Cracked dashboard in '04 TL
Old 04-28-2009, 06:28 AM
  #121
Christopher Means's Avatar
Originally Posted by KaMLuNg
why would your friend buy a car from them if he knows that you were going through what you are going through right now? if i was your friend, i would not have bought the car until they proved to me they would honor the warranty by fixing your car too... otherwise my money would go somewhere else...
i am not sure if you have tried this as you have mentioned trying to get in contact with people through the phone... but have you tried writing to ACS and the dealership? words on paper have alot more meaning than some of the b/s that comes out of people's mouths... that way you have something documented... use this thread also... there is no reason they should be denying you coverage of this DEFECT!!! more than a few people have had the fading/cracking issues...
i would also consider writing to your local media station to get the dealership some bad publicity... there is no reason you should be getting the run around... and if they have agreed to cover the dash and you pay labor... if you are capable enough, tell them you will take the dash, and just swap it out yourself... then return the old dash to them... shot in the dark, but worth a try still...
Good idea with the letter and the local news. One of the news teams does a piece on consumer problems. I hadn't thought of that.
Regarding my friend's purchase, I told him to get it written in his contract but they talked him out of it but assured him it was covered and he wouldn't have a problem. Too inexperienced with a good sales pitch and the dealer's pressure.
Old 04-28-2009, 10:48 AM
  #122
9th Gear
waynesta's Avatar
sorry to hear about your dash. maybe you should swap your dash with your friends, have him take his up there and say " fix this problem you said i wouldnt have." may be a pain in the ass but worth a shot! good luck with everything else.!
Old 04-28-2009, 12:34 PM
  #123
That idea would probably work if he were willing to do it. I have know idea what is involved with taking out a dash though.
Old 04-28-2009, 12:42 PM
  #124
Majofo's Avatar
well.. from what I understand. Drop the glove, drop the steering column (6 bolts), remove the center console trim, remove the center speaker (PITA) and the seats are optional but the work is easier if you remove both driver & passenger seats. The rest is pretty intuitive, be careful with the rear air vent, reuse the upper dash support on the new dash.. it'll take you a day in the garage if you go easy and take your time. I'm thinking of doing mine but I'm so broke right now I'm going to do the fix and see how it works out first. I can post the real step-by-step from the service manual if you're interested.
Old 05-01-2009, 12:41 PM
  #125
TL on "20"'s Avatar
i also have a 2004 and have 2 same crack as chapu in the same place !! the ex owner told me that it crack because of the armoral- !!! they don't have a recall on this ????
Old 05-01-2009, 12:44 PM
  #126
It's a defect and they don't want to deal with it. It has nothing to do with the Armorall.
Old 05-01-2009, 12:52 PM
  #127
Majofo's Avatar
Don't use Armor-all on your dash. It's a shine and it really doesn't protect as it advertises.. also rumored to cause damage from what I'm hearing. The dealership will say anything to you.. bottom line.. you're going to end up paying them if you want them to fix it.
Old 05-03-2009, 12:49 AM
  #128
TL on "20"'s Avatar
chapu saludos mira soy de Puerto Rico tengo tu mismo carro 2004 silver negro por dentro y tengo el mismo problema que tu pero mi carro acaba de cumplir las 50K dime a donde fuistes a ver si voy yo tambien y se puede hacer algo pq definitivo que esto es un defecto de fabrica y deverian hacer un recall !!!
Old 05-03-2009, 01:35 AM
  #129
Majofo's Avatar
Hey hermano .. No son muchos aquí hablan español, pero le sugiero ir a Acura y ver si repair en tu tablero de instrumentos gratis. Si no arreglar el tablero de instrumentos gratuita, a continuación, las opciones se limitan a la reparación de vinilo o de instalar un nuevo tablero de instrumentos. Instalación de un nuevo tablero de instrumentos por sí mismo será de 1 / 2 días de trabajo. Te informaremos de todas la actualización y la bienvenida a Acurazine! - les pido disculpas por mi pobre español ..
Old 05-03-2009, 06:34 AM
  #130
iWhine S/C 6MT TL
04WDPSeDaN's Avatar
Received 2,563 Likes on 1,317 Posts
^ FYI guys the mods are going to edit your posts. They are going to advice you to use english only.
Old 05-03-2009, 06:43 AM
  #131
chapu08's Avatar
Check your emails, I have a story regarding that.....with a happy ending in my case.
Old 05-03-2009, 09:32 AM
  #132
TL on "20"'s Avatar
sorry about talking in spanish, i will try to go to acura to get it fix for free, since this is obious a problem of these cars mostly seen in the 2004 TL, the thing is that my car just got to 50K miles, but i will let know acura that i know that this is a problem with tl, and i am also very concern that in an accident the air bag could not deploy properly. so let see i will let you know !! thanks !!
Old 05-03-2009, 09:42 AM
  #133
TL on "20"'s Avatar
Hi chapu I add you as friend but since i am new in the forum i can't recieve p.m. or emails righ now please write me to manuelfs2000@yahoo.com i was going to go to acura in the kennedy but since you have the same problem as me i think that is beter to go to the same place you did so they realice that is a factory problem. An may be I get lucky who knows jeje
Old 05-03-2009, 09:49 AM
  #134
Road Racer / Solo Addict
EL BAN's Avatar
This is a really interesting thread with lots of info..
Could all of you who stated their individual problems with the dash summarize their result and what they had to do to get it fixed?
I have a co-worker here in PR who is thinking about getting an 04 WDP with about 60K miles on it.. only one owner all service done at Acura dealers and has the extended warranty on it.. it is owned by an older woman and her asking price is 16.5K which he managed to lower to 15K but he is worried about the dash issue because when he told me he found it he was all pumped until he saw the dash cracked in a couple of places.. I told him I would try to research a bit for him on Acurazine..
I know that this thread would be of a lot of help to any potential buyer but it would be 20 times more helpful to any current 04-06 owner experiencing this problem..
It's a recurring problem on some TL's so the info should be pretty much handy so anyone can solve this as others have done it.
So maybe something like..
MEMBER - YEAR - MILES - DEALERS INVOLVED - MANAGERS CONTACTED
Old 05-03-2009, 10:10 AM
  #135
TL on "20"'s Avatar
that is a great idea i think that i was the only one with this problem and i was willing to fix it myself but since i am concern that this is a problem with this car i will fight until they repair it!
El ban if you are RUM_ACCORD_H22 in C.N.
give me a call you have P.M. there !!
Old 05-03-2009, 10:27 AM
  #136
EL BAN's Avatar
Will do..
Old 05-03-2009, 10:46 AM
  #137
sagreba32's Avatar
TL on "20":
Check your e-mails, I'm also from Puerto Rico and I have some info for you.
Old 05-03-2009, 11:48 AM
  #138
sagreba32's Avatar
  #139
TL on "20"'s Avatar
Old 05-03-2009, 11:50 AM
  #140
sagreba32's Avatar
TL on "20":
Upload them again, they are tiny
Old 05-03-2009, 11:55 AM
  #141
Majofo's Avatar
damn you guys.. that is the most extensive dash cracking I have seen yet..
Old 05-03-2009, 11:58 AM
  #142
TL on "20"'s Avatar
Originally Posted by sagreba32
TL on "20":
done !!!!
Old 05-03-2009, 12:04 PM
  #143
Majofo's Avatar
Did you guys notice the cracking around the airbag first? I have two strange cracks near the air bag but not right over the seam and not as extensive. I suggest getting a window visor to protect the dash when you get it fixed.
Old 05-03-2009, 12:08 PM
  #144
TL on "20"'s Avatar
yeah its sucks!! having a $40k acura TL dash looking like the grand canyon lol this is not a 1982 toyota 1.8 to have the dash like this !!!
Old 05-03-2009, 12:09 PM
  #145
sagreba32's Avatar
Two different cars and the crack is exactly the same.
Old 05-03-2009, 12:12 PM
  #146
sagreba32's Avatar
Yes, my first crack was the one in top of the airbag.
Old 05-03-2009, 12:22 PM
  #147
TL on "20"'s Avatar
i purshase the car like that i am worried that it will get worst and righ now my car is tinted 20% and is 85% the time in the shade !! and the little time is in the sun i have the sun roof tilt and the window visor!!
Old 05-03-2009, 12:27 PM
  #148
TL on "20"'s Avatar
segreba I am going to print that picture that 2 pictures is worth gold !!!!! that is the picture i need to present in acura jeje
Old 05-03-2009, 12:32 PM
  #149
Majofo's Avatar
use 05Smoke_GreyTL's pic too..
Old 05-03-2009, 12:37 PM
  #150
Friss04TL's Avatar
that sucks, I had to replace the dashboard when I get the car of the auction, the dashboard was $723.00
Old 05-03-2009, 12:40 PM
  #151
TL on "20"'s Avatar
please all the users that have pic. of the dash crack please post the pictures this will help me alot whith the reclamation at acura !!
Old 05-03-2009, 12:44 PM
  #152
sagreba32's Avatar
Have any of you guys seen this? My car is a Certified Pre-Owned vehicle and they don't want to honor the 1year/12,000 extra warranty
http://www.acura.com/content/pdf/Warranty.pdf
Old 05-03-2009, 12:55 PM
  #153
it's me, Alan Rickman.
timmahh's Avatar
Looks like the common place to crack is around the passenger airbag; the portion around the airbag is thin or 'pre cut' so the airbag can bust through it
How often do you guys have your cars out in the sun?
Old 05-03-2009, 12:58 PM
  #154
TL on "20"'s Avatar
will these cracks can affect the airbag deployment ???
Old 05-03-2009, 01:02 PM
  #155
sagreba32's Avatar
No, the airbags are controlled by accelerometers which are triggered by high forces attributed to collisions. The dashboard cracks are a cosmetic issue
Old 05-03-2009, 04:56 PM
  #156
eso.teric's Avatar
I have an 04 with 37K miles, Last week I notice a crack that is starting to form on the lower right corner of the airbag. There is also another crack on the driver side. I will take pictures today or tomorrow. I havent taken the car to the Acura dealer here in miami, I guess i'll have to take it to see if they replace it for free. I recommend you guys buy a windshield sunshade so it doesn't get worst, at least that what i did.
I think this is not supposed to happen on a $40,000 dollar car, is there anyway we can make Acura to do a recall for this?
Old 05-03-2009, 08:05 PM
  #157
chapu08's Avatar
This was my dash:
Replaced w/o problems by Acura Service.
Old 05-03-2009, 08:59 PM
  #158
sagreba32's Avatar
This was my dash:
Yes, but you were still under warranty. I went to the Acura service center one week after my warranty was out, the car only had 35K miles.
Old 05-04-2009, 06:44 AM
  #159
Christopher Means - 2004 - 26,000 - McDaniels Acura, Hendrick Acura - Service managers and Acura Client Services - No solution to problem. They claim that the dash is "Trim" and not covered under the warranty.
Old 05-04-2009, 09:46 AM
  #160
sagreba32's Avatar
sagreba32 - 2004 - 40,000 miles - Centro de servico Acura, Guyanabo PR - Malaret (se encarga de las garantías), Debrah Rodriguez (parts manager), Jose Carlos Villares (Vice President of sales), Santos Antonetti (Service Vice Prsident), (I have also called Corporate Acura to let them know about the problem)
They told me two weeks ago that they were going to pay for the dashboard but not for the labor. The labor is $500, and I don't want to pay that for a defect, in which Acura is supposed to pay for. I'm going to keep pushing and pushing. I've been dealing with this since Septmber.
Good luck
Quick Reply: Cracked dashboard in '04 TL
