Floor jack lifting points
Old 01-06-2009, 01:54 PM
MikeVR6's Avatar
Looks like the search is down, because I cannot pull up any search term with it.
In any case, I need to lift the front/rear ends of a 01 3.2TL. Are there designated lift points that I can use with a floor jack to lift the whole front or rear end of the car up?
Thanks,
Mike
Old 01-06-2009, 02:10 PM
bringin lead
FirePR2002's Avatar
i use the tow hooks for the rear and sometimes front. will the jack points on the sides not work for you?
Old 01-06-2009, 03:01 PM
jayunsplanet's Avatar
Feel under the sides of your car for "tabs". They hang down about 1 inch. They clear the body kit (if you have one... )
[Or, they could be like mine and be bent over and pointless now *tear*. In which case you need a block of 2x4 to space it out.]
I can't get a normal jack under the front or the sides
Old 01-06-2009, 04:04 PM
bringin lead
FirePR2002's Avatar
^^i can't either - had to get a low profile jack after the drop.
Old 01-06-2009, 04:07 PM
How much was yours? Link?
Someone suggested one to me and it was $179
It would be nice to not have to drive up on wood to get my jack underneath.
Old 01-06-2009, 04:11 PM
bringin lead
FirePR2002's Avatar
i think i paid between $100 - $125 at northern tool (check online also).
here is a pic of the one I got:
Old 01-06-2009, 04:13 PM
bringin lead
FirePR2002's Avatar
it must have been on sale - here's a link at $129:
http://www.northerntool.com/webapp/w...3500_200313500
Old 01-06-2009, 04:33 PM
MikeVR6's Avatar
thanks for the replies, all. On other cars I typically I lift the entire front from a central jacking point, and then slip the jack stands under those "lips" just rear of the front tires.
This is the most stable way to keep the front of the car off the ground evenly. Does the TL have such a central lift point up front?
Old 01-06-2009, 04:36 PM
bringin lead
FirePR2002's Avatar
did you miss this post - hahahaha?
use the tow hook up front to raise it up, then slide the jackstands under the sides or wherever you need them.
Old 01-06-2009, 04:41 PM
spaz
tegkid's Avatar
^^^thats what i do too.
except add a step where i have to drive up on blocks of concrete so the jack fits.
i'm ok w/doing that rather than spending 150 on a low pro jack.
Old 01-06-2009, 04:43 PM
MikeVR6's Avatar
I sure did! I am losing my mind today
Thanks, I'll check it out. On lighter cars like Civics and my older Accord, etc, I am less concerned about lifting from the towhook. I'll try that out. I'm doing some work on a neighbor's car which is the reason I was asking ahead of time. Thanks for the help!
Any ideas why the search here is acting up?
Old 01-06-2009, 04:46 PM
bringin lead
FirePR2002's Avatar
search has been messed up ever since the conversion and upgrade of the software.
i've used that tow hook to raise the entire car (front and back with jackstands on the sides for stability) for hours without any issues. good luck!
Old 01-06-2009, 04:58 PM
Lamborghini Aventador FTW
AMGala's Avatar
There is one jacking point under the front end of the car, between the two wheels. You'll see a little bump there where you can lift from. Other than that, there are two mounting tabs on each side, one near the front wheel and one near the back wheel.
Be careful when using the rear tow hook, if the jack ever slips or the metal somehow bends there, you can puncture your gas tank.
If you can get your car onto a lift you can actually hammer the tabs back into the correct position. I had to do that twice already.
Old 01-06-2009, 06:05 PM
Received 1,731 Likes on 1,389 Posts
The Helms service manual for the CL has an illustration that designates the center of the front cross member ('...front jacking bracket...') as the floor jack support point.
If you literally go to the front middle of the car and follow the center line (underneath) back slightly, you will see a 'bulge' in the cross member. It has a hole present for drainage. You will see it easily, that is the 'front jacking bracket' for a floor jack.
At the #11 in this link.
If I did not suck at the interweb I would post the actual manual diagram.
Old 01-06-2009, 06:08 PM
How are you going to puncture the gas tank from there??? The gas tank is under the rear seat. If it were to come off the rear hook it would only dent the spare tire well.
Old 01-06-2009, 06:33 PM
School or Mods???
2000DEP's Avatar
get a ramp...i've got one from schucks for less than $40...
it's designed to work with lowered cars and it supports up 8,000 lbs
it's safe and cheaper way to go...
you can ask them for clearance of the ramps if you are lowered...
but i don't know how high you want it to be...i only got it for oil changes...
Old 01-06-2009, 09:29 PM
AMGala's Avatar
Freak accidents can happen. I'm just saying, be careful lifting from a point that wasn't necessarily designed to do so
Old 01-06-2009, 11:30 PM
AZ Community Team
Bearcat94's Avatar
So you're saying the Rear Tow hook is not designed to be a lift point on the 2G, even though it *is* a lift point on the 3G? Why would they do that?
ALWAYS use Jack Stands.
OP - Floor Jack points on the 2G are the same. I know, I've got one of each.
Old 01-07-2009, 07:01 AM
Its a designed lift point. (though any one using a jack with a 1.5" lifting pad is just asking for trouble)
Oh and it would have to be more than a freak accident to fall off and hit the gas tank.
Old 01-07-2009, 03:32 PM
AMGala's Avatar
Well ya learn something new every day! I didn't know it was a designed lift point. Thanks for the correction Kris.
Old 01-07-2009, 04:27 PM
Old 01-07-2009, 05:48 PM
2G wanting 3G
9932's Avatar
Old 01-08-2009, 07:06 PM
YoungatHeart
kaptainjack's Avatar
Hello all....was reading this post yesterday and think this floor jack might have been referenced...just got an email from Northern and this seems like a good price...hope it's not too late to be of help...Happy new year to all......
http://www.northerntool.com/webapp/w...te=NY&hotline=
Old 09-22-2016, 09:42 PM
Dnwin's Avatar
Sorry to b ring up this thread again. Did anyone have a problem lifting it up fromt he rear tow hook? It doesnt raise enough for me to put jack stands under.. My jack is from harbor freight and raises 20 inches... Is anyone else having the same problem?
Old 09-22-2016, 10:41 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Sounds like a jack problem.
If you can't get it up enough when you jack it, you might need a helper.
Do you think another 4-inches would help get you there? You could try using a piece of 4x4 lumber between the jack pad and the tow hook to get it up a little bit more.
Old 09-22-2016, 10:44 PM
Received 8,568 Likes on 6,621 Posts
Poor Jack...
Old 09-23-2016, 08:19 AM
Dnwin's Avatar
How high does your Jack normally go?? And yeah I tried the 4x4 to.. I tried with two diff harbor freight Jack .., so everyone jacks the rear okay??
Old 09-23-2016, 11:14 AM
SuperGreg's Avatar
Yeah the smaller floor jacks won't get the car up high enough in the rear to get jack stands in place. I've got this one, works great: ACDelco 34700 - Garage Jack | O'Reilly Auto Parts
I got it when they had a sale for $149.
Old 09-23-2016, 11:22 AM
cu2wagon's Avatar
I've got a 3.5 ton jack that maxes out at about 22".
It works fine to get the car up but I can only use one set of stands with it. I have a larger set of stands that are too tall even on the lowest setting so they're no go. I have a shorter set that I can only use up to about the second setting. Any higher and I'd need some sort of helper.
Old 09-23-2016, 11:29 AM
i find that if i'm jacking up all 4 corners, i have to raise the rear first, or else my harbor freight low pro jack wont raise it high enough.
and if i forget and raise the front first, i just use a helper block to help raise the rear high enough
Mike734
12-10-2021 01:25 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
JDM96specCTR
10-17-2015 01:06 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Floor jack lifting points
