Cruise control not working?? - AcuraZine Community
Old 02-20-2009, 11:11 AM   #1
CHiNaMaN440
04 "NBP TL" 6mt
2004 Acura TL
CHiNaMaN440's Avatar
Trader Rating: (1)
Ealier this week, my cruise control stopped working when I tried using it. When I press the button, it illuminates on the gauge cluster. But when I try setting it, nothing happens.
Any ideas?
CHiNaMaN440 is offline   Reply With Quote
Old 02-20-2009, 11:14 AM   #2
RACINGHART03
RACINGHART03's Avatar
Trader Rating: (2)
Points: 8,821, Level: 63
Points: 8,821, Level: 63 Points: 8,821, Level: 63 Points: 8,821, Level: 63
Had any work done on your car recently? Do your brake lights work?
2008 Tl Type S Auto, All bottle no throttle! Zex wet set up, Richie V6 from heads to Comptech Cat back, Big bore T/B w/ported and polished intake, Injen CAI = 308WHP/265TQ... R.I.P TL. Needed a truck. Now I am driving a 2010 Advanced MDX. Black on black. Boring...but functional...http://www.youtube.com/watch?v=vCiNiYrI8GY
RACINGHART03 is offline   Reply With Quote
Old 02-20-2009, 11:18 AM   #3
CHiNaMaN440
04 "NBP TL" 6mt
2004 Acura TL
Trader Rating: (1)
ummm I did the accord fog light mod Tuesday. But it stopped working Monday
I have to check if my brake lights are working or not
Old 02-20-2009, 11:20 AM   #4
CHiNaMaN440
04 "NBP TL" 6mt
2004 Acura TL
Trader Rating: (1)
I forgot I swapped out my base tails for type s tails Sunday. But that's pretty much plug and play
Old 02-20-2009, 11:25 AM   #5
RACINGHART03
Trader Rating: (2)
Basically the light on the dash tells you the system is ready. Its the input from the "set" switch that activates it. The brake light circuit plays a role though which is why I ask.
Old 02-20-2009, 11:27 AM   #6
CHiNaMaN440
04 "NBP TL" 6mt
2004 Acura TL
Trader Rating: (1)
ok, so what do I need to do? check my fuses?
Old 02-20-2009, 11:48 AM   #7
RACINGHART03
Trader Rating: (2)
If the brake lights dont work its a good place to start. Still gathering info.
Old 02-20-2009, 12:05 PM   #8
CHiNaMaN440
04 "NBP TL" 6mt
2004 Acura TL
Trader Rating: (1)
ok, I just checked my brake lights and looks like there all working.
Any other ideas?
Old 02-20-2009, 12:34 PM   #9
RACINGHART03
Trader Rating: (2)
Any work performed on the car other than what you did?
Old 02-20-2009, 3:03 PM   #10
Fulani has a TL
Fulani has a TL's Avatar
Trader Rating: (1)
Points: 9,716, Level: 66
Points: 9,716, Level: 66 Points: 9,716, Level: 66 Points: 9,716, Level: 66
I remember I had a similar problem when I installed gas and brake pedals from SuperComputers. My cruise would set, and then would randomly disengage. It took a few days and then it stopped doing that. Possible some pressure being applied to the gas pedal?
Fulani has a TL is offline   Reply With Quote
Old 02-20-2009, 3:20 PM   #11
RACINGHART03
Trader Rating: (2)
Totally understandable. The cruise will not turn on/disengage if it detects the slightest ON signal from the brake switch. The weight of the brake pedal was probably pulling it down the slightest bit which would prevent the cc from setting or causing it to cancel. Good post by the way. Just made me realize I should have suggested to the OP to adjust his brake switch. So there. Do that.
Old 02-20-2009, 11:17 PM   #12
CHiNaMaN440
04 "NBP TL" 6mt
2004 Acura TL
Trader Rating: (1)
I did, nothing
any other ideas on what it could be?
Old 02-21-2009, 7:52 AM   #13
RACINGHART03
Trader Rating: (2)
Yes try and adjusting your brake pedal switch. Its an easy DIY.
Old 07-13-2009, 5:45 AM   #14
gatrhumpy
Chapter Leader
(Northeast Florida)
2008 Acura TL Type S
gatrhumpy's Avatar
I have an Accord, but the same problem still applies.
I have a slightly different problem. The Cruise Control light is on, telling me the system is armed and ready to be set. Whenever I press the set button, nothing happens. The "Cruise" does not come on, the cruise control does not set, etc. The brake lights all come on, and the fuses are all OK.
I don't understand what happened. It just went out. I have done no work to my car in a long time.
I'm an engeneer. Damn!
I'm an enginere. Shit!
I'm an engenere. Crap!
I'm good with math.
gatrhumpy is online now   Reply With Quote
Old 07-13-2009, 10:23 AM   #15
zsameer
2005 ACURA TL
zsameer's Avatar
Points: 5,565, Level: 48
Points: 5,565, Level: 48 Points: 5,565, Level: 48 Points: 5,565, Level: 48
Activity: 2.9%
Activity: 2.9% Activity: 2.9% Activity: 2.9%
Maye be you crimped your led unit wires while running them through the housing. might want to check since i had a cruise problem caused by that.
http://tl.acurazine.com/forums/showthread.php?t=733926
zsameer is offline   Reply With Quote
Old 07-13-2009, 12:04 PM   #16
gatrhumpy
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
BTW, my cruise decided to bless me by working again. That was weird...
I'm good with math.
Old 10-13-2010, 10:12 AM   #17
Parcus
New Member
I cannot get my cruise control master switch to engage. When I press it and hold it in it works perfect, but the second I let go it turns off. Is there an easy way to replace this switch. The dealer is telling me it will cost over $240 labor because of the airbag.
Parcus is offline   Reply With Quote
Old 10-13-2010, 11:58 AM   #18
nfnsquared
nfnsquared's Avatar
Points: 14,436, Level: 77
Points: 14,436, Level: 77 Points: 14,436, Level: 77 Points: 14,436, Level: 77
Activity: 10.6%
Activity: 10.6% Activity: 10.6% Activity: 10.6%
It's probably a bad switch. It's been known to fail.
You can do it yourself, but you'll need a Torx T30 bit and a 3/8" driver/ratchet. Look in the 3G Service Department under "lighting". There are scans on how to remove the airbag. Basically, it's just two Torx T30 screws, but they can be tough to remove if you don't use the appropriate sized ratchet because they are held in with Loctite. That's the reason you need a 3/8" driver/ratchet. Don't use a 1/4" ratchet.
If you're the least bit mechanically inclined, don't pay the dealer to do this...the switch only costs about $55. Contact Kaleb at Prestige Acura (use the Vendor link at the top of the page) to order the part.
Edit: Here's a couple of links:
http://tl.acurazine.com/forums/showthread.php?t=606220
http://tl.acurazine.com/forums/showthread.php?t=763962
04 6MT, Navi, WDP, chrome wheels, Clifford Matrix 50.7X RS/Alarm, Huper Optik ceramic tints
nfnsquared is offline   Reply With Quote
2009, accord, acura, adjust, brake, control, cruise, disengages, honda, light, problem, randomly, stopped, tl, working
