remove front axle
Old 08-17-2009, 04:25 PM
cal6tl's Avatar
Question remove front axle
how do i remove the front axle in order to remove the engine?
thanks
Old 08-17-2009, 04:40 PM
mlassek's Avatar
remove the 36mm axle nut, remove the 17mm ball joint castle nut and break the ball joint loose from the LCA, remove the 17mm nut and bolt from the strut fork then pry the axle out of the trans with a prybar on the drivers side and for the right side separate the halfshaft and axle using a hammer and prybar.
Old 08-17-2009, 04:50 PM
cal6tl's Avatar
thanks alot i on my way to pick up a prybar =)
Old 08-17-2009, 10:56 PM
Shouldnt have to remove the axle to remove the engine unless you are removing the trans with it. You just need to unbolt the intermediate shaft (the passenger side)carrier bearing from the motor.
Old 08-17-2009, 11:07 PM
cal6tl's Avatar
yea im removing the engine and tranny =/
jblessing
08-08-2018 09:43 PM
08 NBP TL
09-08-2015 08:49 PM
truonghthe
09-07-2015 11:17 PM
Quick Reply: remove front axle
