How to remove overhead console? - AcuraZine Community
Old 08-05-2004, 10:13 AM   #1
brandonb
Points: 9,342, Level: 64
Points: 9,342, Level: 64 Points: 9,342, Level: 64 Points: 9,342, Level: 64
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
I searched and the only hardwire V1 installs I found is where they ran the wires through the A-pillar. In my 330ci, I hardwired the V1 using the power from the moonroof, via the overhead console. Is this possible with the TL? I was wondering because I haven't found anyone who has done it yet? If it's possible, I'll probably try and do it tonight.
Thanks,
-Brandon
brandonb is offline   Reply With Quote
Old 08-05-2004, 10:14 AM   #2
soopa
The Creator
Points: 67,096, Level: 100
Points: 67,096, Level: 100 Points: 67,096, Level: 100 Points: 67,096, Level: 100
yes its possible... but if you run it through the apillar to the fuse box... you dont have to tap any wires.
easier.
soopa is offline   Reply With Quote
Old 08-05-2004, 10:38 AM   #3
brandonb
Activity: 2.4%
But the V1 comes with the hardwire kit which allows you to tap into the wires. You can just remove that wire tapper thing(I forogt what it's called) if you ever want to un-hardwire your V1.
I'll have to check it out.
Thanks,
-Brandon
Old 08-05-2004, 12:38 PM   #4
stocks2k
Points: 5,759, Level: 49
Points: 5,759, Level: 49 Points: 5,759, Level: 49 Points: 5,759, Level: 49
It definitely is possible, that is how I have mine wired. You have to take out the map lights and the reflector plates to get the screws out. That took me forever to figure out.
stocks2k is offline   Reply With Quote
Old 08-05-2004, 1:02 PM   #5
ITL
I do my own work.
2004 Acura TL
ITL's Avatar
Points: 10,852, Level: 69
Points: 10,852, Level: 69 Points: 10,852, Level: 69 Points: 10,852, Level: 69
Activity: 0.5%
Originally Posted by stocks2k
.....have to take out the map lights and the reflector plates to get the screws out. That took me forever to figure out.
so, how'd you get them out?
ITL is offline   Reply With Quote
Old 08-05-2004, 3:11 PM   #6
foot3ch
foot3ch's Avatar
Points: 8,164, Level: 61
Points: 8,164, Level: 61 Points: 8,164, Level: 61 Points: 8,164, Level: 61
Activity: 0.3%
Used V-1 (1999) for $275 or New Escort 8500 x50?
Do you think it's worth it to buy a used V-1 for $275? It was bought brand new in 1999. or Should I get Escort 8500 x50 instead? Thanks,
foot3ch is offline   Reply With Quote
Old 08-05-2004, 3:37 PM   #7
brandonb
Activity: 2.4%
Hey Stocks, any advice on the install? How did you remove everything? What wires did you use? Any help would be greatly appreciated.
-Brandon
Old 08-05-2004, 7:58 PM   #8
brandonb
Activity: 2.4%
Anyone have tips or a how to on removing the overhead console where the lights and sunroof controls are? I am going to hardwire my V1 up there. Any help would be appreciated.
Thanks,
-Brandon
Old 08-05-2004, 8:06 PM   #9
Aegir
Powered by Guinness
It consists of two sections - the 'switch and light section' and the frame. The switch section just pops out - there is one clip that hold it in, then disconnect the wiring harness connectors. The frame has four screws holding it in.
Aegir is offline   Reply With Quote
Old 08-06-2004, 8:57 AM   #10
stocks2k
Pop out the clear map light lenses with a butter knife then you have to "bend" the silver reflectors to remove them from the console. Remove the 4 screws holding the assembly to the roof. I don' remember what wires I used, but I think they were to the sunroof because my radar stays powered on until I open the drivers door just like the windows and sunroof. I just used a volt meter to find the correct wirs.
Old 08-06-2004, 9:28 AM   #11
brandonb
Activity: 2.4%
I got the light lense out, but I can not get those reflectors out. It's like they are glued in the middle or something. I can get the top and bottom edges out, but the middle is in there tight. I don't want to break something on a 2-day old car! Any advice?
Thanks,
-Brandon
Old 08-06-2004, 10:34 AM   #12
Ron A
Administrator
Ron A's Avatar
Points: 216,415, Level: 100
Points: 216,415, Level: 100 Points: 216,415, Level: 100 Points: 216,415, Level: 100
Activity: 44.8%
Activity: 44.8% Activity: 44.8% Activity: 44.8%
To remove the entire console: (Note: The Service Manual is confusing me here, because it looks like they give two different procedures, so I will give you both and you can use the one that works best for you. I don't have the ambition to try and remove my console just so I can see which works.)
Procedure #1: (Note: As reported by Aegir in the next post, this one works)
1. Remove the moonroof switch.
2. Carefully pull down the roof console.
3. Disconnect the 20P connector from the roof console.
Procedure #2:
1. Carefully pry off each lens with a small screwdriver.
2. Remove the 4 bolts securing the roof console.
3. Pull out the roof console, then disconnect the HFL unit connector.
If someone does this, let me know exactly which procedure you used and I will try and get the info into the 3G Garage.
edit added 7/14/2005:
Also see F-103: Visor area rattle (removal of SunVisor, map light console, front/rear map light)
http://tl.acurazine.com/forums/showthread.php?t=100981
Ron A is offline   Reply With Quote
Old 08-06-2004, 4:23 PM   #13
Aegir
Powered by Guinness
Procedure #1:
1. Remove the moonroof switch. (Note: As reported by Aegir in the next post, this one works)
Procedure #2:
It's basically Procedure 1, but even easier. Just pull the roof console from the frame. The two harness connectors can then be disconnected. It's that easy.
Old 08-06-2004, 10:05 PM   #14
Ron A
Administrator
Ron A's Avatar
Activity: 44.8%
Thanks for the info. I will edit my post to show #1 works.
Old 08-07-2004, 10:51 AM   #15
brandonb
Activity: 2.4%
I removed the lense covers and tried to remove the reflectors. When I pulled on them hard enough, the entire piece came out. Then all you have to do is remove the 4 bolts and the frame comes out.
-Brandon
Old 08-16-2004, 2:14 PM   #16
lstepnio
1337 H4x0r
Which wire are you guys tapping for ignition switched 12V+?
lstepnio is offline   Reply With Quote
Old 08-16-2004, 2:33 PM   #17
ITL
I do my own work.
2004 Acura TL
ITL's Avatar
Activity: 0.5%
Good question...I, also, would like to know what color wires so that I don't have to go out and buy another voltmeter (blew mine up on the sea-doo a few weeks ago...wasn't paying attention to what I was doing)
Old 08-16-2004, 3:36 PM   #18
brandonb
Activity: 2.4%
I used the power wire of the moonroof controls. It's the green wire on the very end. Hope this helps.
-Brandon
Old 08-17-2004, 8:49 AM   #19
ITL
I do my own work.
2004 Acura TL
ITL's Avatar
Activity: 0.5%
-Brandon
That's exactly what I was looking for. Thanks a lot.
Old 01-19-2008, 2:23 PM   #20
SansuiSteve
Love that TL!
SansuiSteve's Avatar
Points: 4,537, Level: 42
Points: 4,537, Level: 42 Points: 4,537, Level: 42 Points: 4,537, Level: 42
Switched 12VDC power in the moon roof console
Guys,
I though this may help. Remember the key is to get the moonroof switch out without damage. Use a feeler gauge to push the latch in and the switch falls out no problem. I will show the whole process below:
This is the feeler gauge. Whatever you use has to be thin enough to slip between the switch body and the moon roof console housing.
Insert the blade into the gap at the top of the switch body.
As you push the blade in the switch will pop out as soon as the latch disengages.
Pull the switch out and then detach it from the connector by pressing in on the center catch on the switch. This will allow the connector to come out. Once the switch is out pull down on the top of the panel from inside of the switch mounting hole and the whole panel will pop out. It only has one center mounted clip and comes out very easily.
The three wire connector that goes to the auto-dimming mirror is the best place to get power. Push the Invisicord probes into the back of the connector. You can see the red and white wire of the Invisicord coming in from the left side of the blue connector. Black is ground, Yellow/green is switched +12VDC from the ignition. You can use wire ties to secure the invisidord wire to the mirror power so the Invisicord connectors do not get pulled out.
I used mine for a radar detector, Itís a Done deal
SansuiSteve is offline   Reply With Quote
Old 01-19-2008, 2:29 PM   #21
ballinfizzle89
FizzyStatus!
2003 Lexus IS
ballinfizzle89's Avatar
Trader Rating: (6)
Points: 20,571, Level: 90
Points: 20,571, Level: 90 Points: 20,571, Level: 90 Points: 20,571, Level: 90
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Awesome!
ballinfizzle89 is offline   Reply With Quote
Old 05-24-2008, 10:49 AM   #22
elviscrc
-Brandon
In the Valentine1 vinstall, I tapped the yellow wire shown in the picture below to the right of the blue connector, and grounded to one of the screws that holds the headliner console, since they have washers. The green wire is only switched when the car is in reverse, and I am not sure why.
Thanks for the pics
elviscrc is offline   Reply With Quote
Old 05-12-2009, 4:58 PM   #23
ImPoRtHoNdA
My username is lame
ImPoRtHoNdA's Avatar
i have a question. does your guy's overhead console have rust in it? mine seems to have A LOT of rust.
hello there
ImPoRtHoNdA is offline   Reply With Quote
Old 05-12-2009, 9:30 PM   #24
dmarcus48
dmarcus48's Avatar
Points: 7,270, Level: 56
Points: 7,270, Level: 56 Points: 7,270, Level: 56 Points: 7,270, Level: 56
I removed the overhead console by popping out the dome lights, taking out the bulbs and the reflectors (be careful with those), this exposes 4 bolts, and the whole thing comes down. I used an invisicord to plug into the back of the green connector, the ground i just put under one of the bolts. I was very easy and works great, a plus is that it's powered with the key. It's very easy with the invisicord and I didn't see the feeler gauge option when I did mine, that looks really easy
2006 TL - Navi - Auto
Alabaster Silver Metallic/Ebony
Shaved Lock Mod
Shortened Door Lock Buttons
Splash Guards
Wheel Locks
Window Auto Up Mod
MusicLink
Acura Wood Gearshift Knob
Carbon Fiber front console kit
Weathertech Visors
All Weather Mats (winter)
Trunk Tray
Full Led Lights - Tec-Toyz
Multivex Mirrors
Super Protector Photo Radar Cover
Valentine One hardwired with an invisicord
dmarcus48 is offline   Reply With Quote
Old 05-16-2009, 4:46 PM   #25
MaxNewYorker
2004 Acura TL
Points: 1,605, Level: 23
Points: 1,605, Level: 23 Points: 1,605, Level: 23 Points: 1,605, Level: 23
http://www.in.honda.com/Rjanisis/pubs/SB/B05-020.PDF
MaxNewYorker is offline   Reply With Quote
Old 07-19-2009, 9:59 PM   #26
xcelir8TL
Modding my TL in
xcelir8TL's Avatar
Sorry to resurrect an old threat, but I decided after four and a half years to relocate my radar detector from the dash to under the rear view mirror.
I had some aluminum bars hanging around so I made a custom mount for my radar detector (going to upgrade soon). I basically bent a piece of aluminum and slid it between the glass and the overhead console and up towards the middle. I drilled a hole through the bar to the metal on the roof to secure it in place. I then covered the new bracket with black spray paint then the soft part of velcro.
Here is the result:
2010 Honda Pilot Touring AWD w/NAVI & RES
xcelir8TL is offline   Reply With Quote
Old 02-21-2010, 3:28 PM   #27
Joe Foe from Buffalo
Joe Foe from Buffalo's Avatar
Points: 5,092, Level: 45
Points: 5,092, Level: 45 Points: 5,092, Level: 45 Points: 5,092, Level: 45
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
Just hard wired my V1 today and have it suction cupped to the window near the rear view mirror. The pictures and details on how to remove the stuff to get power it made it so easy. FYI you can stuff the V1 connection block and wires on the hidden out of sight on the passenger side of the bracket that helps hold the center consul that is around the dome lights near the mirror. If you remove the four 8mm bolts that hold the plastic case behind the lights you will see what I'm referring to.
Joe Foe from Buffalo :-)
http://www.bikepics.com/members/joefoefrombuffalo/
Joe Foe from Buffalo is offline   Reply With Quote
Old 02-22-2010, 12:48 PM   #28
iodprod
Trader Rating: (1)
Points: 6,965, Level: 55
Points: 6,965, Level: 55 Points: 6,965, Level: 55 Points: 6,965, Level: 55
you guys are taking the overhead console the hard way!
on the right side of the white lights, you need a thin screwdriver.
stick it in the little crease next to the light and wiggle the whole center piece comes out in about 2 seconds!
then you can play with all the wires in there.
i just took it down to disconnect my hands free (pioneer double din will handle that)
took me about 4 mins flat.
iodprod is offline   Reply With Quote
Old 02-22-2010, 5:47 PM   #29
cjTL
I'm Craig
2014 Ford Fusion
My Garage
cjTL's Avatar
Trader Rating: (2)
Points: 10,768, Level: 68
Points: 10,768, Level: 68 Points: 10,768, Level: 68 Points: 10,768, Level: 68
Activity: 12.3%
Activity: 12.3% Activity: 12.3% Activity: 12.3%
Dumb question in 3...2...1. How does one go about tapping a wire?
cjTL is offline   Reply With Quote
Old 03-08-2010, 9:51 AM   #30
d-townhakuzo
d-townhakuzo's Avatar
Points: 6,956, Level: 55
Points: 6,956, Level: 55 Points: 6,956, Level: 55 Points: 6,956, Level: 55
Activity: 0.2%
Holy crap this is incredibly easy! I can't wait to do this to my Passport 8500 X50!
04 5AT UA6: (8/25/2009-3/3/2012)
09 6AT G8 GT: (3/3/2012-5/2/2013)
07 6AT e92 335i: ComfortAccess.Premium.Sport
.iDrive
d-townhakuzo is offline   Reply With Quote
Old 03-27-2010, 5:58 PM   #31
chinkwapin
.:dedicated:.
chinkwapin's Avatar
Trader Rating: (1)
Points: 7,293, Level: 56
Points: 7,293, Level: 56 Points: 7,293, Level: 56 Points: 7,293, Level: 56
Activity: 6.3%
Activity: 6.3% Activity: 6.3% Activity: 6.3%
hardwiring my V1 this way this weekend woot!
04 TL 6speed w/ nav
|ARC Winglets|Fujita CAI|GReddy Evo2|Function&Form Coilovers|OEM A-Spec|OEM Window Visors|iSimple iPod Integration|Blacked Out Headlights|OEM Type-S Decklid
chinkwapin is offline   Reply With Quote
Old 12-05-2013, 8:18 AM   #32
ShaneN.
Points: 557, Level: 11
Points: 557, Level: 11 Points: 557, Level: 11 Points: 557, Level: 11
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Potentially stupid question, but if your auto dim is turned off will the radar detector still get power? I hate auto dim, it's always turned off.
Originally Posted by SansuiSteve View Post
Guys,
ShaneN. is offline   Reply With Quote
Old 12-05-2013, 9:17 AM   #33
GKinColo08TL
2008 Acura TL
GKinColo08TL's Avatar
Points: 3,826, Level: 39
Points: 3,826, Level: 39 Points: 3,826, Level: 39 Points: 3,826, Level: 39
Activity: 0.4%
The lead to the auto dim mirror is still hot, you are turning it off with the switch on the mirror.
GKinColo08TL is offline   Reply With Quote
Old 03-27-2014, 7:09 PM   #34
Coveman
Points: 46, Level: 1
Points: 46, Level: 1 Points: 46, Level: 1 Points: 46, Level: 1
Activity: 3.1%
Activity: 3.1% Activity: 3.1% Activity: 3.1%
Great write-up, many thanks!
Coveman is offline   Reply With Quote
Old 06-15-2014, 11:17 PM   #35
VanyDotK
2013 Acura TL
Trader Rating: (4)
Points: 10,035, Level: 66
Points: 10,035, Level: 66 Points: 10,035, Level: 66 Points: 10,035, Level: 66
Activity: 16.3%
Activity: 16.3% Activity: 16.3% Activity: 16.3%
Would anyone happen to know if that line for the auto dimmer has enough power for a dash camera? The Valentine 1 takes about .5 amps, the dashcam I'm looking at takes 1.2 amps.
VanyDotK is online now   Reply With Quote
Old 06-28-2014, 12:32 AM   #36
JimEye
New Member
Points: 270, Level: 5
Points: 270, Level: 5 Points: 270, Level: 5 Points: 270, Level: 5
Activity: 0.5%
Great help - thanks. I wired in a 12 volt to 5 volt mini usb converter for dash cam. Worked great!
JimEye is offline   Reply With Quote
06, 1999, 2005, 2008, 8500, acura, bulb, console, escort, hard, install, kit, light, map, mid, overhead, removal, remove, tl, wire
Similar Threads
Check out this vette. 01SilverL Ramblings 14 12-15-2002 10:43 PM
Rumsfeld and Saddam - old friends. hemants Ramblings 15 09-24-2002 4:27 PM
Check out this one! Betty Ford Ramblings 13 08-28-2002 11:46 AM
