MDX base carrier/ roof rack question
Old Sep 6, 2008 | 08:00 PM
frosty ride's Avatar
Need some insight, I'm looking at buying a 2005 MDX non-touring but want to add the roof rack. I've seen them advertised on but wanted to know if anyone has installed them themselves and how difficult was it. Thanks
Old Sep 7, 2008 | 09:20 AM
FiftyFive's Avatar
Moderator Alumnus
I have a touring and the roof rack came with it but here is a link to instructions on how to add the roof rack:
2002+ Acura MDX Roof Rack Installation
Doesn't seem to hard at all. The only you thing you actually have to modify or cut it the weather moldings. The file in that link will give you exact measurements on everything you need to do. Worse comes to worse and you mess up the weather moldings they are pretty cheap to replace. The OEM Acura roof rack can be had for well under $200.
Let us know how it goes!
Old Sep 4, 2010 | 03:03 AM
jhumbo's Avatar
08 MDX, 04 TL (sold)
I'm interested in adding the roof rack to my 08. Anyone have instructions for the 07+ or know if it is similar enough to the instructions above?
Old Sep 9, 2010 | 01:40 AM
dennis02's Avatar
You can check this out for instructions. http://estore.honda.com/accesssory-i...asp?make=acura
Old Apr 9, 2011 | 07:04 PM
Steven Carpenter's Avatar
need BOLTS for OEM MDX roof rack / MDX has channel that the rubber is in, take rubber out put bolt in.
any one have a line on the bolts ?
oyayjoe
Jan 1, 2019 10:17 PM
CaliBud916
Sep 19, 2015 01:56 PM
datadr
Sep 12, 2015 09:12 PM
FC2012RDX
1G RDX (2007-2012)
Sep 4, 2015 02:05 PM
Snafunk
1/2G MDX (2001-2013)
Sep 3, 2015 08:01 PM
