Groundbreaking Info! Hack your Navi! (Change Pics, Remove Nag Screen) (Garage I-139)
Old 04-02-2005, 07:40 AM
9th Gear
opus's Avatar
Exclamation Groundbreaking Info! Hack your Navi! (Change Pics, Remove Nag Screen) (Garage I-139)
Is anyone following the navigation modification thread in the TSX forum? Will this work on our TLs? I really want to do the no-nag part of it.
Here's a link: https://acurazine.com/forums/showthread.php?t=21434
http://linuxkiddies.com/bysin/navi/
Edit mod: vp911
I am closing this thread since it is so large and unorganized. The new thread that datmrman created spells everything out and is excellent.
Refer to it here: https://acurazine.com/forums/showthread.php?t=129765
opus is offline
Old 04-02-2005, 09:54 AM
acuraTL44's Avatar
It should work with our TLs. The navigation systems should be pretty much the same. The TLs is just a bit more advanced.
acuraTL44 is offline
Old 04-02-2005, 10:39 AM
jastor3759's Avatar
I'm tryin' it. Nothin' better to do....
jastor3759 is offline
Old 04-02-2005, 12:27 PM
crazymjb's Avatar
Do you think you could put a moving gif in as the opening image. IE, my avatar?
crazymjb is offline
Old 04-02-2005, 12:36 PM
jastor3759's Avatar
got the background image to work. had to play with # of colors in Photoshop to get filesize <= old image.
As soon as my SH-4 disassembler finishes downloading, I'll see if I remember anything from my x86 assembler classes in college
Old 04-02-2005, 12:38 PM
jastor3759's Avatar
Not the way it works now. It REQUIRES a bmp, 480x234, max of 256 colors. I had to drop mine to 160 to work. DO NOT try RLE compression in Photoshop. The TL will just show a blank screen instead of your bmp.
Old 04-02-2005, 01:36 PM
Youse Gots Sacked
NFLblitze1's Avatar
so this works with TL?
NFLblitze1 is offline
Old 04-02-2005, 02:13 PM
Greg-ster's Avatar
^It's the same nav system. It uses the same disc. It'll work on the accord too...
Greg-ster is offline
Old 04-02-2005, 02:15 PM
abirvalg's Avatar
just did it
works fine
abirvalg is offline
Old 04-02-2005, 02:16 PM
Youse Gots Sacked
NFLblitze1's Avatar
did anyone encounter any problems?
Old 04-02-2005, 02:20 PM
jastor3759's Avatar
yep.
I finally opened navi.exe in a disassembler. YIKES!!! Hopefully Bysin or someone else will release a NO NAG patch.
Old 04-02-2005, 02:27 PM
Youse Gots Sacked
NFLblitze1's Avatar
this just replaces the start up screen where the acura symbol is with all of the stars and the planet?
Old 04-02-2005, 03:00 PM
acuraTL44's Avatar
Did anybody remove the nag screen on the TL yet?
Old 04-02-2005, 11:29 PM
Troublemaker
Turbowhat2's Avatar
changing the stuff on your computer was pretty straightforward. Just make sure u put the dumpnavi zip files into the folder where you can use the command prompt. Then just follow the readme. Also, make sure your new back.bmp is smaller than the original (130,000bytes).
Here is what mind will look like:
My car is in the garage and my parents are asleep and the alarm is set so i have to do the rebooting tmr.
Turbowhat2 is offline
Old 04-03-2005, 02:03 PM
darkseid2k's Avatar
I'm also interested to know if anyone tried this feature, apparently it's an option with the patch now. Anyone brave enough so far?
darkseid2k is offline
Old 04-03-2005, 04:18 PM
Team Anthracite Member
zax123's Avatar
I'm working on the nag screen fix right now. I found the place to modify the instruction using a hex editor. Just set address 0x0900 to 90h. When I save the file, it's the same size as the uncompressed file extracted from the BIN but when dumpnavi.exe tries to put it back into the BIN, the compressed size is 2 bytes bigger and I don't know why. I even tried the same thing with the TSX bin (BNHN404A.BIN) and it also compresses to two bytes more. That's where I'm stuck right now. If someone has figured this out, PLEASE HELP. Thanks!
zax123 is offline
Old 04-03-2005, 04:56 PM
nfnsquared's Avatar
He,he. What, parents keep the unlock code a secret from you? Damn alarms, no more sneaking out the bedroom window for late a night rendezvous any more (:
Nice work on the .bmp. I like it!
nfnsquared is offline
Old 04-03-2005, 05:17 PM
Troublemaker
Turbowhat2's Avatar
thanks. yeah i have the alarm where when i open a door or window, it beeps. Even when the system isnt armed. Plus if i disarm it, it takes about 1 minute to arm and the beeps are annoying and i dont know how to bypass the countdown.
Here is the picture on the navi screen
Old 04-03-2005, 05:35 PM
nfnsquared's Avatar
I have version 3.30C (early build '04 6MT). The disk only has 7 BIN files on it. Wonder if the TL only has 7 vice the 9 BIN files on the TSX? Anyone confirm for the TL?
Never mind, it just got answered on the TSX thread....
Old 04-03-2005, 05:36 PM
jastor3759's Avatar
There's 9. Be sure to count add.bin, zzz10.bin, and zzz100.bin
Old 04-03-2005, 05:38 PM
nfnsquared's Avatar
Yep, got it. Thanks.
Old 04-03-2005, 06:18 PM
crazymjb's Avatar
Thats awsome. If one say, wanted to keep the nag screen there, could it be edited so it was black and yellow striped and had warning written in red in the scenter, and then it was tapped to continue? Have something like Press enter to Execute program. Something cool. Not really purposful.
crazymjb is offline
Old 04-03-2005, 06:25 PM
nfnsquared's Avatar
aaarrrggg!!!! what am I doing wrong?
I've extracted the files, but when I run the update command line (dumpnavi BN2HH12C.BIN update back.bmp 2112.bmp) I get the error message:
Unable to find back.bmp on BIN
Old 04-03-2005, 06:32 PM
nfnsquared's Avatar
Never mind, it's Back.bmp, not back.bmp. Duh!
Old 04-03-2005, 06:35 PM
crazymjb's Avatar
I meant something like this, and you would select execute. I made this in paint so its crap, so sorry if it doesnt work. Also I am using photobucket so it may dissapear cause of bandwith issues.
crazymjb is offline
Old 04-03-2005, 06:55 PM
nfnsquared's Avatar
Works great! (Once I got the filename right..Duh!). If there are any Rush fans on this board, someone posted a nice 2112 bmp on the TSX thread.
Old 04-03-2005, 11:30 PM
Team Anthracite Webmaster
zeezz's Avatar
wow, this is exciting, groundbreaking stuff. what a genious guy.
zeezz is offline
Old 04-04-2005, 10:26 PM
rmastbro's Avatar
Acura NAVI hacked !!!!
Anyone interested in changing the startup boot screen image on the Navi should read this link !!!
In addition to changing the default Acura startup to a custom screen, there has been coding efforts to remove the dreadful 'OK' prompt that everyone seems to hate!!
A few people with 3G TL's have confirmed that it also works on the TL.
rmastbro is offline
Old 04-04-2005, 11:07 PM
Moderator Alumnus
rets's Avatar
Repost... Will MERGE later...
https://acurazine.com/forums/automotive-news-6/s4-cabriolet-112677/
rets is offline
Old 04-04-2005, 11:50 PM
714tman's Avatar
Confirmed - got the Dark Side of the Moon logo on my Navi now.
714tman is offline
Old 04-05-2005, 12:00 AM
zeezz's Avatar
here's the one i made, i'll repost it over. the aspect is compensated due to the fact that our screen doesnt use square pixels? haha, something like that.
for directions head over to the thread on TSX forums
zeezz is offline
Old 04-05-2005, 12:05 AM
bosoxfan's Avatar
wifi anyone?
tl recognizing cisco aironet card
bosoxfan is offline
Old 04-05-2005, 12:36 AM
Community Architect
robb m.
astro's Avatar
awesome awesome stuff.
stuck in here too.
go TL guys, GO!
astro is offline
Old 04-05-2005, 01:23 AM
Moderator Alumnus
rets's Avatar
Thumbs up
stuck in here too.
go TL guys, GO!
Good catch, you're always steps ahead of me...
Lots of info is what 3GTL'rs are looking for...
rets is offline
Old 04-05-2005, 01:59 AM
Does anyone read this
Donte99TL's Avatar
Cool I might need to do this....
Donte99TL is offline
Old 04-05-2005, 03:24 AM
.:KCCO:.
ayethetiense's Avatar
i was bored and made one too
ayethetiense is offline
Old 04-05-2005, 08:02 AM
x-mode007's Avatar
NAVI MODS from the TSX forum
I tried this mod last night and worked. It allows you to change the startup screen on your navi to any BMP you like.
x-mode007 is offline
Old 04-05-2005, 08:26 AM
cM3go's Avatar
How could I miss this? Great post! Gives me something to do!
cM3go is offline
Old 04-05-2005, 08:38 AM
cM3go's Avatar
https://acurazine.com/forums/showthread.php?t=112677
cM3go is offline
Old 04-05-2005, 09:05 AM
Team Nighthawk MechE
DarkWraith33's Avatar
Awesome
This is fantastic... We need somewhere to compile the 100s of kick aZZ backgrounds people are gonna make...
DarkWraith33 is offline
Quick Reply: Groundbreaking Info! Hack your Navi! (Change Pics, Remove Nag Screen) (Garage I-139)
