radiator flush - how often?
Old 08-22-2008, 10:09 PM
TLBaller's Avatar
I had mine busted 1.5 yrs ago and never thought about flushing them. The mechanic told me to flush my radiator 2-3 times a year..???
Anybody do this??
Old 08-22-2008, 11:05 PM
ht02tl-s's Avatar
that mechanic is either trying to get your business or he's some kind of extreme car buff. 2 to 3 flushes a year is way more than enough. 1 might be fine if you put alot of miles on your car in a year but its recommended that you flush your cooling system every time you change your coolant which is like every 2 years. look in your owners manual, it should tell you the recommended change interval for the coolant.
Old 08-23-2008, 08:54 AM
TexasHonda's Avatar
If you change coolant w/i 2 years you should never need to flush. Modern coolants have very good anti-corrosion packages. I would not contaminate my system w/ a flush unless I was going to totally remove flush by draining the block. This is a bitch to do on 2.5TL's and I just replace my coolant regularly.
good luck
Old 08-23-2008, 10:09 AM
TLBaller's Avatar
so ideally the coolant should be changed once every 2 yrs?? So by doing so, i won't have to do a complete flush, correct?
Old 08-23-2008, 03:23 PM
Khmer Pride
KrayzieDxC's Avatar
that reminds me i have to do that toooo, i havent did since 4 years ago or more..haha
Old 08-25-2008, 10:27 PM
gokartmozart's Avatar
I have my coolant flushed every two years.
Old 08-25-2008, 11:47 PM
大日本帝国
Go90go's Avatar
I don't run coolant.
~Cheers~
adrian_s2k
1G RDX (2007-2012)
23
01-12-2016 04:25 PM
hashbrown
09-29-2015 12:13 PM
Ratheruneeq
09-28-2015 07:41 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: radiator flush - how often?
