Green stuff around battery connections
Old 03-31-2002, 01:00 PM
CWdub's Avatar
I was taken some pictures of my intake and notice there is a green stuff around the battery connections. Does anyone know what this is. I have posted a picture in the gallery under the subject of Silver Type S with Comptech springs.
Is that a bad thing to have that stuff on there or should i just wipe it off.
Thanks for the help
Old 03-31-2002, 01:22 PM
FDao's Avatar
Re: Green stuff around battery connections
Thanks for the help
You should wipe it off and apply grease around the area to minimize future "oxidative" events. It tends to sap your battery discharging capacity, if I remember correctly.
Old 03-31-2002, 02:12 PM
Dan
Dan's Avatar
Disconnect battery. Mix some baking soda with water, and using a brush scrub everything clean and rinse. Let dry and reconnect battery. Some autopart stores sell anti-corrosive pads that fit between the battery and cable that work well to prevent this from happening again.
Old 03-31-2002, 02:22 PM
EricL's Avatar
That green stuff is what happens when battery acid and copper mix.
The seal around the battery post could be "weeping" acid. The only real fix is to get a new battery.
Yes, the pads from "Sears" (those ones filled with red goop) work great for a while. However, some "brutes" like to "wail" on the battery terminals and this breaks the case around the battery posts. The acid keeps coming and coming and it gets pretty expensive to replace the wiring...
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
gatrhumpy
19
12-31-2015 04:22 PM
jpadilla
3G RLX (2013+)
09-27-2015 07:53 PM
Quick Reply: Green stuff around battery connections
