How do I check if a coil pack has gone bad?
Old 02-10-2007, 10:25 AM
Black TL's Avatar
Hi, I think one of my coil packs has gone bad. How can I check this at home?
Old 02-10-2007, 11:54 AM
On the way!
fla-tls's Avatar
Hmm - I don't know, but if I had to guess I would say you should check for continuity in the coil (to make sure it's not broken) and check each coils resistance as well. They should all be the same. If one is very different from all of the rest, I'd say it's probably bad.
Unfortunately I don't know what those values should be. Anybody else?
Old 02-10-2007, 12:28 PM
Registered User
Blazin_TL's Avatar
your engine usually mis-fires if a coilpack goes bad
Old 02-10-2007, 12:51 PM
Initial D
TunedTL's Avatar
Go to Autozone for a free CEL read. Swap a good one with the bad one and read the CEL code again.
Old 02-10-2007, 06:58 PM
Black TL's Avatar
I bought a new coil at the dealer and replaced one at a time to find the one that was failing. Of course, it was the 6th one I checked that was the culprit. I almost lost hope when I got to number 5. :-)
Engine runs fine now.
Thanks again
tonio
02-05-2019 05:43 PM
SpraykwoN
ILX
09-23-2015 11:44 AM
cali boy 91
09-19-2015 01:57 PM
PortlandRL
09-14-2015 12:01 PM
braveheart
09-07-2015 08:12 AM
Quick Reply: How do I check if a coil pack has gone bad?
