04 tl wont keep charge in battery.
Old 08-03-2009, 05:05 AM
lilsoldier1's Avatar
My car has ran great since today but today i went to get something to eat an it wouldnt start the lights were flickering an the dashboard would try to start but was just a brim light. i then got somebody to jump my car it of course it starts... then we take the cables off again no charge... put the cables back on the lights radio etc come on but the car will not crank do you guys think this is a died battery or the alternator.? please help
Old 08-03-2009, 05:12 AM
The Dumb One
Rockstar21's Avatar
hopefully just a dead battery... you should take the battery to get tested.
also.. welcome to Acurazine. you are in the 2nd Gen forums (99-03).. your 04 TL belongs in the 3rd Gen Forums(04-08).. they can probably get to the root of your problems a bit quicker then we can.
Old 08-03-2009, 09:02 AM
LoveMyTL-S's Avatar
Probably a battery. The batteries Acura uses are nortorious for failing. Like was mentioned above, I'd get the battery tested.
Old 08-03-2009, 09:06 AM
Retired!!! ON TOP!!!
rodneyc77's Avatar
it's probably the HFL sucking the battery dead...
Old 08-03-2009, 09:38 AM
1fsthatch's Avatar
alternator
Old 08-03-2009, 09:40 AM
DaddysOnehotAck's Avatar
Yeah its the battery,I had the same problem,the dealer switch it out twice.....also the 04-05 TL's the navi drains the battery a whole lot quicker! Anyways brought a premium battery from Autozone and haven't had a problem since!
Old 08-03-2009, 11:14 AM
Tripnbeats's Avatar
new battery n get the computers updated there were some updates that shut down some of the power drain sources that werent needed.
Old 08-03-2009, 12:56 PM
john151305's Avatar
The dealer has checked it twice and can't find a drain when the symptoms (no outside temp and no phone icon) aren't present. It happened with a new batery and they claim to have checked both the alternator as well as all the things that draw down the current
after you shut the key off.
I haven't been able to get it to the dealer when the symptoms occur -2 hrs away.
Old 08-03-2009, 01:21 PM
LoveMyTL-S's Avatar
Do you know if they checked the HFL? Here is the TSB:
http://www.in.honda.com/rjanisis/pubs/SB/B08-057.pdf
Old 08-03-2009, 02:23 PM
john151305's Avatar
They said they checked it. The TSB referres to 07 and 08. TSB 05-029 describes my symptoms exactly, but only apples to the 05 model. My habd free link does work, it is just the icon that disappears
MetalGearTypeS
08-29-2016 08:28 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
iesu3423
09-29-2015 08:04 AM
navtool.com
09-25-2015 05:15 PM
Quick Reply: 04 tl wont keep charge in battery.
