2G CL Frequently Asked Questions No New Threads Please.
Reading Check Engine Codes - NO DEALER OR AUTOZONE REQUIRED!
Old 03-09-2004, 12:31 AM
VOTE OUT THE BUSH REGIME
AK_MOBBER's Avatar
1. Jumper the service connector
2. Turn the ignition key to ON
3. Count the flashes on the instrument panel
4. Look up what the code means
the flashes will be a series of long blinks, a pause, followed by short ones. For example:
Long-Long-Long-Long-Long-Long-Long____ShortShort
7 long and 2 short, indicates a code 72, Cyl #2 misfire.
Once you've got the code, you should have a pretty good idea of exactly what the problem is. You can troubleshoot from there.
after putting my oil pan back on my 98 V6 accord I started it up and the check engine light came on. I used a paper clip and the above method and read a code 65... Secondary O2 sensor. Apparently while moving the exhaust to get to the oil pan I accidently pulled out the connector for the O2 sensor for the catalytic converter.
Reconnected it, reset the ECU and the check engine light went away!!
I didn't even have to leave my garage!!
Old 03-09-2004, 04:19 AM
Adventurist.
NiteQwill's Avatar
This belongs in the ARCHIVES!!!
Good info!
Old 03-09-2004, 04:30 AM
I miss my 03 CL-S :(
einsatz's Avatar
Very nice. I agree... put this in useful topics asap!
Old 03-09-2004, 04:51 AM
I'm late.
goldmember's Avatar
I third that.
Old 03-09-2004, 05:37 AM
Poppin them thangs
G-UNIT's Avatar
BINGO...good job...st-st-st-sticky it
Old 03-09-2004, 10:07 AM
GreenMonster's Avatar
The good old paperclip and count the flashes works on most OBD cars. Just gotta find the documentation for what the codes mean.
Great Reference
Old 03-09-2004, 10:24 AM
Sold but not Forgotten...
babyblue's Avatar
excellent post bro...
Old 03-09-2004, 10:46 AM
Chaptorial's Avatar
Awesome post.
Old 03-09-2004, 10:57 AM
AK_MOBBER's Avatar
I found it v6p.net while looking for a way to reset the check engine light.
Even though my asian honda tech would check it out for free I was happy not having to drive anywhere.
I'm sure it will help someone!
Old 03-09-2004, 12:34 PM
JakeCL's Avatar
i just use this
plus i can get a bunch of other info out of this thing too like
RPM
Throttle position
Engine load
Fuel pressure
Fuel system status
Short- and long-term-fuel trim
Battery voltage
Timing advance
Coolant temperature
Air flow rate
Intake air temperature
Intake manifold pressure
Oxygen sensor voltage
all for less than 200 bucks
Old 03-09-2004, 12:43 PM
KissMy_Type_S's Avatar
WOW ... That is fuckin beautiful
Old 03-09-2004, 01:53 PM
[DWI]'s Avatar
Originally posted by JakeCL
i just use this
RPM
Throttle position
Engine load
Fuel pressure
Fuel system status
Battery voltage
Timing advance
Coolant temperature
Air flow rate
info? link?
Old 03-09-2004, 03:54 PM
Adventurist.
NiteQwill's Avatar
Originally posted by [DWI]
info? link?
http://www.davisnet.com/drive/produc...p_products.asp
Old 03-14-2004, 08:06 PM
EricL's Avatar
Great Reference
Here is a "free" reference lookup site. You just put in the OBD II code in, and it will return with a definition. (BTW, it's free, so if it doesn't find some oddball definition, remember the cost...)
http://www.iequus.com/obd_def.asp
Off to the archives...
Old 07-27-2004, 07:40 PM
JoeLogic's Avatar
JackCL can you view the info from the carchip in realtime. Or does it have to be downloaded to a pc.
Old 07-28-2004, 09:00 AM
mrsteve's Avatar
Okay i've been trying to do this but the flashes I get don't correspond with anything listed. I get 5 long flashes from the Check engine light. I also get flashes from the ABS light. 9 longs _ 3 Short... then 3 longs_ 5 short
Help
Old 07-28-2004, 11:44 PM
9th Gear
ankit_RENAMED's Avatar
Great... Service Connector?
Wow all fantastic stuff...
OK but the thing is I can't find the service connector.. I'm a pure newbie. I just bought this car 3 weeks back with 105 K miles on it. And right after an oil change at walmart my Check Engine light came on (10 days back)
I read this post and some other ones and figured that the service connector is behind the glove box somewhere but I couldn't find it
Can someone help please?
Thanks...
Old 07-28-2004, 11:45 PM
mrsteve's Avatar
It is between the seat heater switches, under the 12v accessory. You remove a small plastic cover.
Old 07-28-2004, 11:58 PM
9th Gear
Sorry I guess I forgot to mention it's 97 CL 2.2 Premium... it doesn't have heated seats. But anyway I couldn't find it under the 12 v accessory...
Old 07-29-2004, 12:04 AM
mrsteve's Avatar
Opps.. then I have no clue.
Old 08-20-2004, 01:08 PM
8th Gear
oxromeoinlovexo's Avatar
i got a po130 code so wat exactly am i suppose to do? i checked the o2 sensor behind the catbak and it looks fine, but the check engine light is still on. it came on after i got my exust system changed... is the primary o2 sensor the one in the front or the one in the bak? i'm a total newbie so any help would be very thankful... oh yeah... and i have to get my car inspected soon u think i would pass with the check engine light on?
Old 06-02-2005, 08:00 PM
xenolite's Avatar
Just to let everyone know:
Code 16 (1L6S) = missfire
I had to pay the dealer to find that out.
Old 06-06-2005, 11:29 AM
Sig Rho's Finest
NYZGREATST's Avatar
do i need to put the paperclip in the specific holes as pictured or can i put it anywhere?!!? THIS IS GREATTT THANK YOUUUUUUUUU
Old 07-02-2005, 07:30 PM
civicking's Avatar
i think its under the dash on the drivers side.
Old 07-13-2005, 05:21 AM
CLS-PL's Avatar
It's been probably posted somewhere on the forum, but could be useful here.
Last week a Check Engine Light came on while driving. My car has 39k miles.
Some 500 miles ealier my tank cap was stolen on Shell
I bought there a new one, but as it turned out later it didn't match perfectly to the inlet. I used a tape to seal it - to no avail. According to owner's manual, after 3 trips the light should die out after sealing the inlet.
So I did a test described above.
It showed misfiring on all 6 cylinders !!
If it was true the car would shake like an old diesel during startup and immediately die. My car was driving fine. I was almost sure it was related with improper fuel cap and emission systems.
So I simply disconnected the + from the batteries, went to work, reconnected it and the Check Engine Light didn't flash anymore.
I did it al after a consultation with an Acura employee.
In majority of cases CEL shows up just to bug us that emission system detected some slight "deviation".
Greetings
PS. Of course I need an original Acura tank cap.
Old 07-30-2010, 06:44 PM
benR's Avatar
Hi everyone! I'm a newbie to the board and just picked up a 2003 3.2 CL Type-S, MT after losing my jdm fronted, turbo'd integra in an accident.
Anyways, the CEL just popped up so I'm trying to pull the code but can't locate the service connector. I believe I've found the OBDII diagnostic connector under the dash on the driver, right side, but is there a 2-pin service connector that I can jump with a paper clip to pull the code like my old Integra did? If not, is there a way to jump the OBDII connector w/o shorting anything out? The pics are dead in this thread.
Old 12-01-2011, 01:48 PM
RAin geAR's Avatar
which pins need to be jumped?
is there a link to a list of error codes?
thanks!
Old 02-17-2012, 02:41 PM
570berg's Avatar
does anyone know which pins? this is the only thing i could find on google and the pics are dead...
Old 02-17-2012, 05:45 PM
570berg's Avatar
found it:
IT'S PINS 4, AND 9
THIS COVERS ALL OBDII VEHICLES.
TURN ENGINE OFF FIRST.
acura rsx type s k20z1 k20 k series dc5 ep3 honda civic si
The following 2 users liked this post by 570berg:
civicdrivr (02-18-2012), Gottsby (05-01-2014)
Old 02-17-2012, 05:49 PM
570berg's Avatar
sources cross referrence
http://www.k-series.com/tech_document.php?id=37
http://www.ehow.com/how_2214653_read-obd2-codes.html
http://www.honda-tech.com/showthread.php?t=2760775
"acura rsx type s read engine codes with using paper clip"
paperclip, obd, obd2, 2, ii, obdii, trouble codes, diagnostic codes, without scanner, diy, flashing, blinking, dash code, codes, check engine light, cel, ecm, pcm, ecu, emc, ems, diagnostic trouble codes, dtc, honda
civicdrivr (02-18-2012), Ron A (02-17-2012)
Old 02-18-2012, 10:32 AM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,134 Likes on 4,804 Posts
Nice job searching
However, the k-series forum link says to pull fuse #6 in the engine bay fuse box. In the CL, it is fuse #13 in the passenger side fusebox, a 15amp fuse for the clock. You will not lose your radio presets this way, but you will need to reset the clock.
Ive got an old bluetooth OBDII reader that doesnt work, Im going to strip it and jump those two connectors so I can easily plug in whenever a code needs to be read.
Old 02-27-2012, 07:14 PM
StreetKA's Avatar
nice job but basic scanner costs like $25-30 shipped on amazon i would be to lazy to go there jump it and count the flashes but for each their own and DAMN you got a thanks from RonA ohhh god im so jealous !!
Old 01-19-2013, 03:55 PM
6klub's Avatar
Had my transmission replaced with an 05 Honda Oddessy and when I got it back yesterday my CEL was on. I used the pull the # 13 fuse method and it worked! Thanks for the help.
MikeYutkin
09-10-2015 10:13 PM
Bahamanurse1
09-10-2015 10:05 PM
whitesoxsfan12
09-07-2015 04:07 PM
eastcoastguy
09-04-2015 06:44 AM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: Reading Check Engine Codes - NO DEALER OR AUTOZONE REQUIRED!
