How often do you rotate your tires?
Old 09-19-2006, 10:37 AM
Tigerriot's Avatar
I took my TSX in for it's first oil change recently, and I was told I should have the tires rotated. I told them i'd wait til 10,000 miles.
What do you guys think? Is it worth it to pay $40 every 5,000 miles to rotate your tires, or not?
Old 09-19-2006, 10:42 AM
cibs's Avatar
i don't think you ahve to rotate them that often... and hell for $40 i'd rather do it myself... 20 minutes of work tops...
Old 09-19-2006, 10:46 AM
LuvMyTSX's Avatar
Every 10k miles for me.
Old 09-19-2006, 10:52 AM
CarbonGray Earl's Avatar
$40 bucks is too much! The local quick lube place by me does it for 20, but even then I like to do it myself. It such a simple thing to do.
I personally go about every 10k....but I would like to go every 5, I'm just lazy.
Old 09-19-2006, 10:53 AM
Tigerriot's Avatar
Yeah, I hear ya. The only thing is i'd always be afraid I wouldn't do something right, or i'd strip a bolt trying to take one off, or put one back on.
Is is pretty fool proof, or do you need to know a thing or two about cars? Don't they "balance" them or something?
Old 09-19-2006, 10:54 AM
feelgood13's Avatar
mine rotates automatically when i drive - all four of them.
Old 09-19-2006, 11:03 AM
CGTSX2004's Avatar
Considering that I've only managed to put about 4500 miles on my car since I put my summer tires on, I'll probably rotate them when I put the summer wheels and tires on the car again next spring.
Old 09-19-2006, 11:07 AM
jlukja's Avatar
Old 09-19-2006, 11:09 AM
Driver/Detailer
aaronng's Avatar
I rotate it myself every 5000 miles.
Old 09-19-2006, 11:25 AM
jwood_06TSX's Avatar
Or what you can do, which is what i did, was go to a place like Just Tires, or NTB with about 20 mins til they close and ask them when the next time they can do it is. I got luck and the dude working there was like we'll just throw it up there real fast and at the end, i said how much, and he told me just to tip the 2 guys that did it really fast. So i threw them 5 bucks each and they said to come back whenever i wanted......they really liked my car Said he'd hook me up on tires too......god thing too with winter coming!
Old 09-19-2006, 11:33 AM
cibs's Avatar
it is pretty damn fool proof.... just make sure you keep track of what tire came from where and goes where... especially once you go to directional tires (which you don't have to worry about considering you have OEMs)...
they only balance them when they install the tires on the rim, to rotate all it takes is just swtiching them around... 2 jack stands and a jack and i'm good to go... it's a total of 20 nuts to undo and redo...
not that shabby at all...
you really can't mess it up... just remember to start the nuts by hand when you're putting them back on to make sure you don't cross thread them and you'll be fine
Old 09-19-2006, 11:54 AM
afici0nad0's Avatar
do you swap for winters each season? if so, might as well rotate during each season's swap.
Old 09-19-2006, 12:10 PM
CCColtsicehockey's Avatar
Received 3,657 Likes on 2,491 Posts
I rotate mine never since the wheels are staggered and have directional tread.
Old 09-19-2006, 01:19 PM
Reach's Avatar
Hrm, what is proper 'rotating' procedure? I'm at nearly 15k and never rotated, I should probably do that!
do you just swap FR-FL & RR-RL, or do you X them up like FR-RL & FL-RR?
Old 09-19-2006, 01:25 PM
it depends if they are a single directional tread or not.
Old 09-19-2006, 01:30 PM
A DiRTBAG decal on my
TSX2345's Avatar
I have heard tire shops say every 5000 miles re-balalnce, rotate & alignment. Which is what I do, since the shop offers the re-balance and rotation for free and I have the lifetime alignment.
A little tire care preventative maintenance
Old 09-19-2006, 01:52 PM
That seems fine for a rotation, but that's a little too frequent for alignment - I usually do it every 15k, but its more dependent on what I feel at the wheel. If everything feels straight and true, I usually put alignment off.
Old 09-19-2006, 01:57 PM
fdl
fdl's Avatar
Every second oil change
Old 09-19-2006, 02:31 PM
cheepung's Avatar
Do you have any Sears Auto Center nearby? It costs $15 per wheel for balancing-for-life and rotate for free since they have to take the wheels off.
They have no limit (every 5K or months), you can do it as many as you want as long you mention vibration on wheel.
For every 5K, i have oil change at Acura. Balancing and rotation at Sears. I usually take a day off to do all on the same day.
Old 09-19-2006, 03:21 PM
TSX2345's Avatar
Tires aren't cheap so might as well take care of them, and your car at the same time.
Old 09-19-2006, 03:29 PM
I just noticed you have lifetime alignment, by all means, do it your way. I only do it my way because that would be expensive if I had to shell out $60+ every 5k for an alignment.
Plus I'm still on OEM rubber...the sooner I can make the argument for getting out of them, the better.
Old 09-19-2006, 04:10 PM
jerzpwr's Avatar
Old 09-19-2006, 04:39 PM
TSX2345's Avatar
Lifetime alignment definately worth it
Old 09-19-2006, 04:44 PM
How much did you pay and where did you get it?
Old 09-19-2006, 04:51 PM
TSX2345's Avatar
Exclamation
Discount Tire Centers I believe it was like $180. Pays for itself after a few alignments
Old 09-19-2006, 05:06 PM
'06 TSX 6MT
Lone Starr's Avatar
For OEM Tires, the manual says to do:
FR->RR
RR->FL
FL->RL
RL->FR
Basically the fronts move direclty back, and the rears go to the oposite front.
For directional tires, you rotate fronts to backs directly with no cross.
Old 09-19-2006, 05:35 PM
Not bad, I'll have to look into it when I get new shoes....I think dealers charge 69+ so that is a really good deal.
Old 09-19-2006, 08:52 PM
08 MDX with Sports
Newplay1's Avatar
I'm anal I have rotated them every other oil changes..
Old 09-19-2006, 09:01 PM
New to Modding Cars
KapVu's Avatar
I paid $60 bucks for lifetime tire rotation at Discount Tires. I rotate about every 3,000 miles but they recommended every 6,000.
Old 09-21-2006, 08:07 AM
MAC USERS RULE
JAXFLTSX's Avatar
I rotate mine every 2000 miles or 6 fill ups at the gas pump. I am getting 475 miles out of a tank of gas Sweet. Thanks Injen. and the 6mt.
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
Zonian22
11-14-2015 01:20 PM
real_mckoy
4G TL Problems & Fixes
09-25-2015 10:49 PM
datadr
09-12-2015 09:12 PM
Zonian22
09-02-2015 08:19 AM
Quick Reply: How often do you rotate your tires?
