL-6th Gen AV6, it will try, but the ECU seems to only be able to pull 40% max fuel, so as long as you are within 40% of stock size it can, the question is though how upset will the ECU be, p[ulling that much fuel it is going to know something is up and trigger some CEL. The other issue is that the ECU is in open loop mode (just running off the on-bord map) at startup, it will be running so rich it will wash out the cylinders walls and gas foul the oil which will destroy the engine in a fairly short time frame.
Now the 3rd gen TL and 7th gen has a much more advanced EMS which uses wideband O2 sensors and would compensate much more quickly, but will still not be happy and will have the same startup issues.
Old Nov 13, 2009 | 09:38 AM
gerzand's Avatar
wow this is some good info NVA. What type of build was the TL that you put the RDX injectors in? A stroker?
Also, Ive been thinking about buying some high quality quick-disconnects for the existing stock and new RDX injectors pigtail wires so that if I need to go backto stock, it will be a cleaner/no solder mess. As long as the quick-disconcontnect continuity is good, do you think this is an OK idea?
Old Nov 13, 2009 | 09:50 AM
Rejckt's Avatar
which injectors are plug and play?
Old Nov 13, 2009 | 09:56 AM
gerzand's Avatar
RC injectors.... but near a $100 a piece. RDX'ers are only $37/pc
Old Nov 21, 2009 | 08:25 AM
NVA-AV6's Avatar
BANNED
Yes it was a 3.6L/6spd.
If anything get the Scion connectors from toyota, the last thing you want is to kill your enging due to a faulty injector connection.
Old Nov 21, 2009 | 05:13 PM
gerzand's Avatar
I have the scion clips.... im refering to the pigtails. Anyways, I think im just going to solder. Less agony down the road if something were to happen.
Old Nov 21, 2009 | 06:46 PM
Rajca's Avatar
the clips are cheap and easy to re pin. just do it that way instead of soldering them in permanently. what about if u need to change teh injector? gonna cut the wire?
Old Nov 21, 2009 | 07:06 PM
gerzand's Avatar
HAHAHA you guys still dont get what im saying. Again, I HAVE THE CLIPS.
The whole concern was of cutting the Original pigtail wires then wanting to be able to go back to stock down at some later point in time and it being a PITA because the connections will have been soldered to the new pigtails already.
Old Nov 21, 2009 | 07:09 PM
Rajca's Avatar
u dont have to cut the pigtail wires. dont know what its called, but theirs a tool that makes getting the pin out of the clip, or u can use a small screw driver.
Old Nov 21, 2009 | 07:11 PM
gerzand's Avatar
i guess, just seems ghetto to me to re-use the fragile metal internal parts of the clip. I saw the screwdriver method on the tutorial that was posted.
Oh well...
Old Nov 21, 2009 | 07:25 PM
NVA-AV6's Avatar
BANNED
It's not at all ghetto, ghetto would be using crimp connectors and just shoving them on the injectors or cutting the wires and just taping them in (don't laugh, I have seen it done.....), as long as the metal part is not corroded or bent it is fine to reuse it and infact helps to keep the harnesses integrity.
joflewbyu2
Aug 18, 2019 10:38 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Juandiablo
Sep 27, 2015 10:32 AM
