Anybody get the 2nd gear grind when shifting in high RPM"s???
Old 11-11-2005, 12:48 PM
Un-Kut's Avatar
Anytime i shift @ redline to 2nd gear, even though the clutch is fully depressed, i get a slight grinding noise.... its pissing me off, does anybody get it too? i think its similar to the RSX 6 speed problem others were having
Old 11-11-2005, 12:55 PM
C'mon, man! Row yer own.
peter_bigblock's Avatar
I find, sometimes, shifting at redline into 2nd it's balky -- doesn't want to go into gear as quickly as I'm trying to shift and I occasionally get a grind. Just takes a split-second hesitation to get it into 2nd. Other gears don't seem to mind shifting as quickly as I can.
Anybody else?
Old 11-11-2005, 01:25 PM
moda_way's Avatar
I have the Comptech Short-shift and it can be a bit tight to get in, but I've never had a grind.
Old 11-11-2005, 05:58 PM
tsxflexer's Avatar
Usually when you get grinding shifting into gears at high RPM's on Honda Trannies it means that the synchros are worn. This doesn't mean that your tranny is going to fail. If you delay your shift alittle it shouldn't grind.
Old 11-12-2005, 12:28 AM
That's what I figured. I've had a couple fairly bad mis-shifts (missed 4th, hit 2nd downshifting from 6th). Actually, it wasn't me, it was my brother on the worst one. That's okay, though -- he's my bro. He can buy me a new synchro if this one goes out.
Old 11-12-2005, 01:10 AM
Professional Newbie
madmanmax3000's Avatar
yeah man i've definitely gotten that grind before...it kills me a bit inside each time...because i have ZERO idea what's happening to my car! thank god it's only happened a few times right
Old 11-12-2005, 01:46 AM
Un-Kut's Avatar
thats weird, it can't be worn synchros because i only have 15,000 miles on the car
Old 11-12-2005, 07:21 AM
Ticket Slow Drivers
Redfish's Avatar
With the colder weather...it feels a bit notchier...no grinds yet.
Now, my girlfriend's 2002 RSX...that grinds in the winter time. Several times we've taken it to the dealer...'they can't replicate the problem'.
Old 11-12-2005, 07:53 AM
Registered Abuser
Eeyore's Avatar
Leave it at the dealer on a cold night and have them drive it 1st thing next morning. They can't replicate it because you drive in with the tranny and car all warmed up. My 02 RSX-S grinded from 1-2 every time I started driving it in cold weather.
The TSX doesn't grind, but the 1-2 shift is a little difficult at times and like the RSX it gets worse with the cold weather. Never had a grind shifting at high rpm from 1-2 though. I have had a small grind for whatever reason while shifting SLOWLY from 3-4.
Old 11-12-2005, 09:58 AM
JTso's Avatar
My TSX grinds occassionaly from 1st to 2nd during high rpm shifting regardless of temp or the mileage of the car. It's been doing it since new. Slowing down the shifting eliminates the problem so I doubt the dealer will do anything about it.
Old 11-12-2005, 10:02 AM
04 remembrance
iamhomin's Avatar
I had my synchros replaced and transmission rebuilt because of that problem. Mine had to be shoved to second for it to work.
But it was an isolated problem.
Old 11-28-2005, 03:24 PM
jorgev's Avatar
i get the grind going to second when i shift wile turning.. i thought it had to do with the vsa because that is the only time i have a problem shifting.. 90% of the time when shifting into 2nd i chirp 2nd and with the vsa off i have chirped 3rd...
Old 11-28-2005, 03:43 PM
JayRoam's Avatar
It happens to me, but fortunately not often. Especially when powershifting, but sometimes during normal driving. When it's normal driving, it happened when I was kinda tired. Usually 2nd gear, but sometimes 3rd. I've been driving Honda/Acura stick-shift for about 10 years now, and it seems like a Honda/Acura thing.
Old 11-29-2005, 01:43 PM
MaxOctane's Avatar
Gears grinding on the RSX is a WELL known problem. Here is the online petition, signed by over 18000 people. http://www.petitiononline.com/RSXgrind/petition.html
Old 12-01-2005, 01:11 AM
Por Favor?
Brandon24pdx's Avatar
Its from abuse, plain and simple. Yeah, some manual transmissions shift better and are built tougher than others, but most normal MT's for street cars wont like to be shifted past 7000 rpms. The parts are too light to hold up under drag racing type abuse. Hell, ask Mitsubishi how many EVO VIII trannies theyve replaced under warrantee, and those are built pretty tough.
You can use better tranny fluid for better protection. The NEO RHD is preffered by the guys trying to hold a tranny together behind 400-500 hp AWD Mitsubishis.
Old 12-01-2005, 06:46 AM
HebrewHammer's Avatar
It's 1800 people, not 18000.
When I shift, I always ease up on the throttle while putting out the clutch. After the gear change, I step on the gas while letting up on the clutch. So I'm not shifting at high rpm. I don't mean this as a criticism of anyone's driving style - it's just how I was taught and I don't get grinding sounds when I shift.
Old 12-03-2005, 02:26 AM
sillycasilli's Avatar
Since day one I have had that "problem"
The dealer told me that "the problem could not be duplicated under normal driving conditions". .... uh duh... when i dropped it off I said quick shifts @ high rpm...
so anyone build beefy trannys for our TSX yet?
Old 12-03-2005, 10:54 AM
Ticket Slow Drivers
Redfish's Avatar
Thanks MaxOctane. I think I came across that petition a while back...I need to add her name. Her's grinds even at low RPMs & slow shifts.
As the weather is getting colder, my TSX continues to get notchier.
phillyguerrilla
09-11-2015 06:39 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
Desert Ridge
09-05-2015 09:47 AM
Quick Reply: Anybody get the 2nd gear grind when shifting in high RPM"s???
