HomeLink Programming Issues - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine RDX Community > First Generation RDX (2007-2012) > Audio, Bluetooth, Electronics & Navigation
Old 08-06-2007, 4:20 PM   #1
kritter
Just moved into a new home with a Chamberlain 1/3horse LiftMaster garage door opener (rolling codes). I've tried several times (following the directions in the Acura manual) to get the HomeLink programmed but no luck yet. Anyone have any insight here please? Thanks!
kritter is offline   Reply With Quote
Old 08-06-2007, 7:37 PM   #2
Levy
Try it this way:
1) Hold down the button on the garage remote AND the button on the car (pos #1) AT THE SAME TIME.
2) Stop when the red light in the car's ceiling starts blinking fast. You're done.
3) Now park the car close to the gate. Very close.
4) Find the "learning button". It's supposed to be on the motor's surface.
5) Press the learning button and run to the car.
6) Hold down the same button inside the car (pos #1) until it starts blinking fast.
That works for most of the scenarios. Let us know if it works, ok?
Levy is offline   Reply With Quote
The Following 3 Users Say Thank You to Levy For This Useful Post:
andrewbenjack (07-27-2013), H22A_CD5 (09-12-2011), Jenluv186 (06-15-2013)
Old 08-08-2007, 9:20 AM   #3
kritter
Worked like a champ - thanks!
Old 08-09-2007, 5:25 PM   #4
Artie Ecks
Levy- I just wanted to say thanks, I was having the same problem and this fixed it. I love these boards!
Artie Ecks is offline   Reply With Quote
Old 08-10-2007, 8:00 AM   #5
brizey
Points: 6,133, Level: 50
Points: 6,133, Level: 50 Points: 6,133, Level: 50 Points: 6,133, Level: 50
Activity: 0.8%
The instructions in the manual sucked. There are really two sets of instructions, and only one works.
brizey is offline   Reply With Quote
Old 09-01-2007, 10:07 PM   #6
mau108
mau108's Avatar
Points: 8,550, Level: 62
Points: 8,550, Level: 62 Points: 8,550, Level: 62 Points: 8,550, Level: 62
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
instructions in the manual are way too confusing, if this then this if this then this and it keeps referring to each step ahh....
I gotta try this out tomorrow.
mau108 is offline   Reply With Quote
Old 09-02-2007, 12:16 PM   #7
catnippants
2007 Acura RDX
Points: 6,959, Level: 55
Points: 6,959, Level: 55 Points: 6,959, Level: 55 Points: 6,959, Level: 55
Activity: 0.3%
I have a Liftmaster setup as well, and I found that you need to use the Acura directions to program homelink to act as your remote, then use the Liftmaster instructions to authorize it for your opener. So it's really a two step process...
Mike
catnippants is offline   Reply With Quote
The Following User Says Thank You to catnippants For This Useful Post:
gigijen22 (11-29-2013)
Old 02-04-2008, 5:24 PM   #8
lawandorder360
Mike
Reviving this thread...just programmed the homelink in the RDX for a Liftmaster garage door opener, and it works fine.
HOWEVER, The other freestanding remote opener and the keypad no longer work! The code that was programmed to open the door (4 numbers) is now gone.
Do I simply need to add the keypad and the remote again to the memory of the unit? How would I need to do it?
Anyone??
lawandorder360 is offline   Reply With Quote
Old 02-05-2008, 12:30 PM   #9
bobq
bobq's Avatar
Points: 7,643, Level: 58
Points: 7,643, Level: 58 Points: 7,643, Level: 58 Points: 7,643, Level: 58
Yes, you need to add the keypad and the other remote back.
You probably removed all remotes when you started the programming for the RDX by holding the learning button in too long.
I have a Liftmaster, keypad and several remotes and all work fine with the homelink in the RDX in the mix.
bobq is offline   Reply With Quote
Old 02-06-2008, 9:01 PM   #10
sasair
sasair's Avatar
Most garage door openers have a limit of how many openers can be programmed into it and it usually isn't very big number. like 4 or 6. If you reach that limit and add a new opener, then it will forget the oldest openers, which will likely be the keypad and free standing remote since they probably came with the opener.
sasair is offline   Reply With Quote
Old 09-08-2010, 10:17 AM   #11
bbryson
New Member
Worked for me
Thanks Levy for the info. I have a 2003 MDX and a Liftmaster and your procedure is far clearer than what is in the user manual. I wouldn't have figured this out without your help.
bbryson is offline   Reply With Quote
Old 11-14-2010, 11:45 AM   #12
MPBRDX
MPBRDX's Avatar
Points: 3,310, Level: 35
Points: 3,310, Level: 35 Points: 3,310, Level: 35 Points: 3,310, Level: 35
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Originally Posted by Levy View Post
Try it this way:
Hey that worked...sweet!
Thanks for your help.
MPBRDX is offline   Reply With Quote
The Following User Says Thank You to MPBRDX For This Useful Post:
JKW1 (07-17-2014)
Old 12-19-2010, 1:51 PM   #13
hyuga
New Member
This worked great on a 2007 Acura TL and a Chamberlain 3/4 HP opener! Thank you very much, Levy, for posting such clear instructions!
hyuga is offline   Reply With Quote
Old 12-19-2010, 4:45 PM   #14
mrgold35
mrgold35
2006 Acura TSX
My Garage
mrgold35's Avatar
Points: 8,505, Level: 62
Points: 8,505, Level: 62 Points: 8,505, Level: 62 Points: 8,505, Level: 62
Activity: 17.5%
Activity: 17.5% Activity: 17.5% Activity: 17.5%
Is there a way to disable the homelink in the car when the key is out? Someone can open your garage door if your car is parked outside.
This seems like a security flaw with homelink having it active all the time.
Son (handed down for his 16th B-day) - 06 TSX 5AT w/ Navi, Carbon Gray w/ Quartz
His - 08 RDX Tech, Moroccan Red Pearl w/ Taupe
Her - 11 MDX Adv/Ent, Palladium Metallic w/ Ebony
mrgold35 is offline   Reply With Quote
Old 12-20-2010, 9:29 AM   #15
YYC_BoxsterGuy
2011 Acura RDX
My Garage
Points: 762, Level: 14
Points: 762, Level: 14 Points: 762, Level: 14 Points: 762, Level: 14
Try it this way:
Perfect! I was having trouble getting my Linear opener programmed, but following these instructions worked first time.
I could have been: a) not holding the remote close enough to the HomeLink buttons (at first, it was on the visor, but then I held it right next to the HomeLink...like 1/4 inch), and b) not transitioning from the 1st set of instructions to the 2nd set fast enough (I would meander around the garage, looking for something to stand on to reach the Learn button.)
YYC_BoxsterGuy is offline   Reply With Quote
Old 02-12-2011, 10:26 PM   #16
bigbrainz
New Member
Points: 1,570, Level: 22
Points: 1,570, Level: 22 Points: 1,570, Level: 22 Points: 1,570, Level: 22
Holding the remote SUPER close was the tip I needed. I also had it on the visor, like 6" away and it didn't work, but right up next to it did the trick--thanks!
bigbrainz is offline   Reply With Quote
Old 02-22-2011, 7:05 PM   #17
remarkco
Points: 1,087, Level: 17
Points: 1,087, Level: 17 Points: 1,087, Level: 17 Points: 1,087, Level: 17
Levi, we recently purchased a 2008 w\ the tech package. We were having trouble programing the home link to our Genie garage opener. I found your instructions and they worked like a charm. Many THANKS!!!
remarkco is offline   Reply With Quote
Old 03-20-2011, 11:18 AM   #18
PARZ RDX
New Member
Points: 1,389, Level: 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Smile
That worked for me, I wasn't holding the remote close enough either. Big thanks...
PARZ RDX is offline   Reply With Quote
Old 08-28-2011, 4:07 PM   #19
rjpros
New Member
rjpros rjpros rjpros
Points: 110, Level: 2
Points: 110, Level: 2 Points: 110, Level: 2 Points: 110, Level: 2
Activity: 0.2%
Worked great for door 1 but i can't get the same procedure to work for door 2 with button 2
rjpros is offline   Reply With Quote
Old 02-13-2012, 11:14 AM   #20
durhamjm
New Member
Activity: 0.1%
Programming HomeLink -Second Garage Door
Hi - the suggestion by Levy was exactly what I needed. I have both a RDX and a Honda Accord and both programmed just fine. Now, how do we do that if I have two garage doors? I tried the same technique using position #2 without any luck. Thoughts?
durhamjm is offline   Reply With Quote
Old 04-01-2012, 4:53 PM   #21
didr
New Member
Points: 19, Level: 1
Points: 19, Level: 1 Points: 19, Level: 1 Points: 19, Level: 1
Activity: 0.1%
only half-way there
Okay, so I followed the excellent instructions for programming the new Liftmaster opener, and all seemed well. The Homelink accepted the code and the garage door dutifully closed. But, I can get the door to close, but the Homelink does not cause the door to open. I have other (handheld) remotes that work just fine, so it must be something about Homelink that isn't programmed correctly. Any ideas?
didr is offline   Reply With Quote
Old 04-01-2012, 10:30 PM   #22
alfa75uk
Points: 657, Level: 13
Points: 657, Level: 13 Points: 657, Level: 13 Points: 657, Level: 13
Can you open the door using homelink with the car inside your garage or are you only trying it from outside? The reason I ask is that I had a strange issue where I could open & close the door with the car inside the garage and close it from the outside but not open from outside. Took me months to figure out what was going on. If it's not opening at all with the car inside the garage it's not the same issue I had.
alfa75uk is offline   Reply With Quote
Old 06-23-2012, 9:25 PM   #23
chinkwapin
.:dedicated:.
chinkwapin's Avatar
Trader Rating: (1)
Points: 7,293, Level: 56
Points: 7,293, Level: 56 Points: 7,293, Level: 56 Points: 7,293, Level: 56
Activity: 6.3%
Activity: 6.3% Activity: 6.3% Activity: 6.3%
old thread but damn that made things easy! thanks
04 TL 6speed w/ nav
|ARC Winglets|Fujita CAI|GReddy Evo2|Function&Form Coilovers|OEM A-Spec|OEM Window Visors|iSimple iPod Integration|Blacked Out Headlights|OEM Type-S Decklid
chinkwapin is offline   Reply With Quote
Old 08-17-2012, 1:54 PM   #24
Vividsi
2004 Honda Civic
My Garage
Vividsi's Avatar
Points: 2,673, Level: 31
Points: 2,673, Level: 31 Points: 2,673, Level: 31 Points: 2,673, Level: 31
Activity: 0.3%
I have a lift master and just programmed mine a few days ago, works like a champ.
Vividsi is offline   Reply With Quote
Old 06-11-2013, 9:22 AM   #25
andygirl
andygirl's Avatar
andrea sarandes
Points: 5,442, Level: 47
Points: 5,442, Level: 47 Points: 5,442, Level: 47 Points: 5,442, Level: 47
I can't get mine to program. When I hold the remote button down and the HL button at the same time, all it does is open the garage door.
'07 Technology Carbon Gray Pearl
Wilwood BBk; Hondata reflash
19" Black wheels; K&N Typhoon CAI
I'm not speeding officer, I'm qualifying.
andygirl is offline   Reply With Quote
Old 07-30-2013, 7:17 PM   #26
outwism
New Member
Points: 9, Level: 1
Points: 9, Level: 1 Points: 9, Level: 1 Points: 9, Level: 1
Activity: 0.6%
Man, i tried everything except the 2 step process. I have a 2013 rdx. Works now! Thanks for forums and original poster!!!
outwism is offline   Reply With Quote
Old 07-31-2013, 8:11 AM   #27
wspy
2008 Acura RDX
1996 Eagle Talon
My Garage
wspy's Avatar
Points: 7,898, Level: 59
Points: 7,898, Level: 59 Points: 7,898, Level: 59 Points: 7,898, Level: 59
Activity: 0.4%
Too bad it dosent work for gate openers
wspy is offline   Reply With Quote
Old 08-13-2013, 3:28 AM   #28
Akshay Thakor
New Member
Points: 361, Level: 7
Points: 361, Level: 7 Points: 361, Level: 7 Points: 361, Level: 7
THIS WAS OMEGA HELPFULL!!!
yet somehow i managed to program it differently on the 08 MDX
Akshay Thakor is offline   Reply With Quote
Old 08-27-2013, 5:28 PM   #29
GENOBANDITO
New Member
Points: 10, Level: 1
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Activity: 0.2%
2013 rdx followed steps programs homelink kills garage door remotes
GENOBANDITO is offline   Reply With Quote
Old 09-01-2013, 8:47 AM   #30
x2lacrosse
Points: 2,557, Level: 30
Points: 2,557, Level: 30 Points: 2,557, Level: 30 Points: 2,557, Level: 30
Just bought a new house w/ a Liftmaster 8355 w/ MyQ technology; can't get either of our homelinks to program and have recently found a few reviews that state an external adapter is needed to make them work w/ this model opener. Unless someone has found otherwise, just posting this as an FYI.
Mine - '07 K23A1
Hers - '11 VQ37
x2lacrosse is offline   Reply With Quote
Old 11-16-2013, 4:53 AM   #31
Zippercat
Points: 1,669, Level: 23
Points: 1,669, Level: 23 Points: 1,669, Level: 23 Points: 1,669, Level: 23
Activity: 0.3%
This is probably what you need. New homelink tech is not compatible with most cars....
http://www.amazon.com/Liftmaster-855LM-HomeLink%C2%AE-Repeater-Kit/dp/B0071EYS1U/ref=sr_1_1?ie=UTF8&qid=1384599130&sr=8-1&keywords=liftmaster+repeater http://www.amazon.com/Liftmaster-855LM-HomeLink%C2%AE-Repeater-Kit/dp/B0071EYS1U/ref=sr_1_1?ie=UTF8&qid=1384599130&sr=8-1&keywords=liftmaster+repeater
In case that link does not work, just search "liftmaster repeater" at Amazon.
Zippercat is offline   Reply With Quote
Old 11-17-2013, 10:43 AM   #32
x2lacrosse
@ Zippercat.
If you were replying to my post, I was already aware of the incompatibility issues. I was more posting as an FYI.
I contacted Liftmaster; they gave me phone and ticket #'s to contact Homelink. Who then sent me a repeater free of charge for the product itself, I just had to pay $7 in shipping. Since repeater install, both cars programmed easily and working flawlessly.
Mine - '07 K23A1
Hers - '11 VQ37
Old 07-17-2014, 2:03 PM   #33
JKW1
New Member
Activity: 0.5%
Homelink programming Liftmaster
These instructions worked for my 2012 Acura RDX. Thank you!
JKW1 is offline   Reply With Quote
2006, acura, chamberlain, door, garage, homelink, homlink, liftmaster, opener, problems, programming, rdx, remote, sinc, tl
