DIY Timing Belt - AcuraZine Community
Old 11-10-2008, 12:32 AM   #1
MotionEffects
Acura TLS are SLOW
MotionEffects's Avatar
Points: 13,936, Level: 76
Points: 13,936, Level: 76 Points: 13,936, Level: 76 Points: 13,936, Level: 76
DIY Timing Belt
Did my timing belt after 120k. I Got the Timing belt, Ps belt, AC belt, Water Pump, Tensioner, Idler, and the adjuster pulley. This is my first time doing a timing belt on any car and it took a long time (5 hours). I could of done it faster but I was taking pictures and didnt have the battery tie down as that is a very important tool. I think I can do one now in about 2 hours. Here is a DIY. This isnt the best write up due to the pics and I did this at work after working on cars for the past 9 hours(was really beat). Overall, this was a easy job. From a scale of 1 to 10, I rate this about 3. The hardest part was removing all the bolts for the timing cover due to the limited amount of room.
List of tools you will need
-Crank Holder
-Impact Gun
-Serpentine belt tool
-Battery Tie down tool
-Lots of different sockets, swivels,extensions,wrenches, etc
-Jack+Block of wood
I AM NOT RESPONSIBLE FOR ANY DAMAGE DONE TO YOUR ENGINE. Proceed at your own will.
Removal
1.Turn the crank to make sure your Timing marks line up. Front Cam, Rear Cam, And Crank Mark. ( No pics for the rear cam-You need a mirror to see the timing mark.)
Front cam timing mark
Crank Timing mark-Look for a White dot & Arrow on the timing cover. They should line up
2.Remove Right front Wheel and Under panel
3.Move Auto tensioner and remove Alternator/AC belt
Use a serpentine belt tool. If you dont have one use a 14mm wrench but be careful since there is a lot of tension on that
4.Loosen the PS pump nuts. One is hidden behind the pulley. There is a total of 3 nuts. Remove belt. Note-I would recommend un-doing the hose clamp and move the pump out of your way IF you have bought PS fluid.
5.Support the motor with a floor jack and block of wood under the oil pan.
6.Remove the engine side mount.
7. Remove the oil dip stick tube by undoing the 10mm bolt. (new o-ring for dipstick tube is recommended)
8.Remove the crank bolt (19mm socket) with impact tool. Before you remove the crank, Re-check ALL your Timing Marks to make sure they are align.
Kinda Surprise that the crappy husky gun removed the bolt.
9.Remove all the Timing cover bolt, starting with the front, rear, and lower. This is the most frustrating part due to lack of room.
9a. I do this "just in case" If I screw up. Mark your Cam gears with white paint.
10. I dont have a Pic for this Due to the lack of room for me to fit my Camera (DSLR). You need to remove one of your battery tie down bar. Use the tie down bar and screw it in a bracket to push the Timing Belt Adjuster pulley in to release the tension on the timing belt. Sorry, that is the best i can explain it. If you dont have the tie down like me, Your gonna have a hell of a time to relieve the tension on that.
11.Remove the Engine Side Mount Bracket.
12.Loosen the Idler pulley and remove the belt.
13. Remove and replace water pump.
(Forgot to take a pic of the water pump so i have to re-use a pic, Notice the belt if not off of the pic when it is supposed to be)
14. Remove battery tie down and remove adjuster.
Everthing removed
Tensioner Looks good
The belt could of lasted another 20k
Idler pulley looks good
Adjuster pulley looks good
Install..........
I dont really have pics for install since its really just a reverse of everything.
1.Install timing tensioner, but do not remove the pin. Install the battery tie down tool.(If you re-use the old tension, You need to put it in a vice and compress the tensioner.)
2. Install the timing belt COUNTER-Clockwise starting with crank gear working your way up the to front cam gear around idler pulley and into rear cam gear. AND MAKE SURE ALL THE BELT SLACKS ARE AT THE TENSIONER!!! There should be no slacks or play between the cam gears or crank and cam gear. Note-If your belt dont line up with the cam gears, Dont worry, Move the cam gear very slightly(were talking about a .1 mm NOT A TOOTH).
3. I can't stress enough on how important it is to make sure there are no belt slacks between the cam gears and crank gears. Double Check your Belt BEFORE you remove the pin to the tensioner. Pull the pin when your ready Remove battery tie down tool.
4. Check your timing mark to make sure they are correct. Install the crank and bolt(no need to tighten the crank bolt). Turn the Engine over a few times by putting a 19 mm socket+ratchet.
5. If they are, your good. Install everything in reverse order,
If not, start over from step 10 of removal process.
Remember to do your cooling system flush.
Good luck
Feel free to chime in if I forgot something
02 TL-S Non-Navi
Oem Body Kit
OEM Spoiler
H&R Springs+Koni Yellow,<-----Taken Off as of 10/8/06
Comptech Sway Bars
NEUSPEED Strut Bar
Cusco Lower Tie Bar
19" 5Zigen Evo w/ 225/35/19 Toyo Proxes<-----Cracked 3/05
Rotora Rotors w/ EBC Greens
OBX Headers <-----Taken off as of 11/29/04
AEM CAI
Zex Nitrous-75 shot<------ Taken off as of 1/05
Greddy E-Manage(waiting to be hooked up to the Nitrous) <-----Sold as of 7/05
Recaro Sports Seats
MotionEffects is offline   Reply With Quote
The Following 3 Users Say Thank You to MotionEffects For This Useful Post:
ekxtreem (04-04-2013), emaka9 (03-04-2013), maddog0z (06-23-2013)
Old 11-10-2008, 12:46 AM   #2
MotionEffects
Acura TLS are SLOW
Wrong Pic used in step 11 of removal. Ignore the pic in Step 11
02 TL-S Non-Navi
Oem Body Kit
OEM Spoiler
Comptech Sway Bars
NEUSPEED Strut Bar
Cusco Lower Tie Bar
AEM CAI
Recaro Sports Seats
Old 11-10-2008, 4:53 AM   #3
red00tl
Points: 6,224, Level: 51
Points: 6,224, Level: 51 Points: 6,224, Level: 51 Points: 6,224, Level: 51
A very nice post indeed! Much kudos to you for a superb write-up.
red00tl is offline   Reply With Quote
Old 11-10-2008, 7:13 AM   #4
Iggy
Points: 10,895, Level: 69
Points: 10,895, Level: 69 Points: 10,895, Level: 69 Points: 10,895, Level: 69
I'm suprised the Husky broke that free too.
2002 WDP TL-S w/nav
OEM body kit, rear spoiler, fog mod,
Eaglight 55w fogs, 3A exhaust tips.
Debadged
Member of the bent rim club
Stereo:
JL XR650-CS front , Polk DX-6 rear,
Infinity 1030w
Kicker Rmb-8 mid sub
Earthquake Tnt-900 5ch(65wRMSx4, 200wRMSx1)
two 2ch PAC loc.
Tsunami double shield cable
Cascade V-block front & rear doors
Cascade DEFLEX powerpads (front)
Southy's Arnold mod
The elusive EQ bypass(without noise!)
Iggy is offline   Reply With Quote
Old 11-10-2008, 7:30 AM   #5
fsttyms1
2000 Acura TL
fsttyms1
Points: 98,328, Level: 100
Points: 98,328, Level: 100 Points: 98,328, Level: 100 Points: 98,328, Level: 100
Activity: 99.6%
Activity: 99.6% Activity: 99.6% Activity: 99.6%
Nice.
I will add.
1. Install the belt counter clock wise starting from the crank.
2. Ive done this probably 5+ times and i still dont see the need for the battery tie down.
3. Make sure the rear cam doesn't move. It sits right on the edge of spinning forward or backward 1/4 turn. If you do forget to mark it, there is a mark on the backing plate that you can line up with the TDC line across the cam gear
And i to am surprised your air gun got that off.
Old 11-10-2008, 11:18 AM   #6
phee
I got the Shifts
1999 Acura TL
phee's Avatar
Trader Rating: (5)
Points: 41,805, Level: 100
Points: 41,805, Level: 100 Points: 41,805, Level: 100 Points: 41,805, Level: 100
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
wow. great writeup! where were you 20k miles ago?
phee is offline   Reply With Quote
Old 11-10-2008, 11:19 PM   #7
SSTL
Awesome Memeber
1999 Acura TL
SSTL's Avatar
Trader Rating: (1)
Points: 6,295, Level: 51
Points: 6,295, Level: 51 Points: 6,295, Level: 51 Points: 6,295, Level: 51
Nice write up, thanks for taking the time.
RIP: 99 Acura TL (2007-2010)
SSTL is offline   Reply With Quote
Old 11-11-2008, 3:20 PM   #8
acutee
acutee's Avatar
Points: 11,716, Level: 71
Points: 11,716, Level: 71 Points: 11,716, Level: 71 Points: 11,716, Level: 71
Activity: 3.1%
Activity: 3.1% Activity: 3.1% Activity: 3.1%
Great writeup
Great write up with pictures. That is very good of you doing it the first time in 5 hrs.
acutee is offline   Reply With Quote
Old 11-11-2008, 5:13 PM   #9
Stimpy
Points: 5,473, Level: 47
Points: 5,473, Level: 47 Points: 5,473, Level: 47 Points: 5,473, Level: 47
Activity: 0.3%
how much did the materials end up costing you?
Stimpy is offline   Reply With Quote
Old 11-11-2008, 8:29 PM   #10
death
Lower IS Better!
2003 Acura TL TYPE-S
death's Avatar
Points: 11,056, Level: 69
Points: 11,056, Level: 69 Points: 11,056, Level: 69 Points: 11,056, Level: 69
Great write up, thanks for sharing.
1998 Audi A4 1.8T (Daily Driver)
2002 Lexus IS300 Sport Cross (Daily Driver)
2003 Acura TL-S (gone but not forgotten...)
death is offline   Reply With Quote
Old 11-11-2008, 8:35 PM   #11
MotionEffects
Acura TLS are SLOW
fsttyms1-Now since you mention the rear cam sits on the edge of jumping forward or backward, I forgot to mention that happen to me. Haha
phee-
You're very Welcme
Stimpy-I paid $350 for all belts, waterpump, tensioner, adjuster and idler pulley. I didnt really need the tensioner, idler and adjuster since they all where good. No play in the bearings (idler+adj) and no leaks (tensioner)
02 TL-S Non-Navi
Oem Body Kit
OEM Spoiler
Comptech Sway Bars
NEUSPEED Strut Bar
Cusco Lower Tie Bar
AEM CAI
Recaro Sports Seats
Old 12-12-2008, 12:26 AM   #12
salvageland
Points: 2,527, Level: 30
Points: 2,527, Level: 30 Points: 2,527, Level: 30 Points: 2,527, Level: 30
Activity: 0.1%
thanks for the DIY!!!! i'm going to tackle this job on my accord v6 6spd next week...just one question, what did u do to correct the rear cam timing when it slipped during installation?.....i read on a different forum that you have to remove the rear valve cover and loosen the rocker arm bolts to be able to turn the cam back to TDC....
salvageland is offline   Reply With Quote
Old 12-12-2008, 9:29 PM   #13
jjar03
Points: 3,404, Level: 36
Points: 3,404, Level: 36 Points: 3,404, Level: 36 Points: 3,404, Level: 36
I am also curious to hear an answer that salvageland asked.
Is it OK or can I change the water pump without draining the coolant first, I mean, spill free of course? Judging by your post this seems to be the case.
In my mind it would be easier to finish off replacing the belt + pump and then drain and replace the coolant itself.
In short I am getting ready to do it myself, also, first time ever, so I would like to know which tool/tools did you use exactly to take off all those cover bolts (front, rear and lower cover of course). The space is extra tight especially for the rear cover and lower cover. Can you access any bolts from under the car?
Can you post the exact measure (length) for the wrench?
jjar03 is offline   Reply With Quote
Old 12-13-2008, 12:08 AM   #14
Russell The Love Muscle
2002 Acura TL TYPE-S
My Garage
Russell The Love Muscle's Avatar
Points: 2,106, Level: 27
Points: 2,106, Level: 27 Points: 2,106, Level: 27 Points: 2,106, Level: 27
Activity: 26.7%
Activity: 26.7% Activity: 26.7% Activity: 26.7%
All you need to do is slide the timing belt off of the cam gear, make sure that you don't turn the crank off of TDC when you do this, then put a wrench on the bolt for the cam gear and turn it until it lines up, then slide the timing belt back on the gear.
Drain the coolant before you remove the pump otherwise once you remove the bolts and start to pull the pump off coolant will spill everywhere and it runs down the motor so you can't just put a drain pan under it.
As for the tools, I'm not sure because I've never changed the timing belt and waterpump on the TL
Russell The Love Muscle is offline   Reply With Quote
Old 01-02-2009, 2:09 AM   #15
SableSal
Is this right?... I mean, it seems right. Although I have never done a Honda timing belt before.
Can anyone confirm this, so for my peace of mind??
SableSal is offline   Reply With Quote
Old 01-11-2009, 11:18 PM   #16
XxXboboXxX
Told Ya'LL...DYNASTY !!
2002 Acura TL
XxXboboXxX's Avatar
Trader Rating: (2)
Points: 11,239, Level: 69
Points: 11,239, Level: 69 Points: 11,239, Level: 69 Points: 11,239, Level: 69
any way you could hook us up with a parts list?? and the parts #'s
nice DIY, getting ready to do this myself
XxXboboXxX is offline   Reply With Quote
Old 01-11-2009, 11:24 PM   #17
XxXboboXxX
2002 Acura TL
XxXboboXxX's Avatar
Trader Rating: (2)
would a kit like this take care of it..
http://cgi.ebay.com/ebaymotors/Acura...ht_4327wt_1093
Old 01-12-2009, 9:13 AM   #18
Acura2g
Owner www.2ndgen.info
Do we have torque specs?
99 3.2TL NBP
-K&N Drop-in Filter
-02-03 Taillights
-Hardwired Cobra Radar Detector
-Ipod Nano
-Outlaw Thermo Gasket
-Intake Resonator Removed
-Mid-Muffler Deletion
Owner and Operator: 2nd Generation
Acura2g is offline   Reply With Quote
Old 01-12-2009, 11:18 AM   #19
CJITTY
Ackniculous One
2008 Lexus LS Hybrid
CJITTY's Avatar
Points: 25,762, Level: 96
Points: 25,762, Level: 96 Points: 25,762, Level: 96 Points: 25,762, Level: 96
Very Nice write up, props to you for doing this.
This is something I wouldn't feel comfortable doing myself. I just got my timing belt service with new oem water pump, valve adjustment, coolant flush, power steering flush and they threw on my UR Stock size lightweight pulley (labor for the pulley free of course) for $590 at a Acura mechanic's shop nearby. Dealer wanted $1200 w/o a valve adjustment so your DIY will certainly be helpful to those looking to save a lot of cash.
2008 Lexus LS600hL
2003 Acura TL Type S - Sold
CJITTY is offline   Reply With Quote
Old 01-12-2009, 6:40 PM   #20
mrkatt
Hi, great write up!
OK, you have inspired me to DIY on the timing belt. Now, if you could answer a few questions please.
The water pump, does it include the gasget, and do I need to apply adhesive to the gasget/engine, or is the pump just bolt on with rubber gasget no adhesive?
I am using a new tensioner/aduster pully/idler pully. How do I use the battery tie down and on what part? Dealer only item?
Thanks for any advice
Jason
mrkatt is offline   Reply With Quote
Old 01-13-2009, 11:23 PM   #21
salvageland
Activity: 0.1%
i tried to tackle this job this week and upon taking off the timing belt covers i found that my belt was in excellent condition..(04 accord v6 6 speed with 107k miles) so i decided to drive another 20-30k on the stock belt before i change it...
i have timing belt kit that i bought from ebay comes with GMB idler and tensioner pulley with a Continental timingbelt...if anybody is interested...$105 shipped nairi91205@yahoo.com
Old 01-21-2009, 8:02 PM   #22
AnthraciteBeast
2001 Honda S2000
AnthraciteBeast's Avatar
Trader Rating: (3)
Great write up
Im thinking about doing this myself because i dont have $1000+ that the stealership wants
I bought the car when it already more than 110k on it so i dont know if it was ever changed!
Is there a way to find out if it was or not? (dumb question i know)
2001 SM S2000
2003 AM 3.2CL Type -S ---- SOLD
1996 CG Integra GSR ---- SOLD
AnthraciteBeast is offline   Reply With Quote
Old 01-22-2009, 7:53 PM   #23
DasTeknoViking
2004 Volkswagen R32
Points: 2,289, Level: 28
Points: 2,289, Level: 28 Points: 2,289, Level: 28 Points: 2,289, Level: 28
Activity: 0.2%
Pretty nice write up, having to do these all the time @ work I am glad that some people are able to do these. They are cake walk ! Only thing I don't understand is this battery tie down thing you are talkin about ?
I stick the tensioner into the vise and compress it back..
There is no way of telling if the timing belt has been changed. Look at the drive belts, if they are pretty crusty looking chances are its never been done. If any of you have any Qs about these belt changes, shoot me a PM.
DasTeknoViking is offline   Reply With Quote
Old 01-23-2009, 6:26 PM   #24
Southern
Southern's Avatar
Points: 8,894, Level: 63
Points: 8,894, Level: 63 Points: 8,894, Level: 63 Points: 8,894, Level: 63
Nice write-up! I also did my timing belt at 120K miles however I also did the valve adjustment and replaced my worn engine mounts.
From your write-up I assume that you work on cars for a living because you wear gloves and you rated this job as a 3/10. I ended up scraping my hands doing my timing belt because I don't like the feel of gloves when I wrench. I also assume that you were using an industrial shop air compressor because you were able to break the crank bolt with your air impact gun.
2001 White 3.2TL
Southern is offline   Reply With Quote
Old 01-24-2009, 9:22 AM   #25
DasTeknoViking
2004 Volkswagen R32
Activity: 0.2%
K, I now see how you compress the timing belt tensioner back using the battery tray bolt..... I did a belt on a 99 TL yesterday and saw that little tab. It looks like a big PITA to do it that way, just buy a vice and compress it like that.
Maybe that person with the 99 TL was from here, it had cross drilled rotors and some kinda pads that where not OEM all around ?
Fix your tie rod bud
Old 02-01-2009, 3:16 AM   #26
SableSal
Anyone??
Old 02-01-2009, 10:02 AM   #27
mrkatt
My fathernlaw and myself tackled this tbelt job last week, took 7 hrs (2 hrs back and forth to the tool store, and 1 hr gettin the damn crank bolt off!) with the majority of time taking off the timing belt cover and front mount. I did not have a factory service manual (trial and error for removal sequence), but from the time I exposed the timing belt/water pump ( I replaced tbelt/water pump, tensioner (was bad) idler pully and adjuster pully (looked good), took me 30 min and was very easy. BUT, on this job I also changed upper lower rad hoses and flushed collant, replaced ac tensioner, both belts in 7 frustrating hrs. The worst part, DON'T OVER TIGHTEN YOUR PS BELT. I ruined my ps pump, and is at the dealer to repair (long story I am going to write up later when/if car is fixed).
Hope this helps,
Jason
Old 02-02-2009, 2:59 PM   #28
01RedCLS
Points: 8,209, Level: 61
Points: 8,209, Level: 61 Points: 8,209, Level: 61 Points: 8,209, Level: 61
Can you list exactly what sockets you need for this?
2001 Acura CL Type-S w/ NAVI, San Marino Red (Legend Calipers, Brakemotive Drilled/Slotted Brakes, Option Racing UC Pulley, 2006 Avincar Speaker Upgrade)
01RedCLS is offline   Reply With Quote
Old 02-05-2009, 2:42 PM   #29
slickshoes
Points: 6,676, Level: 53
Points: 6,676, Level: 53 Points: 6,676, Level: 53 Points: 6,676, Level: 53
Also, do you have the part number for the tensioner, its not listed anywhere on the part sites...and in this image, you see it as #18, but the part and price aren't actually listed.
-06' Civic-
-99' TL-
-66' Nova SS-
slickshoes is offline   Reply With Quote
Old 02-05-2009, 7:18 PM   #30
bromat80
Points: 3,230, Level: 35
Points: 3,230, Level: 35 Points: 3,230, Level: 35 Points: 3,230, Level: 35
Awesome write up. I just purchased a 2000 TL this week with 120k on it with the original timing belt and I had plans to take care of this as soon as possible.
bromat80 is offline   Reply With Quote
Old 02-06-2009, 11:13 AM   #31
slickshoes
Also, could I get away with changing out the PS belt, AC belt, timing belt, water pump, and water pump gasket. Or do I need the pulleys and tensioner.
I'm going to be picking up the parts online at a discount and bringing them to my local repair guys..thanks.
-06' Civic-
-99' TL-
-66' Nova SS-
Old 02-06-2009, 11:34 AM   #32
Chanrith
'02 NBP TL-S
2008 Lexus RX
My Garage
Chanrith's Avatar
Points: 4,359, Level: 42
Points: 4,359, Level: 42 Points: 4,359, Level: 42 Points: 4,359, Level: 42
Activity: 0.3%
Great write-up. Looks pretty intense for me to do. It cost me a little over $500 to have a shop do it with OEM parts (belts & water pump). I think this is one task I'll have to pass on considering I only need to do every 90k-100k+.
Type-S
"Mods": replaced tranny (covered by Acura), engine mounts, air filter, cabin air filters, timing belt/water pump @ 112k miles, tires Tomod: seafoam, sparks, OEM lip kit (front & sides only), rear bumper (looking for OEM NBP), WW rear lip, exhaust tips, black-out headlights, repair fogs, repair drivers seat heater, paint outer grille & maybe door handles.
Chanrith is offline   Reply With Quote
Old 02-08-2009, 6:16 PM   #33
Acura2g
QUESTION:
Where do you get the pin for the hydrolic tensioner?
99 3.2TL NBP
-K&N Drop-in Filter
-02-03 Taillights
-Ipod Nano
Old 02-08-2009, 9:43 PM   #34
Legend2TL
2005 Acura TL
Legend2TL's Avatar
Points: 19,430, Level: 88
Points: 19,430, Level: 88 Points: 19,430, Level: 88 Points: 19,430, Level: 88
Activity: 36.5%
Activity: 36.5% Activity: 36.5% Activity: 36.5%
Nice pictures and writeup!
One last note even if you drain the antifreeze when you remove the waterpump on a J32 or J35 there's usually enough antifreeze still in the block that will come out when the pump is removed. So be certain to plug the dipstick hole with a rag to prevent the antifreeze from going into the oil pan. I discovered this the hard way, and had to change the oil to drain the anti-freeze out of the oil sump (and I just changed it before the timing belt change!).
Legend2TL is online now   Reply With Quote
Old 02-08-2009, 9:45 PM   #35
Legend2TL
2005 Acura TL
Legend2TL's Avatar
Activity: 36.5%
Yep with the J motors it's really easy to get the old belt off and more importantly very easy to get the new belt on and aligned. I did a J35 motor on a Honda Pilot last year (virtually identical to this J32 timing belt change).
Old 02-08-2009, 9:47 PM   #36
Legend2TL
2005 Acura TL
Legend2TL's Avatar
Activity: 36.5%
Originally Posted by Acura2g View Post
QUESTION:
It comes with the new tensioner.
Old 02-08-2009, 9:51 PM   #37
Legend2TL
2005 Acura TL
Legend2TL's Avatar
Activity: 36.5%
Crankshaft pulley bolt 19mm
Seprentine pulley bolt 14mm
TB covers 10mm
PS pump bracket 12mm
WB 10mm
Idler pulley 14mm
TB tensioner 10mm (?)
Old 02-08-2009, 10:03 PM   #38
Acura2g
I'm a little confused. I'm doing it this week.
Do I need to buy that? I bought a kit that includes
The Idler Pulley, Timing Belt and tensioner pulley. Nothing else.. Do I need to buy something else?
99 3.2TL NBP
-K&N Drop-in Filter
-02-03 Taillights
-Ipod Nano
Old 02-09-2009, 12:09 PM   #39
acutee
acutee's Avatar
Activity: 3.1%
That is just a partial kit. You will need a water pump, and might as well replace the tensioner.
Old 02-16-2009, 1:41 AM   #40
SableSal
Awesome! I'm going to be tackling the J30 this summer. Thanks a million! I appreciate it!
I was always curious on the seals, crank seal, cam seals? What about changing those out? Also, is it customary to replace the tensioner and idler?
2003, 32tl, acura, bar, belt, change, cl, cross, front, labor, mark, member, nsx, rod, tdc, tie, timing
