Groundbreaking Info! Hack your Navi! (Change Pics, Remove Nag Screen) (Garage I-139)
Old 04-07-2005, 05:34 PM
  #81
The Oracle of Acurazine!
Teh Jatt's Avatar
worked with 6 bn files
Teh Jatt is offline
Old 04-07-2005, 06:30 PM
  #82
mrbrett's Avatar
Round two of backgrounds is coming... I'll post later tonight.
mrbrett is offline
Old 04-07-2005, 08:27 PM
  #83
RepellR's Avatar
I am having a problem trying to update the image. I've changed the image, updated the proper bin and try to load the disc. The problem is that the old image is still showing up. I've tried disconnecting the battery. I've also confirmed that the image in the bin is the updated image by unpacking the BIN using bysin's utility.
Did anyone run into this problem? If so, how did you remedy it??
RepellR is offline
Old 04-07-2005, 08:59 PM
  #84
.:KCCO:.
ayethetiense's Avatar
are you sure you modified the correct bin file? make sure that when the bin file is loading, its cd u created and not the stock dvd
ayethetiense is offline
Old 04-07-2005, 09:30 PM
  #85
mrbrett's Avatar
More Backgrounds!
Here are some more backgrounds...
Enjoy!!
mrbrett is offline
Old 04-07-2005, 11:42 PM
  #86
Troublemaker
Turbowhat2's Avatar
good stuff brett
Turbowhat2 is offline
Old 04-08-2005, 07:02 AM
  #87
Team Nighthawk MechE
DarkWraith33's Avatar
Someone get this MrBrett guy a job.... ROFL (meaning you should do this for a living! not a knock on u at ALL!)
AWESOME WORK DOOD...
DarkWraith33 is offline
Old 04-08-2005, 07:41 AM
  #88
RepellR's Avatar
Ayethetiense,
I did make sure I am updating the correct BIN. I did have an image appearing, but I have lag that I am trying to eliminate. I've updated the bitmap and modified the original BIN. I've even extracted the modified BIN off the CD and see the updated image and it still isn't taking affect.
Thanks though!
RepellR is offline
Old 04-08-2005, 09:17 AM
  #89
kona's Avatar
My new startup image is displaying fine however, I'm having a problem geting rid of the nag screen. I'm running the GUI version of dumpnavi.exe (dated 4/7/05) on BN2HH12C.BIN (dated 9/2/03) and get the message "Nag modification is not supported on your car" message.
Anyone else have this problem?
Here are my bin files.
ADD
BN2HH12C
BN2HH110
BN2HH120
BN2HHMLD
BN2HN12B
BN2HN18B
zzz10
zzz100
kona is offline
Old 04-08-2005, 09:49 AM
  #90
cM3go's Avatar
Mr Brett, keep em coming! They are great!
One request... could you take this one:
and put the floating satellite back in? I'd appreciate it. Thanks!
cM3go is offline
Old 04-08-2005, 01:22 PM
  #91
100k miles club
w1n78's Avatar
nice ones mrbrett, but can you make ones with a TL and not a TSX please
w1n78 is offline
Old 04-08-2005, 02:48 PM
  #92
mrbrett's Avatar
Sure, but I need some good images of the TL to work with and maybe some concept sketches... post some pictures and I can work with them in photoshop.
mrbrett is offline
Old 04-08-2005, 06:29 PM
  #93
crazymjb's Avatar
MB, you could sell these, but not to us of coarse. Real works of art. I hope some computer geek comes up with a way to reprogram a large portion of the system, some .GIFs would be a nice addition As of now, when we get the car I will use one of your awsome images! Thanks, they are truly beautiful [and that word is usually set aside in my vocab for actual cars and models(female of coarse)]
crazymjb is offline
Old 04-08-2005, 08:22 PM
  #94
Worked for me
Worked for me... "Install" instructions need a lil tweakin but fairly easy to connect the dots... Comments/questions:
1. Several seconds of black prior to new image loading in... Normal? More than "before."
2. Image looks GREAT. AWESOME. Keep the cool ones comin...
3. Background image goes away and another several seconds of blackness before the "no-nag" screen appears, devoid of any words, only the "Go" button...
Are these before and after periods of black on screen typical? I am using the BMPs that I've gotten from "The Website" as is so the size is correct, etc... You other guys seeing this too?
Thanks for any info! (BTW I used the GUI version 1.4 and a MrBrett background) in my 05 TL... THANKS
Old 04-08-2005, 09:07 PM
  #95
Troublemaker
Turbowhat2's Avatar
the acura website has some nice tl photos
Old 04-08-2005, 10:33 PM
  #96
Team SSM
Tajam's Avatar
Ahhhh I got the picture to work fine. But the No nag, im having trouble.. With the DumpNavi tool, it says that my car doesnt support no nag???
Tajam is offline
Old 04-08-2005, 11:35 PM
  #97
Team SSM
Tajam's Avatar
1. That is normal.
In order to get the bitmap to 113,068 (which will not create a lag when loading, at least not on mine it didn't) you need to change your RGB created image to an Indexed Color (Image > Mode > Indexed Color). Once inside the indexed color dialog box, chose Local (Perceptual) from the Palette drop down menu. Then input 173 in the Colors field. This will alter your colors in your image because you are limiting the palette, so you might have to make some sacrifices or changes to the image. Then save as bitmap, 8 bit. BTW, this pertains to Photoshop.
once you get the size smaller, then the "black" will go away alot quicker.
Tajam is offline
Old 04-09-2005, 12:51 AM
  #98
kona's Avatar
Tajam, your problem sounds the same as mine. At least it's the same message.
Just curious, what is the name of your bin file and its creation date?
I'm thinking that dumpnavi.exe doesn't know how to process earlier versions.
kona is offline
Old 04-09-2005, 01:13 AM
  #99
Team Nighthawk Director
J RIDE 81's Avatar
how difficult was this to do?
J RIDE 81 is offline
Old 04-09-2005, 02:09 AM
  #100
mrbrett's Avatar
Her ya go, let me know if you want the satellite in a different position.
mrbrett is offline
Old 04-09-2005, 02:33 AM
  #101
Team SSM
Tajam's Avatar
IT was actually very simple, just follow the The Read me directions which comes with the Dumpnavi gui tool
Kona mine is BN2HH12C.bin
but the No-nag is basically the same thing, the screen just turns black and after a couple seconds says Go. Bysin said he left the no-nag and is now working on getting IE to work
Tajam is offline
Old 04-09-2005, 02:42 AM
  #102
2005 TL Owner
angler67's Avatar
I completed my first test:
Car: 2005 AT
BOOT BIN: BNHH401A.BIN
FileSize: 110 KB (113,398 bytes)
I still see the long black screen (3-4sec) before the new splash screen, even though its size is under 130K.
Any Suggestions???
New Splash:
Original:
angler67 is offline
Old 04-09-2005, 02:46 AM
  #103
Moderator Alumnus
rets's Avatar
Angler67, why resolutions on Navi look so fuzzy??? I'm not in this, but just feel curious... thanks...
rets is offline
Old 04-09-2005, 03:25 AM
  #104
2005 TL Owner
angler67's Avatar
one of 2 things, either that 898 number isnt calcualted correctly, or its a different number that needs to be under 113k
To add to what crazymjb indicated, the file size is the dimension 480*234 = 112320pixels * 8 bits per pixel (8bpp = 256 colors depth) / 8 bits/byte = 112320 bytes.
This is the raw data which has a file header with palette data which brings the minimum size to 113,398 bytes for a 480*234 pixel 256 color bitmap. The only way to make the file size smaller is to shrink the header, hence shrinking the palette by changing the file with a tool that can index the palette to make it smaller.
I get 113,176 Indexed to 200 colors
I get 113,068 Indexed to 173 colors
OR shrink to get
I get 112,918 with 478x233x256 colors
I will try it again with the shrunk image.
angler67 is offline
Old 04-09-2005, 03:30 AM
  #105
2005 TL Owner
angler67's Avatar
I'm not sure what you mean by fuzzy. Is my pic fuzzy, or the NAV screen in general, in person?
In General:
I think the max of 256 colors in the Win CE running on the NAV unit washes out the colors. And the resolution is so small that allows for less detail after anti-aliasing.
My Pic:
Pics in the dark requite a longer shutter time which creates a more blurry picture because of light saturation and movement in the camera.
angler67 is offline
Old 04-09-2005, 03:50 AM
  #106
2005 TL Owner
angler67's Avatar
I completed my 2nd test:
Car: 2005 AT
FileSize: 110 KB (112,918 with 478x233x256 )
Any Suggestions from those of you who have no 2-3 sec black screen?
Here is a better picture with flash.
New Splash:
Original:
angler67 is offline
Old 04-09-2005, 06:57 AM
  #107
Car: 2005 AT
I am in the same boat... 111k picture (thanks to MrBrett, DA MAN) but I still get long pauses of "the blackness..." Any other thoughts? Pics are right size, color depth, etc.... Hmmmm...
Old 04-09-2005, 09:52 AM
  #108
jastor3759's Avatar
don't compress the image. it will cause long delays or not even appear. I found reducing the number of colors (160) did the trick.
jastor3759 is offline
Old 04-09-2005, 01:11 PM
  #109
.:KCCO:.
i had the lag also.
i had 256 color and i still do have 256 color.
i just sliced off a thin piece of image off the left side. when you slice it out. make sure you actually cut it out and not just make it black. ie. in photoshop, CROP a thin piece off one side.
result: no lag and still 256 colors
oh, use a brand new disk to burn on too and reupload the bin file from the original nav. MAKE SURE YOU DO NOT MODIFY THE BIN FILE THAT YOU ARLEADY MODIFIED WITH THE PICTURE BEFORE.
Old 04-09-2005, 01:40 PM
  #110
lhn5's Avatar
I am hearing that the Motorola V710 has new software via Verizon and it works great (from Verizon) Acura is apparently testing it now and will be done in a few weeks. Anyone get this phone with the new software? Thanks.
lhn5 is offline
Old 04-09-2005, 02:17 PM
  #111
vp911's Avatar
Hey - welcome to the forums. You posted your question in the wrong thread. You should do a search about this (https://acurazine.com/forums/search.php) as it has been discussed before. Good luck.
vp911 is offline
Old 04-09-2005, 03:16 PM
  #112
Spinnin them beats
Acuraluvr's Avatar
i want to do this sooo bad....... question for those who hav done it:
what program do u download on the link in the first post?
does the 'dumping' affect the navi original disc?
how do u create those images?
Acuraluvr is offline
Old 04-09-2005, 03:18 PM
  #113
vp911's Avatar
acuraluvr - first program on that website.
no. it should not affect the orig. nav disc.
photoshop should work fine for this.
vp911 is offline
Old 04-09-2005, 03:22 PM
  #114
cM3go's Avatar
You used the wrong image, but thats ok, I still like it, Thank you sir!
cM3go is offline
Old 04-09-2005, 03:31 PM
  #115
kona's Avatar
bysin has released a new version (1.5) which removes the nag text, still leaving the Go button. I sent bysin my bin file and he was kind enough to recompile dumpnavi.exe. If you are 2004 early owner and had problems getting rid of the nag text, try downloading dumpnavi.zip again.
kona is offline
Old 04-09-2005, 03:56 PM
  #116
Spinnin them beats
Acuraluvr's Avatar
ok now....... ive got everthing and now all i need is a 'bitmap'
i lik the acura one with the thundar.... but im stuck help?
Old 04-09-2005, 03:58 PM
  #117
Spinnin them beats
Acuraluvr's Avatar
i went to browse and out of my lik 30 pics, only six came out.... are thease available/ the right size to use?
Old 04-09-2005, 04:00 PM
  #118
Spinnin them beats
Acuraluvr's Avatar
ok last question: are the pics that were in the first post of this thread in bmp? is so, can i use them?
Old 04-09-2005, 04:04 PM
  #119
vp911's Avatar
acuraluv - i believe all the pics that have been posted here are BMP files (bitmap) so you don't need photoshop...you can use those images without modification.
vp911 is offline
Old 04-09-2005, 04:06 PM
  #120
Spinnin them beats
Acuraluvr's Avatar
i saved those pics but they are not in bmp format? it dosnt show when i click browse on the 'dumpnav'
if i were to photoshop it, how do i meke it into a bmp?
Quick Reply: Groundbreaking Info! Hack your Navi! (Change Pics, Remove Nag Screen) (Garage I-139)
