Acura clarifies the definition of a transmission flush
Old 02-04-2008, 02:35 AM
SodaLuvr's Avatar
From the January 2008 ServiceNews:
Some A/T repair procedures call for flushing the trans using Acura Precision Crafted ATF-Z1 (and no
substitutes). Problem is, where do you find the info to do that? It’s not listed in the S/Ms and if you do an
ISIS search, you’ll find a few ServiceNews articles on this subject, but they’re rather dated, and none of
them say the same thing.
NOTE: The term “flushing” refers to repeatedly draining and refilling the trans with Acura Precision Crafted ATF-Z1. Don’t confuse it with aftermarket flush systems. American Honda still strongly recommends that you avoid using them on any Acura vehicle. The original procedure was written for simpler A/Ts that readily upshifted when you ran the vehicle on a lift. But A/Ts have come a long way since then, and most of the newer ones balk at shifting past 2nd gear when on a lift, unless you work the shift lever a certain way. In light of all this, we thought it was high time that the A/T flushing procedure got a facelift. So here’s the latest word on flushing that works for all A/Ts:
1. Set the parking brake, and raise the vehicle on a lift.
2. Drain the trans, and refill it with Acura Precision Crafted ATF-Z1. Refer to the applicable S/M or to ISIS
for details.
3. Start the engine, shift into Drive, and release the parking brake.
4. Push down on the accelerator pedal to raise the vehicle speed to 2,500 rpm.
• If the trans shifts past 2nd gear, go to step 5.
• If the trans won’t shift past 2nd gear, keep the engine speed at 2,500 rpm and shift from Drive to
Neutral and back to Drive. Then go to step 5.
5. Make sure that the trans shifts through all the forward gears and goes into torque converter lockup.
6. Let off the accelerator pedal, and press the brake pedal to drop the vehicle speed to zero. Shift into
Reverse and then into Neutral.
7. Shift into Drive, and repeat steps 4 thru 6 four more times.
8. Set the parking brake, and repeat steps 2 thru 6 two more times.
9. Drain the trans, and reinstall the drain plug with a new sealing washer.
10. Refill the A/T with ATF-Z1.
Remember, Honda does not require that the transmission be flushed (as outlined in the above procedure) if you are just performing routine maintenance on the transmission.
Old 02-04-2008, 07:22 AM
Old 02-04-2008, 08:19 AM
T-Swzy
Razzi's Avatar
wtf does step 5 mean? is it saying go into SS mode and manually go up the gears while on a lift?
Old 02-04-2008, 08:42 AM
It means to make sure the trans shifts into 1,2,3,4,5th gear. (yes on a lift)
Since most of us dont have a lift, we Drive it around the block a few times. The key is to get it to shift into each gear to help transfer old fluid out and the new in
Old 02-04-2008, 09:32 AM
Lamborghini Aventador FTW
AMGala's Avatar
What is torque converter lockup?
Old 02-04-2008, 10:03 AM
wise2k's Avatar
I believe this is overdrive
Old 02-04-2008, 11:20 AM
No. thats 5th
TQ Lock up is kinda like a automatics clutch. The TQ converter is what allows you to be at a standstill with the motor running in gear. It helps transmit the power from the motor to the trans. Under pressure and rpm it goes from slip to lock.
If your cruising down the road (like 4th or 5th) and give it gas but not hard enough to change gears you will see the tach rise some, thats the tq converter unlocking.
Old 02-04-2008, 11:24 AM
Here some good reading
http://www.bankspower.com/Tech_understandtorqueconver.
Old 02-04-2008, 12:08 PM
mpg2034's Avatar
So correct me if I'm wrong, but isn't the above procedure the same as the 3x3 drain/fill method? (mind my ignorance)
Old 02-04-2008, 01:38 PM
SodaLuvr's Avatar
Yes, but it goes into further detail the driving you should do between each drain and refill.
Old 02-04-2008, 02:06 PM
Yes, but dealers have lifts and can do it without having to physically drive teh car any where
Old 02-04-2008, 02:24 PM
mcflyguy24's Avatar
Where do you get Acura "service news" from ppl? I googled to no avail.
Old 02-04-2008, 02:29 PM
SodaLuvr's Avatar
There's a sticky in 3G TL.
SodaLuvr's Avatar
Do not attempt to "drive" your car while it is on jack stands!
Old 02-06-2008, 09:47 PM
acitydweller's Avatar
I see there's no mention of changing the transmission filter located inside the transmission.
Old 02-07-2008, 07:38 AM
Yes, because its a NON serviceable filter. Only way to change it is to take out the trans and open it up. You do that, you might as well replace parts inside after going thru all that trouble
Old 02-07-2008, 09:31 AM
AMGala's Avatar
Thanks Kris! Just FYI, that link doesn't work, it's missing a couple of letters at the end. Here is the full address:
http://www.bankspower.com/Tech_under...ueconver.c f m (with the spaces removed between the c f and m)
Old 02-07-2008, 10:02 AM
Its the in the address (site thats blocked by ours)
Old 02-07-2008, 10:42 AM
T-Swzy
Razzi's Avatar
that's some good readin i tell ya
Old 02-07-2008, 11:14 AM
AMGala's Avatar
Yup, automatic site filter.
cobra10363
01-16-2021 08:12 PM
Mike Bertram
09-10-2015 09:27 AM
Allen_442
09-08-2015 06:01 PM
Quick Reply: Acura clarifies the definition of a transmission flush
