Car ran hot won't start
RODDYS
What up guys as u know I sold my car two weeks ago and the guy that bought said he was on his way to work and the car ran hot and broke down and now it won't start any suggestions. He said it had oil and radiator coolant all fluids are good. I never had any problems out of it and never heard of any one here having a running hot problem. Just wonering
If he has oil in his coolant or coolant in his oil then it's a blown head gasket which will occur if the car overheats. Does the car crank over? Or does it not start? How far did it overheat? If it overheated a lot why didn't he pull over and turn the car off? Need more symptoms.
01 CLS
RODDYS
Well he said it will turn over but that it won't crank. None of the fluids are a problem they are all fine. He said that it went all the way into the red before he pulled over cause there was traffic so I don't know thats all I know for now. He was asking about something that looked like a sensor near the fuel filter and it had denso on it. Don't know why he would ask about that so thats all I know for now
Do you know this person? Or is he just some guy that bought your car? If you know teh guy then help. If you don't......Why are you invloved? It's not your car, you have no reason to care.
I'd be pissed if someone that bought a car from me started to hassle me about problems he now has.
Once the car leaves your hands you have no idea how it's treated.
I'm here in spirit...
It's no longer your problem unless you make it your problem. It sounds like a blown head gasket to me too. If I remember correctly when my mom's car blew it's head gasket, there wasn't any mixing of fluids. Everything looked normal. The coolant wasn't circulating, the car over-heated and that was that.
saberlove
03-11-2021 09:29 AM
