how can someone steal a car with the chip key??
Old 06-22-2001, 10:26 PM
darkalley's Avatar
Post how can someone steal a car with the chip key??
Doesn't the chip key protect the car from being started?? I know thieves are smart but if you have the chip how can they bypass it. (i know nobody on this forum is a thief but someone must know). Also, with the remote start do you lose the key chip protection totally?? I know if someone wants your car they can take it. Also, anybody know a great car alarm company in the Union, Morris or Essex county area???
Old 06-23-2001, 04:21 AM
SL1200MK4's Avatar
Post
Hum... I know that in HK, they actually use a laptop to open the door of the Mercedes S-class, and bam with in a minute the car is gone. So, I think it's pretty simple for them do decode or somehow crack the chip.
Of course, they are more likely to spend the time trying to crack the S-class instead of the TL.
Old 06-23-2001, 03:57 PM
Smile
If someone really wants your car, they will just tow it somewhere and then get into it
'02 TL-S WDP/Parchment NAV
Old 06-23-2001, 10:05 PM
thejavagod's Avatar
Post
my 2000 Honda Accord EXV6 was stolen last year and it is protected by the same engine immobilizer used in the TL/S. The car was found stripped about 30 days later, insurance investigation revealed that a copy of my key was made somehow...perhaps by a valet or at the stereo shop where I installed my Kenwood eXcelon amp and speakers. The immobilizer computer registered that my original key had started the car last.
BTW, I lost the amp, speakers and about 150 CDs - it sucks big time! never ever leave anything in your car, damn I'm pissed just thinking of it!!
Old 06-23-2001, 10:20 PM
Post
First of all even the laser cut benz keys can be duplicated if you know someone at the dealership. As for immobilizer chip system..take a look at the scene in Gone in 60 Seconds when they are stealing the Jag. I saw that little toy first hand and let me tell you can blink your eyn you, it reads codes faster that you can blink your eyes. As someone said before... if they want your car, even if its a benz, they will take it.
"TL is an awesome car" VW dealer in Long Island.
Old 06-23-2001, 11:33 PM
daverman's Avatar
Post
Does anyone know how the immobilizer key system actually works?
I know that the GM key system works using a simple (but effective) method -- precision-trimmed resistors. However, since there are few resistor combinations, you can actually "break the code" by trial and error. Also, you can read someone's "code" using a well-calibrated Ohmmeter.
Old 11-14-2005, 01:52 PM
I'm a llama :(
Motohip's Avatar
The part that's bolded is exactly my question. Please help because I had remote start with the bypass installed and now any old key works to start my car.
Old 11-14-2005, 02:00 PM
I'm a llama :(
Motohip's Avatar
I guess I shouldn't advertise this...
Old 11-15-2005, 12:50 PM
2007AcuraRL's Avatar
When I installed my system, I used a transponder bypass module which learns the code in your key and sends this code as a pulse to the ignition when remote starting.
Old 11-15-2005, 06:44 PM
I'm a llama :(
Motohip's Avatar
So since it's pulsed, it only sends the signal when remote starting. With the older transponder systems you actually need the key, but it should still work the same way. In case anyone else needs to know, the answer is yes, you should still need a chipped key.
Old 11-15-2005, 07:14 PM
two miles an hour
kcblack02tl-s's Avatar
i want a remote start alarm on my tl. and a friend of mine claimed that they can bypass the alarm so that you no longer need a key in the dash for the remote start to work. Is that the same bypass your talkin about or am i off?
Old 11-15-2005, 08:17 PM
Horny.
TXXXX's Avatar
That "chip" is essentially a resistor, if the resistor value matches, then the car will start.
Yes, the installer can bypass that "chip".
Old 11-15-2005, 08:33 PM
prjctTL's Avatar
is the key self powered?? like with a battery in the black part of the key?? how does the immoblizer work??
Old 11-15-2005, 09:12 PM
big mike 13's Avatar
thieves...
Old 11-15-2005, 11:38 PM
two miles an hour
thnks now i feel better about getting the Viper Remote start
now to get somebody to install that bypass
Old 11-15-2005, 11:55 PM
NiGhT rIdEr
bkzjimmy's Avatar
go reallly far from where u live to get it installed!
Old 11-16-2005, 12:01 AM
bx-tls's Avatar
I was told about it and how there is a way to program even the keys to decode any car. never ask in dept how, but now..................i'm curious as to how
Old 11-16-2005, 12:45 AM
two miles an hour
my bad for hijacking the thread but
im too lazy to go far away ive been told that its pretty dangerous to do the bypass without the key in the dash but im gettin anxious
Old 11-16-2005, 06:53 AM
Horny.
TXXXX's Avatar
The black part is the resistor. Resistors are passive devices, no power unless you attach a battery or some sort of power to it.
The immobilizer is on your car, it is "chip" (black thing, resistor) on your key matches that value, the car will start. The immobilizer disable something, most likely something electrical.
Old 11-17-2005, 04:00 PM
OntarioTL's Avatar
I know that all too well. My 300M was stolen that way on a flatbed just last year. Bastards!!!!! My car was never recovered.
Now I have a TL-P, fingers crossed it wont happen again. I thought about getting Boomerang 2 (lo-jak) installed just in case.
OntarioTL
Old 11-20-2005, 12:01 PM
I'm a llama :(
Motohip's Avatar
I think with this year TL, you don't need a key in the module. If you do though, just cut off the key part.
Old 11-22-2005, 01:55 PM
two miles an hour
thanks for the info probably gonna get it done b4 christmas if its not stolen yet
Old 11-22-2005, 03:57 PM
I'm a llama :(
Motohip's Avatar
Better hurry before your car becomes someones Christmas present.
Old 03-09-2011, 05:51 PM
2007 6SMT Type-S
SurfingScotty's Avatar
(Arg!) My Carfax report says my car had LoJack installed at the dealer. Is there a way to use it, as I bought the car used from a stealership?
Old 03-09-2011, 05:58 PM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
holy thread revival batman!
ur in the wrong town buddy ur 1st gen this is 2nd gen
Old 03-09-2011, 06:07 PM
TRIUMPHT's Avatar
lol i was just about to say ..they pull up with a tow truck and drive off with it .the first thing that comes to peoples minds when they see a tow truck towing is either you didnt make your car not or you owe alot of tickets
Old 03-09-2011, 06:15 PM
Rich and Famous
EL_PIC's Avatar
Yea - the dealer charges $100 for the blank and another $100 to program it.
Any questions ??
Old 03-09-2011, 07:19 PM
MechEng
03tLsNBP's Avatar
^ you are responding to a question that was asked 10 years ago.
Old 03-09-2011, 11:22 PM
Unregistered Member
Karanx7's Avatar
Better late than never... Well maybe not.
Old 03-10-2011, 01:01 AM
silvertl510's Avatar
well, i know the answer now haha. or anybody else who reads after me
Old 08-20-2011, 05:18 PM
kill you till you die
yeedatoy's Avatar
You get a jumper harness and run a different ECU, start the car with a jig key and drive away. It may run like shit, but its still runs. Car stolen. K-SERIES cars are stolen using ECU's programmed with K-pro so the immobilizer is disabled, best thing you can do it use realtime GPS tracking.
tman570
06-11-2019 07:56 AM
HairyMonkey019
04-22-2016 10:50 PM
cm561
01-27-2016 10:17 PM
nanos
11-12-2015 08:41 PM
Quick Reply: how can someone steal a car with the chip key??
