Car pulls to the side after tire rotation
Old 04-30-2009, 08:08 AM
Kostyan's Avatar
I have 32K on original Michelin tires, the fronts worn on the sides, and rear had plenty of thread. After rotating the tires a couple of weekends ago (merely put fronts to back, and vice versa), my car started pulling to the side, and I am getting some sort of vibration from the right front. Is there an explanation for this?
Old 04-30-2009, 08:09 AM
TeknoKing's Avatar
It could be just as simple as the wheel balance..maybe the weight flew off, or it could a bad rim. How is the tire itself?
Old 04-30-2009, 08:19 AM
Kostyan's Avatar
the tire is in perfect condition, with about 70% tread left- it was prev mounted in the rear
about six months ago, the dealer did a 3rd gear tranny fix, and tech had to do an alignment after taking out the tranny. The car did not pull to the side after that...How can rotating the tires for 1st time at 30k mi cause the car to start pulling to the side?
Old 04-30-2009, 08:24 AM
TeknoKing's Avatar
I have no clue, it really shouldn't pull at all.. is the wheel balance weight there? Is the rim sitting in properly? I know these are all common sense things, but you never know, we all make little mistakes. Just recheck.
I don't see how rotating tires can throw car off it's alignment.
Old 04-30-2009, 08:28 AM
Kostyan's Avatar
all weights are there...rim sitting mproperly otherwise it would not mount right....tire pressure is all equal.
Old 04-30-2009, 09:59 AM
NTMD8
jimsta's Avatar
I had the same problem when i changed my rims on my TL, after reading a bit online. It is possible that this can be due to uneven tire wear as well, or manufacturer tire defect. After posting in the problems/fixes review and reading the resposnes there I decided to check tire rack as well.
http://www.tirerack.com/tires/tirete....jsp?techid=12
Old 04-30-2009, 03:16 PM
Kostyan's Avatar
this is a great article, thanks for posting it here! This indeed will help me diagnose the cause.
Old 04-30-2009, 07:35 PM
gsr3gp's Avatar
its most likely a tire pull, i have seen this happen many times after a tire rotation...just cross rotate the front tires and this usually straightens it out or just causes it to pull the opposite way
Heyzuez20
10-14-2015 07:18 AM
GhostTL09
09-19-2015 01:57 PM
Phambam12
09-06-2015 06:57 PM
Zonian22
09-02-2015 08:19 AM
emsrph
08-31-2015 10:28 AM
Quick Reply: Car pulls to the side after tire rotation
