Anyone know where the oxygen sensor is located?
master of ????
Hey I got my Air/Fuel gauge in today and I was wondering if anypne knew where the O2 sensor is located. I think it is right after the headers but I have not looked yet? I need to tap into the white wire on the harness comming from the sensor for my gauge to function.
Anyone done this on our car yet? Any advice.
It's easy to do on other cars so I don't think a CL will be too bad.
thx
thx
Actually there is two oxygen sensors on the CL. The primary oxygen sensor is in the headers and the secondary O2 sensor is on the catalytic convertor.
In order to install the A/F gauge you must splice into the white wire on the primary O2 sensor located on the headers. Easy install should take you less tha 30 minutes, atleast thats how long it took me. Good Luck
Originally posted by niedejb
You could tap prior to the ecu in the cabin too.
Swaps? $3000 for 50HP? :(
The O2 sensor is the 16P connector (the gray one on the left in the pic above) the white/red wire in the middle row of the three on the connector, all the way on the end toward the blue connector.
X XXX X
OXXXX<-this is the green/white wire in the pic.
XX X
The "O" should be the one you need (white/red)
X XXX X
XX X
08_UA7_Gr33k
02-11-2016 02:17 PM
