TL: Need to swap factory Bose amp with high power aftermarket...
I would like to install an upgraded 4 channel amp in my 03 TL for the 4 voice speakers (already upgraded them to Infiniti Kappas). Since the Bose Amp is in the trunk, it shouldn't be too hard to connect the new amp without running all new wires since all of the wires I need (except power for the new amp) run in and out of it.
Does anyone know where I can get either: 1) A free copy of a wiring diagram for the factory Bose amp or 2) a wiring harness that will allow me to plug the new amp into the factory leads for the Bose amp? Thanks!
Not sure if this will help.....
Heres a link to another site that says they are free. May have to email them..... http://www.modifiedlife.com/2003-acu...iring-diagram/
Acura Car Radio Stereo Audio Wiring Diagram Autoradio connector wire installation schematic schema esquema de conexiones stecker konektor connecteur cable shema
1-Speaker RF+
8 -Speaker RR+
2-Speaker LF+
9 -Speaker RF-
3-Dash Light Dimmer Wire
10-Speaker LF-
4-ВAT+
11-Mute
5-+12 VOLT IGNITION WIRE
14-Gnd
6-Power Antenna Turn On
15-Speaker LR-
7-Speaker LR+
16-Speaker RR-
ACURA FX-MG6006 ZH
ACURA MU920A0 (Japan)
2003 Acura TL Car Radio Stereo Wiring DiagramCar Radio Constant 12v+ Wire: White/Green
Car Radio Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow/White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Car radio Model autoradio Manufacturer
MCU
EEPROM
Car
ACURA
MATSUSHITA
ACURA
1102
MATSUSHITA
D75116GFA 911
93C46
ACURA
1106 39100-SM4-A312-M1
MATSUSHITA
D17005GF 902
93LC46 smd
ACURA
1107
MATSUSHITA
ACURA
1108
MATSUSHITA
D17010GF 908
93LC46 smd
ACURA
2TB0 BOSE MT939A0
ALPINE
ACURA
3403 KEH-M7036ZM
PIONEER
PD4432A
P2100
ACURA
BOSE 2100 CM-3929
ALPINE
51T25615W03
ACURA
BOSE 2200 CM-6913
ALPINE
51T25615W03
ACURA
CD
MATSUSHITA
ACURA
CD
MATSUSHITA
ACURA
CD
MATSUSHITA
ACURA
CM 3919 2DIN
ALPINE
51T25615W03 or 01
ACURA
CM 3929
ALPINE
ACURA
CM 839R0
ALPINE
24C01
ACURA
CM 936C0
ALPINE
ACURA
CM 939C0
ALPINE
51T5571W02
24C01
ACURA
CM 940A0
ALPINE
ACURA
MT939C0
ALPINE
ACURA
MU920A0
ACURA
FX MG6006ZH BOSE changer 6 CD
PIONEER
PE5170A 78055A52
BR9010 smd
ACURA
1TJ2 BOSE 6CD
MATSUSHITA
C2CBHG000069
ACURA
1-Speaker RF+
8 -Speaker RR+
2-Speaker LF+
9 -Speaker RF-
10-Speaker LF-
4-ВAT+
11-Mute
14-Gnd
15-Speaker LR-
7-Speaker LR+
16-Speaker RR-
MCU
EEPROM
IC Amplifier
CD changer
ACURA
MATSUSHITA
ACURA
1102
MATSUSHITA
D75116GFA 911
93C46
ACURA
MATSUSHITA
D17005GF 902
93LC46 smd
ACURA
1107
MATSUSHITA
ACURA
1108
MATSUSHITA
D17010GF 908
93LC46 smd
ACURA
2TB0 BOSE MT939A0
ALPINE
ACURA
3403 KEH-M7036ZM
PIONEER
PD4432A
P2100
ACURA
BOSE 2100 CM-3929
ALPINE
51T25615W03
ACURA
BOSE 2200 CM-6913
ALPINE
51T25615W03
2xTA8210L
ACURA
CD
MATSUSHITA
ACURA
CD
MATSUSHITA
ACURA
CD
MATSUSHITA
ACURA
CM 3919 2DIN
ALPINE
51T25615W03 or 01
ACURA
CM 3929
ALPINE
ACURA
CM 839R0
ALPINE
24C01
ACURA
CM 936C0
ALPINE
ACURA
CM 939C0
ALPINE
51T5571W02
24C01
ACURA
CM 940A0
ALPINE
ACURA
MT939C0
ALPINE
ACURA
MU920A0
ACURA
PIONEER
PE5170A 78055A52
BR9010 smd
ACURA
1TJ2 BOSE 6CD
MATSUSHITA
C2CBHG000069
NEMA
Wow... This section of the forum is getting more and more retarded the more noobs we get... Read before posting people...
OP, I highly doubt you'll be able to find a plug and play harness to connect an aftermarket amp into the signal leads for the Bose amp... With that being said, I wouldn't send more than say 20w through the factory speaker wire... So if you're going to amp your kappas with proper power for them, it'll be better to run all new speaker wire... Just do it right, and run new wire...
As for your second question about something that will allow you to plug the amp right to the factory speaker wires (from the HU), if you get an amp with speaker level inputs, you should be alright. Or you could buy something like a Rockford Fosgate ThreeSixty.2 and get RCA's out of that, and connect those to an amp to get your signal. Your call there...
20 watts of power if you have a high pass crossover is a ton of sound. It doesn't take much power to get loud volume from mids and tweets.
Bass drivers (mid-bass and certainly subs) need the higher amp / wattage systems.
Not a bad idea to replace stock wires w/ new ones, but you'll get plenty of good sound from the stock wire when they are crossed at ~120hz and up.
TLDude876
12-28-2016 03:18 PM
12-13-2015 02:21 PM
handsom-hustla
11-13-2015 05:04 PM
09-15-2015 06:44 PM
