How do I program my key fob?
Old 06-16-2006, 12:09 PM
krames's Avatar
I just picked up my 2006 TSX and I LOVE it!
But, unfortunately my dealer did not program one of my key fobs. It is useless! I cant use it to open my doors. Can anyone help me out? I tried searching all over and I didnt find anything.
Kyle
krames is offline
Old 06-16-2006, 12:16 PM
moda_way's Avatar
Follow precisely:
Transmitter Programming
Storing transmitter codes:
The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the tailgate are closed.
1. Turn the ignition switch to ON (II).
2. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch. (located by the driver’s window switches)
3. Within 1 to 4 sec, turn the ignition switch OFF.
4. Within 1 to 4 sec, turn the ignition switch ON (II).
5. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch. (located by the driver’s window switches)
6. Within 1 to 4 sec, turn the ignition switch OFF.
7. Within 1 to 4 sec, turn the ignition switch ON (II).
8. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch. (located by the driver’s window switches)
9. Within 1 to 4 sec, turn the ignition switch OFF.
10. Within 1 to 4 sec, turn the ignition switch ON (II).
11. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver in the power window master switch. (located by the driver’s window switches)
12. Confirm you can hear the sound of the door lock actuators within 1 to 4 sec, then push transmitter lock or unlock button again, or the code will not be stored.
13. Within 10 sec, aim the transmitters (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons.
Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch off, and remove the key.
15. Confirm proper operation with the transmitters.
moda_way is offline
Old 06-16-2006, 12:17 PM
CGTSX2004's Avatar
search is your friend!
https://acurazine.com/forums/showthr...program+remote
And welcome
CGTSX2004 is offline
datadr
03-23-2016 01:39 PM
soupi
14
11-15-2015 11:15 AM
eastcoastguy
10-29-2015 03:00 PM
DementiaPhuro
09-29-2015 05:31 PM
malvothegreat
09-29-2015 12:38 AM
Quick Reply: How do I program my key fob?
