Reset hands free link - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL Community > Third Generation TL (2004-2008) > Audio, Bluetooth, Electronics & Navigation
Old 11-25-2008, 12:58 PM   #1
tech_rcd
Points: 3,319, Level: 35
Points: 3,319, Level: 35 Points: 3,319, Level: 35 Points: 3,319, Level: 35
I recently purchased a 2006 TL. When I tried to set up the hands free link it said it was locked and asked for the 4 digit code. Of course I did not have it. I was told that I would have to take it to the dealership to have it reset. I live a 100 miles from a dealer. I called the dealer where I had taken it in for the power steering recall. He told me a way to do it myself.
Disconect both battery cables and touch them to each other for 20 seconds. This resets everything. You will need your radio code to get the radio back working.
It worked just fine. Everything was exactly as he said it would be.
Just wanted to share that with everyone.
tech_rcd is offline   Reply With Quote
Old 11-25-2008, 1:55 PM   #2
PeterUbers
Trader Rating: (1)
excellent work, and congrats -- this should be a sticky!
2004 TL (SSM), 5AT, non-navi Gone!
2009 G37xS, 7AT, navi/prem, platinum
PeterUbers is offline   Reply With Quote
The Following User Says Thank You to PeterUbers For This Useful Post:
Lester86 (01-29-2013)
Old 11-26-2008, 3:11 AM   #3
Tolik
Tolik's Avatar
Points: 2,641, Level: 31
Points: 2,641, Level: 31 Points: 2,641, Level: 31 Points: 2,641, Level: 31
Activity: 1.0%
ok i have same problem are you sure that is safe to do that
Tolik is offline   Reply With Quote
Old 11-26-2008, 1:07 PM   #4
Jbenfrank
Points: 4,999, Level: 45
Points: 4,999, Level: 45 Points: 4,999, Level: 45 Points: 4,999, Level: 45
Activity: 0.1%
I have the same issue with my 06 tl, but I want to be sure that this is a good idea. I always thought it would be bad to let those two cables touch eachother. Can someone confirm that this will indeed work? I set up an appointment with acura to reset it for me in 1 week, but I would be much happier resolving the issue myself. Thanks so much for the tip Tech
Jbenfrank is offline   Reply With Quote
Old 11-26-2008, 1:41 PM   #5
Jbenfrank
Activity: 0.1%
I just called my local acura dealer to confirm if this would work and they said yes! I believe this is the way the dealer does it, yet they charge $50! Thanks tech, Ill be trying this as soon as i get home. By the way Tech, if you edit the title of this thread to spell reset instead of re-set, people will be able to find this solution much easier.
Old 11-26-2008, 2:09 PM   #6
tech_rcd
Thanks for tip Jbenfrank. I will try to fix that.
Make sure both battery cables are not hooked up to the battery. Remember this resets everything and you must have your radio code to get your radio working again.
Good luck.
Old 11-26-2008, 2:14 PM   #7
tech_rcd
Can I edit the title? The edit button is gone?
Old 11-26-2008, 2:40 PM   #8
Timeless
Timeless's Avatar
Points: 6,075, Level: 50
Points: 6,075, Level: 50 Points: 6,075, Level: 50 Points: 6,075, Level: 50
Activity: 4.4%
Activity: 4.4% Activity: 4.4% Activity: 4.4%
Wow, this might be a life saver. I'm going to give it a shot....
Timeless is offline   Reply With Quote
Old 11-26-2008, 3:03 PM   #9
Timeless
Timeless's Avatar
Activity: 4.4%
didn't work......could it be because I have navi?
Old 11-26-2008, 5:05 PM   #10
Jbenfrank
Activity: 0.1%
I just tried and it didnt work! I also have navi, so maybe thats why? I decided to leave them connected for a longer period of time to see if that will do it, theyre connected as i speak. Ill give it a half hour and let u guys know if it worked
Old 11-27-2008, 9:20 AM   #11
Jbenfrank
Activity: 0.1%
I tried connecting them for a longer period of time (half hour), and it still didnt work. I guess this only works with non-navi models. Guess Ill be handing over my $50 to acura after all!
Old 11-28-2008, 8:47 AM   #12
tech_rcd
I don't have Navi and it worked for me. Sorry i did not post that initially.
Old 11-28-2008, 12:11 PM   #13
Timeless
Timeless's Avatar
Activity: 4.4%
Would it be possible to pull the fuse for the navi...where ever it may be and then try this? Any one know if it might do the trick then?
Old 11-28-2008, 2:12 PM   #14
1995hoo
Keep Right Except to Pass
1995hoo's Avatar
Points: 11,863, Level: 71
Points: 11,863, Level: 71 Points: 11,863, Level: 71 Points: 11,863, Level: 71
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
The moderators have the board set up to remove the ability to edit a post after five minutes have past since it was posted. I've never known why they did it that way, but it's how it is.
1995hoo is offline   Reply With Quote
Old 01-27-2009, 8:48 PM   #15
Xpditor
2004 Acura TL
Xpditor's Avatar
Points: 42,226, Level: 100
Points: 42,226, Level: 100 Points: 42,226, Level: 100 Points: 42,226, Level: 100
Activity: 0.9%
We have our reasons.
But I have fixed it for you.
Dave
Xpditor is offline   Reply With Quote
Old 03-12-2010, 7:38 AM   #16
mellow69
New Member
i recently purchace a 2007 MDX, hand free link is locked, are you sure touching the two cable will work for my suv.
mellow69 is offline   Reply With Quote
Old 07-31-2011, 11:47 AM   #17
cjj2d
Points: 4,110, Level: 40
Points: 4,110, Level: 40 Points: 4,110, Level: 40 Points: 4,110, Level: 40
tried this on my 06 TL, did not work. still "booting up".
cjj2d is offline   Reply With Quote
Old 07-31-2011, 5:03 PM   #18
LawnPro
Scott
LawnPro's Avatar
Points: 3,801, Level: 39
Points: 3,801, Level: 39 Points: 3,801, Level: 39 Points: 3,801, Level: 39
Activity: 0.9%
My dealer was nice enough to print out directions to reset my hfl, but when I got home and tried the reset, nothing happened. I don't know. Maybe that's his way of telling me to make a service appointment?
LawnPro is offline   Reply With Quote
07, 2006, 2007, acura, code, device, free, hands, handsfree, handsfreelink, link, locked, navi, reset, tl, tsx
