Battery Drain/2nd battery.. Opinions?
Old 07-16-2003, 11:35 PM
I've been marked.
shaolin's Avatar
I have a 3000w D-Class amp running to my battery and also some neons on the inside, and underbody's (ricer.. yes i know =p).
But i'm still using the stock battery and today it just completelly drained on me..
I'm figuring to get a Optima Yellowtop battery for the car, but also I was thinking about taking out that battery and charging it, but also keeping it and mounting all my lights to it and just running my system off my car battery and my car of course..
But I'm not too sure of how to run a 2nd battery from lets say the trunk or so.. anyone ever done it before, or know where I could find out how to?
Or any other opinions?
Old 07-17-2003, 02:11 AM
BigPimpin's Avatar
use a capacitor
You would probably be better using a capacitor it will be a cheaper setup
Old 07-17-2003, 09:28 AM
JaySyn77's Avatar
Go to the forums at SoundDomain.com and read about batteries. You have to be careful on what type of battery you put in the trunk, because same are known to let off fumes.
Old 07-17-2003, 09:45 AM
KyleWatson's Avatar
The second battery is only going to have no effect on the system while the car is running. If you want to add the second battery you'll need a battery isolator, the rest is pretty self-explanatory.
Old 07-20-2003, 02:56 PM
Flap.
Hobo's Avatar
go with a good cap
Old 07-20-2003, 10:03 PM
N.O. Accorderz's Avatar
caps are worthless...upgrade ur wiring from the alt and batt to ground...it helps a lil...get a higer output alt. and a second batt for playing time only...get a yellow top and put it in the trunk...its made to be charged and discharged only not for starting a car...thats what the red top is for...
Old 07-20-2003, 11:28 PM
Fuct in the hed!
Nicky Pass's Avatar
You probably need a higher amperage alternator. Like Kyle said....a second battery would be good if you show the system with the car not running. Caps are not worthless....they keep a constant voltage to the amplifier its in line with.
MetalGearTypeS
08-29-2016 08:28 PM
adrian_s2k
1G RDX (2007-2012)
23
01-12-2016 04:25 PM
SilverJ
4G TL Problems & Fixes
15
10-13-2015 05:14 PM
swany0095
2G TSX Performance Parts & Modifications
10-07-2015 02:18 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: Battery Drain/2nd battery.. Opinions?
