Steering Wheel vibrates when braking at high speed
Old 10-05-2008, 04:11 PM
nebrou's Avatar
Hi
My steering wheel vibrates hard in my CL when i press the brake at high speed. I changed the back rotors and pads since I thought the problem comes from them since they were in a bad shape, but still it didnt solve the problem
Any help will appreciate it.
Old 10-05-2008, 04:27 PM
MD03CL-S's Avatar
Usually the front rotors/pads when you feel it in the steering wheel.
Old 10-05-2008, 05:09 PM
p.diddy's Avatar
warped rotors. i recently had the exact same problem i bought new drilled/slotted rotors and i havent had the problem since.
Old 10-05-2008, 05:25 PM
Not Asian
phipark's Avatar
It's the front rotors.
Old 10-05-2008, 05:28 PM
CL6
My only car is a Bus
CL6's Avatar
This is a well known problem with the CLs.
Old 10-05-2008, 05:52 PM
Regional Coordinator (Texas)
nspec_ya4's Avatar
i just installed new rotors in front and it seems like it got worst.
any opinions or common problems?
one of my friends/mechanic said it can also be my back rotors,
my steering wheel still shakes pretty hard and i just cant figure out what it can be.
Old 10-05-2008, 06:02 PM
m733l's Avatar
did you change the pads as well?
Old 10-05-2008, 06:04 PM
Not Asian
phipark's Avatar
Hopefully the pads were changed as well. If they were, then something else is wrong. Check the calipers, could be frozen, or maybe something may be bent. Your steering wheel wouldn't really shake if it was the rears that were bad.
Old 10-05-2008, 10:42 PM
aznboi2424's Avatar
Change the pads and rotors at the same time. Id suspect the rotors first if your braking and your steering wheels shakes. I will be upgrading to slotted/drilled rotors at my next brake pad change. Make sure you do a proper bed-in, it makes a world of difference.
Old 10-05-2008, 11:08 PM
nspec_ya4's Avatar
no i didnt change the pads because they're in very good condition.
i'll change them tomorrow. the only problem is that if the vibrations stay, i wont be able to return the brake pads.
Old 10-05-2008, 11:26 PM
nf3d0149ab's Avatar
My vibrations in the steering wheel were resolved with new rotors and pads.
Old 10-05-2008, 11:27 PM
m733l's Avatar
you generally want to change them both at the same time because if your rotors are warped then the pads you are using will not wear properly. so if you changed the rotors and used the uneven pads then it will warped the rotors again. i would change to new pads and resurface the rotors and then put them on at the same time.
Old 10-06-2008, 09:22 AM
Trolling Canuckistan
black label's Avatar
I've heard of a pad slap with no rotors, this is the first rotor slap brake job I've ever heard of.
Old 10-06-2008, 08:39 PM
TellinItLikeItIsSince1/06
'01White3.2CL's Avatar
i had this problem too. i bought rotora slotted rotors and new pads at once, the problem lessened a lot, but it was still there and i was pissed.
it wasn't until i put on my new rims that i found that one of my front rims was bent on the inside by the axle where i could have never saw it.
turned out it was combo of bad brakes and a bent rim...now its perfect.
Old 10-06-2008, 10:34 PM
nspec_ya4's Avatar
oh yeah. one thing i forgot to list.
on my old driver side rotor, there was a small piece of metal
something in a shape of a horse shoe, but a little thicker than a paperclip. and only about 3-4 inches long.
its was inserted or got stock in b/w the walls of the rotor.
could not figure out what the hell it was. any body knows?
Old 10-06-2008, 11:35 PM
sbowden99's Avatar
I had this exact problem (steering wheel vibrating when braking) and Acura rebuilt my front end trying to solve it. In the end, it was a frozen caliper.
cheers,
--Seth
Old 10-07-2008, 03:32 AM
om27's Avatar
Usually, its the rotors. Simply replace them.. I am sure it'll definitely help... I did the same for mine and the problem got fixed. But, if u dont get it done from a skilled person,,it might worsen....
Old 10-07-2008, 07:50 AM
i heart latin chicks
nbennettksu's Avatar
this is a well known problem with any vehicle when the rotors havent been broken in properly
Old 10-07-2008, 09:16 AM
Kulrevon's Avatar
I believe some rotors are actually balenced from the company. Thats possibly what you are talking about.
I could be completely wrong about that.
Old 01-23-2013, 06:06 PM
DomIzDope's Avatar
Possibly worn tierods too. Check those but most likely the rotors and pads.
Old 01-23-2013, 06:41 PM
AustinTaper's Avatar
Why you are resurrecting a 4 year old thread, only to restate what was already mentioned?
Old 01-24-2013, 03:12 PM
Ultra Negro
OperationDarkie's Avatar
He already necro'd a bunch of old threads
peti1212
ILX
22
01-05-2022 05:14 PM
thisisnotdave
4G TL Problems & Fixes
09-08-2015 10:02 AM
nishant11
09-02-2015 10:34 AM
Quick Reply: Steering Wheel vibrates when braking at high speed
