What does the codes P1706 and P0700 mean?
Old 05-11-2005, 10:13 PM
2doe's Avatar
Anyone knows these codes meaning? and how to fix?
P1706
P0700
thanks
Old 05-11-2005, 10:28 PM
TL no more!
WolfpackBill's Avatar
Ok...P1706 means that the tranny fails to shift other than 2nd-4th gears and lock-up clutch does not engage. The possible causes are either:
-disconnected A/T gear position switch connector
-open in A/T gear position switch wire
-faulty A/T gear position switch
IMO, take it to a tranny shop and see what the problem really is. It does sound like it's a bad tranny computer. Our '90 Accord had the same problem but no codes because there weren't OBDII computers. There were no first gear nor 4th gear. The problem was the tranny computer and the replacement was $300.
Old 05-11-2005, 10:29 PM
LDH
I
LDH's Avatar
P1706 has something to do with the automatic transmission and are you sure its P0700?
Old 05-11-2005, 10:37 PM
2doe's Avatar
yeah, there was two codes. I took it to the dealer to get it flushed about two months ago. Do you think something might have happened? it shift well. as far as I can tell. thanks guys
Old 05-11-2005, 10:54 PM
Ken1997TL's Avatar
P1706
P0700
thanks
P1706 is not in my book
P0700 is the Transmission Control System
Old 05-12-2005, 07:58 AM
808 TL Scene Photographer
MongooseDog's Avatar
hey does this mean that you guys have an FSM available for these cars? If so where did you pick it up?
Old 05-12-2005, 10:04 AM
2doe's Avatar
thanks guys, i will call the dealer and ask if it still under warranty, ie the emissions warranty
Old 05-12-2005, 11:45 AM
Haikoo's Avatar
Wishfull thinking....apples and oranges
I have the similar tranny problem. When the car is cold the shift from 1 to 2 is VERY rough and actualy kicks me back....but if I shift manualy from 1 to 2 it's smooth.
Old 05-12-2005, 12:36 PM
Ken1997TL's Avatar
No, but its a Chilton and has most of the stuff I need.
Old 05-12-2005, 02:02 PM
TL no more!
I have the Honda's service manual on cd-rom that covers 1st gen TL's. It's a great manual. I bought it on Ebay for like $25.
Old 05-12-2005, 03:30 PM
LDH
I
LDH's Avatar
I use shopkey5, which is like a helms manual for every car
Old 05-12-2005, 06:27 PM
oh ok nice. one more question I just got my bumper lights in do you guys know what the bulb codes are for them?
Old 05-12-2005, 07:51 PM
LDH
I
LDH's Avatar
194/168 for the outer peice and its either 7440 or 7441 which everone if a single filament.
*it's 7440 for the bigger peice.
Old 05-18-2005, 01:22 PM
Ysidro's Avatar
hi,
if it said tranny,
Is your d4 light burnt out? Or any of them? If it is try replacing them first.
If your car drives fine then it should be something else.
For me, its weird, my D4 light went out, the check engine light comes one. I then took it to First Acura dealer, they told me its somekind of transmission switch. It cost me $256 for labor and the part cost only $11 buck! They try to sound tecnical by saying its a transmission switch but infact its a fucking light bulb.
Old 05-18-2005, 09:08 PM
Haikoo's Avatar
Originally Posted by Ysidro
hi,
if it said tranny,
Doubt it.
The d4 lights are burnt out on most of our cars and theres no way it trigers the check engine light.
Next time get a code read first before you take it to a dealer if you're worried about being riped off.
Old 01-28-2013, 06:11 PM
spydercatt's Avatar
Check out this video to see how to change the switch out
Jamus22
06-11-2023 10:08 AM
MilanoRedDashR
10-02-2015 10:49 AM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
mars
09-28-2015 11:03 AM
Quick Reply: What does the codes P1706 and P0700 mean?
