How do I clean the Idle Air Control valve? - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine CL Community > Second Generation CL Discussion
Old 05-27-2004, 3:37 PM   #1
Tosh
Eurotrash
2001 Acura CL-S
Points: 10,166, Level: 67
Points: 10,166, Level: 67 Points: 10,166, Level: 67 Points: 10,166, Level: 67
Activity: 4.0%
Activity: 4.0% Activity: 4.0% Activity: 4.0%
It seems there's an epidemic of idle speed related problems that are caused by a dirty or sticking or defective IAC valve. I'm getting a bit of a stumbling idle on my 2001 CL-S, and I want to clean the IAC valve.
A long time ago, after the car had sat for almost a week during cold weather, when I started it up, it started surging between about 600 and 2500 RPM. I called the dealer and headed toward there, but by the time I got there it had cleared itself and never happened again. But the service writer said that it was most likely the IAC valve, but he wouldn't change it unless he could duplicate the problem. And now it's out of warranty....
So, it looks like I need to remove the battery to get to it, but I would rather have someone who knows how to do it describe the proper procedure. And pics would be a big help. I even think this could be a Sticky. Thanks!
Tosh
Tosh is online now   Reply With Quote
Old 05-28-2004, 8:09 AM   #2
scalbert
scalbert's Avatar
Points: 19,992, Level: 89
Points: 19,992, Level: 89 Points: 19,992, Level: 89 Points: 19,992, Level: 89
One easy way may be to spray some carb cleaner into the TB while it is running. It might stall on you but doing this a few times should help.
scalbert is offline   Reply With Quote
Old 05-28-2004, 8:30 AM   #3
SiGGy
SiGGy's Avatar
Points: 18,789, Level: 86
Points: 18,789, Level: 86 Points: 18,789, Level: 86 Points: 18,789, Level: 86
On my GF's Mitsubishi galant I took apart throttle body and cleaed it out with carb cleaner. Took me about 2 hours.
I haven't had to do the CLS yet...
SiGGy is offline   Reply With Quote
Old 05-28-2004, 8:57 AM   #4
fender4
Points: 11,001, Level: 69
Points: 11,001, Level: 69 Points: 11,001, Level: 69 Points: 11,001, Level: 69
or first fill up at chevon and put in a bottle of chevon techoline (sp) injector cleaner... After one tank I bet your problem will go away..
fender4 is offline   Reply With Quote
Old 05-28-2004, 9:01 AM   #5
scalbert
scalbert's Avatar
If it is the IAC then a fuel additive won't help. Fuel doesn't get anywhere near the TB.
Old 05-28-2004, 9:41 AM   #6
fuzzy02CLS
fuzzy02CLS's Avatar
Trader Rating: (2)
Points: 34,910, Level: 100
Points: 34,910, Level: 100 Points: 34,910, Level: 100 Points: 34,910, Level: 100
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
I took the tb off & sprayed carb cleaner all over it. It helped for a few days, then the car ran tha same again. I think mine is bad.
If the IAC is bad would it send a code? I have no codes on my car stored or otherwise.
fuzzy02CLS is offline   Reply With Quote
Old 05-28-2004, 9:51 AM   #7
fender4
Yaaaa,,, I know I was just trying to fix the easy things first..
Old 05-28-2004, 9:52 AM   #8
scalbert
scalbert's Avatar
If it completely failed or was seriously bad it would set a code.
Old 06-07-2004, 3:17 AM   #9
Tosh
Eurotrash
2001 Acura CL-S
Activity: 4.0%
Anyone with good instructions?
First of all, it looks like the battery may have to come out to get to the IAC valve....
Anyone with firsthand experience in cleaning it?
Old 06-07-2004, 7:52 AM   #10
fuzzy02CLS
fuzzy02CLS's Avatar
Trader Rating: (2)
Activity: 4.1%
:sqnteek:
The IAC value is attached to the TB. The TB comes off then the IAC comes off the TB, or you can try to get it off the TB while it's still on the car. The air hose & some conencters get moved, the throttle cable gets taken off & then just unbolt the TB. It's rather easy.
Old 07-11-2004, 9:21 PM   #11
Tosh
Eurotrash
2001 Acura CL-S
Activity: 4.0%
Anyone else?
It seems easiest to just leave the TB in place, right? So if I don't want to remove the TB and all the hoses, will I need to remove the battery first? Otherwise it doesn't look like there's room for the IAC valve to come off....?
Fuzzy, you say it's rather easy, but it doesn't seem that you were actually successful in cleaning the IAC valve. You just sprayed carb cleaner all over...
I think I would like more detailed instructions.
Old 07-12-2004, 8:30 AM   #12
sundance_gold
What does it cost to have someone (the dealer) replace the IAC?
sundance_gold is offline   Reply With Quote
Old 07-12-2004, 10:26 AM   #13
fuzzy02CLS
fuzzy02CLS's Avatar
Trader Rating: (2)
Activity: 4.1%
It's a $85 part plus labor.
Spraying carb cleaner on it is the way to clean it. I also used a q-tip. After you take the TB off, you can remove the IAC valve.
Old 09-25-2004, 6:51 PM   #14
Tosh
Eurotrash
2001 Acura CL-S
Activity: 4.0%
More help, please
Wouldn't I be better off removing only the IAC valve from the throttle body without removing the whole TB from the intake?
2001, 2003, acura, air, cl, clean, cleaning, control, galant, iac, idle, mdx, mitsubishi, stumbling, valve
