NGK Laser Iridium vs. NGK Iridium IX... - AcuraZine Community
Closed Thread
Old 08-14-2009, 1:42 PM   #1
BuffBakerGA
2005 Acura TL
BuffBakerGA's Avatar
Trader Rating: (2)
Points: 7,197, Level: 56
Points: 7,197, Level: 56 Points: 7,197, Level: 56 Points: 7,197, Level: 56
I have a 05' TL auto with 90k miles.
All of the websites recommend this OEM plug IZFR6K-11 part number 6994 (~$9.99)... Regular OEM plug.
http://www.ngksparkplugs.com/product...m.asp?mode=nml
Some have used the Iridium IX plug ZFR6FIX-11 part number 6441 (~$6.99)... NGK states its there performance plug.
http://www.ngksparkplugs.com/product.../iridiumix.asp
The specs are same but has anyone had trouble with the IXs??? With all things being equal, I will go with the cheaper so call "performance" plugs. I want to change them out this weekend and I just want to make sure I have the right part for the job... Anyone personally install the IXs.
I've searched and this is the only thing I've found...
Originally Posted by me1abPSU View Post
Erick 3:
The NGK Laser plugs are OEM [Part #: IZFR6K-11 or #6994]
The NGK Iridium IX plugs are [Part #: ZFR6FIX-11 or #6441]
Both will work just fine. The NGK Iridium IX are their "perfomance enthusiast" plugs. http://www.ngksparkplugs.com/product.../iridiumix.asp
2005 SSM TL A-Spec | Type-S tails-sides-spoiler | F5 Fujita CAI | BM Drilled/Slotted Rotors and Pads | Progress RSB | V-LEDS | Tint 30% | De-badged
2007 WDP MDX | Ent. & Tech. Package
BuffBakerGA is offline
Old 08-14-2009, 3:48 PM   #2
BuffBakerGA
2005 Acura TL
Trader Rating: (2)
From what I've researched, it looks like the NGK Iridium IX plugs ZFR6FIX-11 (part #6441) are for the 2nd generation TLs and the NGK Laser Iridium IZFR6K-11 (part #6994) are for the 3rd generation TLs. Can anyone confirm this???
Has anyone put the IX plugs in a 3rd gen TL?
Old 08-14-2009, 4:53 PM   #3
Turbonut
Trader Rating: (1)
Points: 13,432, Level: 75
Points: 13,432, Level: 75 Points: 13,432, Level: 75 Points: 13,432, Level: 75
Activity: 14.4%
Activity: 14.4% Activity: 14.4% Activity: 14.4%
Your correct, but why even thinka bout putting teh 2G plugs in a 3G?
Go with what is recpmmended:
2004 ACURA TL 3.2 V6 J32A3 FI
OE Laser Iridium IZFR6K11 # 6994 .044
Turbonut is offline
Old 08-14-2009, 5:49 PM   #4
LoveMyTL-S
2008 Acura TL-S
LoveMyTL-S's Avatar
micheal.cain
Points: 25,120, Level: 95
Points: 25,120, Level: 95 Points: 25,120, Level: 95 Points: 25,120, Level: 95
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
It's only a $3 difference per plug. Total $18.
2006 Honda CR-V (Sahara Sand Metallic)
2008 Acura TL-S (Carbon Bronze Pearl)
| iJDMTOY | Drop Stop | vLEDS | Trunk Tray | All Weather Mats | Plastidip |
Car of the Month Contests are going on now! Is your car good enough to win our monthly contests and possibly be our 1st Car of The Year for AcuraZine? Click here and Sign up for this month's contest today!!!!!!!!
LoveMyTL-S is offline
Old 08-14-2009, 6:07 PM   #5
SodaLuvr
SodaLuvr's Avatar
Points: 22,237, Level: 92
Points: 22,237, Level: 92 Points: 22,237, Level: 92 Points: 22,237, Level: 92
Activity: 0.3%
Iridium IX is a performance oriented plug that is not designed for long-life. It is good for about 60k since it does not have the platinum pad on the ground electrode.
Laser Iridium is a long-life plug that is good for 105k, if not more. It features the platinum pad on the ground electrode.
The Laser Iridium is the one you want...
2010 Altima 3.5SR V6
2011 Toyota Prius III
Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Spoilers and bodykits are how much of the wall you take with you. Rollcages and windownets are how much of a mess you leave on the wall.
SodaLuvr is offline
Old 08-14-2009, 6:31 PM   #6
NE14RoxCJ
NE14RoxCJ's Avatar
Points: 5,229, Level: 46
Points: 5,229, Level: 46 Points: 5,229, Level: 46 Points: 5,229, Level: 46
Maybe what YOU want. I don't trust any spark plug to perform well for 105k miles. Not even really a money thing for me, I just can't see spending extra money on something I don't expect to take advantage of. Save the $20 and grab a 30 pack to drink while you change the plugs.
NE14RoxCJ is offline
Old 08-14-2009, 6:44 PM   #7
SodaLuvr
SodaLuvr's Avatar
Activity: 0.3%
Regardless, it makes more sense to purchase the longer life plugs. They would give you a greater margin of error, even if you changed them every 60k.
SodaLuvr is offline
Old 08-14-2009, 8:20 PM   #8
Turbonut
Trader Rating: (1)
Activity: 14.4%
Here's 0ne for y0u. The daughter's Maxima which came with 100,000 miles replacement plugs were replaced at 132,000 miles and running great. A little worn, but not as much as you might think. And yes this was the first replacement as she purchased the car new.
Turbonut is offline
Old 08-15-2009, 1:29 AM   #9
01tl4tl
Points: 40,640, Level: 100
Points: 40,640, Level: 100 Points: 40,640, Level: 100 Points: 40,640, Level: 100
Activity: 45.9%
Activity: 45.9% Activity: 45.9% Activity: 45.9%
gen2 came with NGK Platinum and can use Iridium IX or Iridium
gen3 came with Iridium
Thats to help it meet the magic 100 mark before ~needing~ replacement- unless you operate in the `severe service` part of the maitenance and need things at 60
Smart money changes the plugs at 50-60k miles to get max mileage and performance from them--Im on iridium ix with a gen2
dont care how good old plugs looked- its all about their resistance and sparking,,which has gone down considerably
Its like the headlight bulbs- they get dimmer with age but you dont relaize it
01tl4tl is offline
Old 08-15-2009, 5:28 AM   #10
Turbonut
Trader Rating: (1)
Activity: 14.4%
I don't agree.
Here's spme info straight from NGK:
FAQs - Spark Plugs
Q: How much of a performance improvement can I expect from changing plugs?
A: A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer cars' engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.
When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable.
Turbonut is offline
Old 08-15-2009, 11:45 AM   #11
01tl4tl
Activity: 45.9%
what dont you agree on?
I used the word considerably- while they say 1-2% toal engine output
ok maybe thats not ~considerable~ but its ~measureable~ hows that?
All I know for sure is new plugs in my 01 at 68k miles made it run better.
what percentage I couldnt say exactly- no dyno proof that cleaning the intake system and new plugs made a huge differance- though the 1-2 mpg increase overall seems to back up the theory of new plugs are better than old plugs.
Book says to change way before 100 if you drive in severe service like commute traffic stop and go, or live in cold or hot, or mountains or....
Of interest is the tech section at ngk on materials used in plugs now
01tl4tl is offline
Old 08-15-2009, 12:43 PM   #12
Turbonut
Trader Rating: (1)
Activity: 14.4%
It's just like plug wires on older cars, they don't make a difference either.
If the plugs are firing, you're not going to notice a difference when the new plugs are installed. Sorry, but similar to the mileage increase after Seafoam is used. IMHO It's purely mental, especially with the computer controlled environment maintaining the correct A/F ratio.
Turbonut is offline
Old 08-15-2009, 3:03 PM   #13
01tl4tl
Activity: 45.9%
seafoam works- physics and boroscope show that with a clean piston top, it fires that carefully controlled mixture better than a carbon coated one== see Torque
Clean valve edges seal better in the fast action open shut seal open shut seal life lived at high rpm
Clean valve stems dont interfere with airflow to the cylinder--
vtec delays the 2nd intake valve opening slightly and opens it for longer-
the purpose is to create a tornado like airflow into the cylinders- that burns much better!
Clean oil passages and pickup screen makes for spec oil pressure!!
sludge in TV commercials is real and a hazard to engines everywhere
That ethanol 10% added gas the govt mandated is messed up stuff that leaves behind crud everywhere
the computer can adjust "so that vehicle operation seems smoother and more seamless"
that says SEEMS-as in passenger comfort,,,
not, makes cars run as good as new regarless of plug age,,,
Seems to me thats masking the symptoms, thats like saying
Take a pill for that nail in your head Sir lol
Old spark plug wires have more resistance to electrical flow thru them- reduces amount energy to the plug so it fires weaker spark in the combustion chamber,
Less explosive than original spec means less torque generated from the expanding gasses pushing the piston down and the crackshaft to rotate
Means more partially unburnt fuel exiting the exhaust in the atmosphere
True- we have coil on plug with the TL which is very hi energy and doesnt require any 25 dollar plus with extra capawigawatz capability from built in capacitor--they have been tried and same 1mpg improvement any TL gets with new NGK plugs at 60-70k miles
Stick with NGK Iridium like the factory has used for DECADES on these cars
platinum was the gen1 and 2 spec because thats what was available-
iridium became more readily available when plans for gen3 made, and gets it
01tl4tl is offline
Old 08-15-2009, 5:00 PM   #14
Turbonut
Trader Rating: (1)
Activity: 14.4%
Here's something directly from Magnecore:
Despite what is published in advertisements and some vested interest magazine articles, no spark plug wires will generate or "install" additional horsepower, unless the wire has failed, or has failing components. It's the same concept as the plugs. If operating properly, new parts will not change the performance, regardless of the age or mileage.
Yup, Seafoam is Magic Potion in a bottle. Itís certainly amazing how vehicles that have never seen the stuff can go hundreds of thousands of miles and still operate like new. I also wonder how they claim additional fuel mileage and performance after cleaning as even with a clogged air filter the fuel mileage doesn't change, so how can running the stuff through the engine increase fuel mileage. Wishfull thinking.
We're off target from the OP.
Turbonut is offline
Old 08-17-2009, 1:49 PM   #15
Majofo
Wishes he owned a..
2012 Nissan GT-R
Majofo's Avatar
koobecaf rettiwt nideknil $2PlayNay NSP
Points: 29,814, Level: 99
Points: 29,814, Level: 99 Points: 29,814, Level: 99 Points: 29,814, Level: 99
Activity: 99.6%
Activity: 99.6% Activity: 99.6% Activity: 99.6%
:threadclosed:
Majofo is offline
Old 08-17-2009, 2:07 PM   #16
candrews
2008 Acura TL
candrews's Avatar
Points: 6,354, Level: 52
Points: 6,354, Level: 52 Points: 6,354, Level: 52 Points: 6,354, Level: 52
Activity: 0.7%
...are we to assume that your daughter drives her Maxima as hard as I/we tend to drive our TL'S? For only $20 I'll buy the better plugs and change them at 60K as well...
candrews is offline
Old 08-17-2009, 2:10 PM   #17
csmeance
2006 BMW 7-Series
My Garage
csmeance's Avatar
I facetube, I think! Is it twitting? Twittering? Darn it! Linked-Out csmeance :idontlikemyinfostolen:
Points: 42,036, Level: 100
Points: 42,036, Level: 100 Points: 42,036, Level: 100 Points: 42,036, Level: 100
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
lMud-Guardsl426WHP/430WTQ V12l
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
csmeance is offline
Closed Thread
car, compare, for, iridium, ix, izfr6k11, laser, life, mileage, ngk, platinum, plug, plugs, spark, zfr6fix11
