Notices
Parts Search
Keyword:
Category:
Price:
Location (State/Prov/Terr):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Location (State/Prov):
SOLD: 18" Enkei m52 Rims w/ BF Goodrich Gforce Comp2 A/S
Old 11-29-2016, 08:41 PM
hyperview's Avatar
Category: Wheels & Tires
Price: $950
Location (State/Prov/Terr): NJ
Item Condition: Used
225/18/50
5 x 114.3
50 offset
Had on Acura for a couple of months
Flawless condition both rims and tires....
no curb rash or scratches and tires have basically no wear
firm on price
Attached Thumbnails 18" Enkei m52 Rims w/ BF Goodrich Gforce Comp2 A/S-008.jpg   18" Enkei m52 Rims w/ BF Goodrich Gforce Comp2 A/S-006.jpg   18" Enkei m52 Rims w/ BF Goodrich Gforce Comp2 A/S-007.jpg   18" Enkei m52 Rims w/ BF Goodrich Gforce Comp2 A/S-005.jpg   18" Enkei m52 Rims w/ BF Goodrich Gforce Comp2 A/S-010.jpg
18" Enkei m52 Rims w/ BF Goodrich Gforce Comp2 A/S-011.jpg   18" Enkei m52 Rims w/ BF Goodrich Gforce Comp2 A/S-009.jpg
hyperview is offline
Old 12-02-2016, 09:17 PM
hyperview's Avatar
Friday night bump..... These are like new rims and tires......unbelievable grip
great wheels for winter
Old 12-02-2016, 10:31 PM
champaned_out's Avatar
might want to add the width of the wheels
champaned_out is offline
Old 12-03-2016, 09:11 AM
hyperview's Avatar
Rim is 8 x 18
thank you.....
Old 12-04-2016, 08:54 AM
hyperview's Avatar
$1000 now ..... Not one bit of curb rash or wear
mod edit-updated
Old 12-11-2016, 09:58 AM
hyperview's Avatar
Found pic of wheels on my TLX
Old 12-11-2016, 10:00 AM
hyperview's Avatar
Old 12-19-2016, 01:37 AM
Soal Man's Avatar
Car looks clean. I'm surprised no one's biting on the Enkei's with the G force comp's. GLWS
Soal Man is offline
Old 12-19-2016, 11:53 AM
hyperview's Avatar
yea, they are definitely a clean combo, truly without a blemish but I'm in no rush to sell so we'll see
thanx
Old 12-20-2016, 02:22 PM
I like cars.
Username 0's Avatar
I would of jumped on these but the tires are to tall for my cu2 and your local. Glws
Username 0 is offline
Old 12-23-2016, 09:08 PM
hyperview's Avatar
Thanx..... I figure to sell them eventually....
Old 01-07-2017, 02:13 PM
chrisTL-s's Avatar
Will these fit on 3rd gen tl
chrisTL-s is offline
Old 01-07-2017, 05:41 PM
hyperview's Avatar
Looking at tire rack ...... Looks like they do as both 3rd gen tl and TLX both use a 5x114 lug pattern
concerning offset the TLX uses a 50 mm offset while your tl uses a 45 mm offset ...... So I don't think a 5 mm offset difference makes it not able to fit...... Anyone else chime in on this?
Old 01-15-2017, 10:10 AM
hyperview's Avatar
So these wheels do fit just about all the TL,CL and TSX models.... Apparently Acura uses the 5 x 114.3 lug pattern for most models
this website shows all the manufacturers who use this pattern ....... Ford, Infiniti, etc......
roadkillcustoms.com
just enter the pattern in # of lugs (5) and spacing in mm (114.3)
would a moderator be kind enough to change my price from $1000 to $975
thanx
mod edit-updated
Old 01-15-2017, 01:01 PM
Administrator
Ron A's Avatar
Did you use these on your TL or some other car? Just asking to make sure the centerbore will fit our cars.
Ron A is offline
Old 01-16-2017, 11:54 AM
hyperview's Avatar
Ron
were on a 2.4 TLX btw.
centerbore on these wheels are 72.6
and they will fit TL, TSX, and CL
I have my order number from tirerack so any potential buyer can call tirerack and give my order number to confirm fitment on the car they want to put them on ( just to make 100% sure)
thanx
Old 01-16-2017, 12:18 PM
hyperview's Avatar
Ron
forgot to mention......
most aftermarket wheels as per tirerack will have a centerbore that is LARGER than the hub that the wheel is going onto but they still fit obviously. My wheels came with a center ring and of course the lug nuts assist in keep the wheel balanced as well
its only when the center bore of the wheel is SMALLER than the hub it's going on is there a problem
Old 01-16-2017, 04:18 PM
Administrator
Ron A's Avatar
Originally Posted by hyperview
Ron
The centerbore for most of our wheels is 64.1. From what I remember it is better to use an adapter but I'll let some of the wheel whores help me out with this.
Are you including the center rings?
Ron A is offline
Old 01-16-2017, 08:10 PM
hyperview's Avatar
Wheels are somewhat new to me as well..... But apparently after chatting with the wheel whores over at tirerack (lol) just about all aftermarket wheels are made with oversized center bores which explains why they always seem to come fitted with center rings
supposedly the TLX has the same size hub as the tl, tsx, and the cl ....... It's probably easier for Acura to produce like that. I can't imagine Enkei making 17 different versions of the same m52 18" rim just to fit all the different hub sizes out there...... Just easier to make the center bore oversized and fit with center rings I guess...... But to conclude my wheels will fit the above mentioned models. They would even fit a mustang ( as the stang uses a 5 x 114.3 lug pattern ) but would need to have different center rings pressed in to accommodate the ford hub
Old 01-16-2017, 10:24 PM
Administrator
Ron A's Avatar
I guess you missed where I asked in my post above if you are including the center rings so I'll ask again if you are including the center rings?
If it was me I wouldn't want to depend on the lug nuts doing all the work to keep the wheel centered. That's not because I know a lot about wheels but I just like to be safe.
Ron A is offline
Old 01-17-2017, 08:18 AM
hyperview's Avatar
yes center rings are included with wheels.....I have no use for them
Old 01-19-2017, 01:01 PM
hyperview's Avatar
Thursday bump for flawless wheels
yes center rings included.....will fit TL, TSX and CL
I have order number from tirerack in case you want to confirm with them the fitment
Old 02-03-2017, 08:37 PM
hyperview's Avatar
Friday night bump $950
moderator please update
mod edit-updated
Old 02-20-2017, 12:16 PM
hyperview's Avatar
Sold!!!
Jackass
12-18-2016 04:18 PM
BeastV6
3G TL Photograph Gallery
10-12-2016 06:59 AM
A Cake On
04-29-2006 05:46 PM
CLASSYCLS
11-16-2004 01:52 PM
awesomebase
01-04-2004 08:07 PM
Quick Reply: SOLD: 18" Enkei m52 Rims w/ BF Goodrich Gforce Comp2 A/S
