Old 08-11-2011, 12:14 PM
  #281
BSpecialist's Avatar
Type 1 Switchbacks switch between white and amber as long as your parking lights are on while signaling. Type 2 Switchbacks are white while the parking lights are on, but only blink amber for signals.
I had to email the ebay seller to make sure I was getting the Type 2, as I think they tend to be considered more legal than the Type 1.
Old 08-11-2011, 08:48 PM
  #282
Desert Life Sucks!!
sauceja's Avatar
Originally Posted by cfujikawa
mine do that as well. it depends on what type of bulb you got, and from what manufacturer. i don't think it's a bad bulb. it's wired so that when you don't have your corner lights on (ie. during the day, and your lights are off), they will just blink amber (since the default bulb status is off). when you do have the corner lights on (ie. at night with the headlights), they will blink amber-white (because the default bulb status is on).
when i bought my bulbs from autolumination, they had a choice between the two types (amber blink only vs. amber-white blink). i thought i ordered the amber only bulbs, but i think they sent me the amber-white ones. doesn't really bother me, so i never exchanged them.
If that was an option then I may have missed it. But the funny thing is they didn't do it right away. It took about 30 seconds of blinking just orange when I was showing my dad then it starting blinking both. Kinda made me look silly but f it. Didnt know there were different kinds but then again I am a noob to led's and this stuff.
More of an old school modder.
Old 08-11-2011, 08:57 PM
  #283
Desert Life Sucks!!
sauceja's Avatar
My windows are pretty much black and cops here don't really mess with things like this. You should hear all the ricer exhausts going on that don't get stopped.
Plus we are a non emission state so not having cats here is technically not illegal either.
With nicer cars they tend to look the preverbial other way. Its the multi color shit cars with big wings and dents that draw attention of the cops since mexican mafia, gangs, meth houses drugs in general and the scum that live here pretty much keep po-po busy.
Damn 50.00 in lights down as I kinda want the type 2's but will rock these out for a while.
Really need a new soldering gun as I do not feel comfortable about this solder job.
Does anyone know what part number these relays are or where to get replacements???? So that I can go ahead and re-solder resistors (or 1 .24 ohm resistor ) and do it right so I don't have to keep worrying if something may go bad.
Old 08-11-2011, 08:59 PM
  #284
cfujikawa's Avatar
oh, that is odd. maybe shoot them an email and see if that's normal?
Old 08-16-2011, 07:39 PM
  #285
King of NYC
rockyfeller's Avatar
OK GUYS YES!!!! I am confirming this as said before, this mod WORKS with 4 LEDs! I have switchbacks up front and LED rear signals. I went and unsoldered the series setup, cut the leads a bit for clearance and resoldered them as parallel. So I used two .12ohm resistors but of course you could use 1 .24ohm resistor as described. Works like a charm, no hyperflash, regular flash rate! I don't have to be as concerned as before if my LED signals were on for a long time, simulating load needlessly, drawing power and generating heat. (200watts!) My BIG THANKS to the geniuses, Roger and BSpecialist!!
Only 1 problem now. I was just about to set up to put my load resistors back in and they just got mailed in. If anyone wants some 50watt 6ohm resistors, PM me.
Old 08-16-2011, 08:34 PM
  #286
OCD
Roger555's Avatar
Nice work! We should have a moderator add this to the first post lol for any noobs stumbling onto this.
Old 08-16-2011, 10:15 PM
  #287
Glad to hear you got it working as well. But I think you mixed up the terminology a little hah. No worries though!
Old 08-16-2011, 10:40 PM
  #288
vietxquangstah's Avatar
so its either 2 - 0.12ohm or 1 - .24ohm resistor for FRONT and BACK?
not .06ohm like someone mentioned earlier?
Old 08-16-2011, 10:43 PM
  #289
Yessir. Just make sure if you have 2 0.12ohm that they are soldered in SERIES (google if needed). One end of the resistor connected to one end of the other resistor, then the 2 un-soldered ends go into the board.
Old 08-17-2011, 02:13 AM
  #290
Being an Acha Bacha in
Elegant TYPE S's Avatar
Good stuff bro... nice to see you're still in the scene!!
Old 08-17-2011, 01:43 PM
  #291
Starcraft II addict
Buda's Avatar
Did you test to see if any one of the LED bulbs is "out" that it hyperflashes to let you know you have a bulb out?
Old 08-17-2011, 10:49 PM
  #292
tlmailman's Avatar
any pictures. is there enough clearance for the 2 resistors with the cover?
Old 08-22-2011, 09:18 PM
  #293
I have not tested if it will hyperflash if one bulb is out. Personally I'm not too worried about it as I drive at night quite a bit and can always tell if my bulbs are still working.
Sorry I haven't had a chance to take a picture yet of my setup, but yes you can fit 2 resistors in there with enough clearance. It will be close if you don't solder close enough but you can always just bend it over a little like I did. I will post pictures soon.
Old 08-25-2011, 12:17 PM
  #294
guitarplayer16's Avatar
About to use this guide for my autolumination 120 amber LED front turn signals.
Anybody have any .12 ohm 1 watt resistors left?
Old 08-28-2011, 03:34 PM
  #295
King of NYC
yeah man, sorry I did mix up what I meant, lol. This mod is so worth it guys, everyone with LEDs on 2 corners or all 4 should do it. It's easier to do than it looks.
To make clearance within the flasher housing the resistor's leads will need to be cut short to the level to just penetrate the circuit board. The resistor will nearly come to rest on the circuit board. Luckily there aren't too many big components around it and you have space to make it work. You might have to do some mild bending to close it up and fit it in.
guitarplayer I have resistors, just pm me.
Old 08-29-2011, 12:42 AM
  #296
07 NBP TL
Horditruck's Avatar
how many watts is the 0.24 ohm resistor?
Old 09-01-2011, 11:28 AM
  #297
07TL-S's Avatar
I'm planning on just running switchbacks in the front right now, so would it be ok to put in a 0.24 ohm now? or will it affect the normal bulbs in the rear?
Old 09-01-2011, 03:19 PM
  #298
You can go ahead and put it in now. You just won't be able to tell if one of your rear bulbs burns out I'm pretty sure.
Old 09-01-2011, 03:20 PM
  #299
I'm pretty sure a 1 watt .24ohm resistor will work fine.
Old 09-01-2011, 03:28 PM
  #300
Engineer
lights's Avatar
how about 1/2 watt?
Old 09-01-2011, 03:33 PM
  #301
Originally Posted by lights
how about 1/2 watt?
That should probably work, the watt rating on resistors is the ability to dissipate heat, and I would guess not much of a current is passing through the circuit...but again that's just a guess...Roger555???
Old 09-01-2011, 05:19 PM
  #302
OCD
Roger555's Avatar
Ya 1/2 W will work
Old 09-02-2011, 09:14 PM
  #303
m7r7m's Avatar
Roger or anybody else on this post have any resistors still...preferably a .24 ohm 1w resistor?
Old 09-04-2011, 07:58 PM
  #304
Desert Life Sucks!!
sauceja's Avatar
or better yet what are the color scales of the .24 ohm resistor. Radio shack has a plethora of resistors its just i am not so good with color coding on these.
Pics make me happy.
Old 09-15-2011, 09:51 PM
  #305
xavier25's Avatar
It Works!!!
I was able to solder a couple .12 ohm resistors in series and get everything working. I got the LEDs mentioned on page 1 or 2 through ebay and they seem good. the rears are brighter than the stock bulbs. I'll see how things look tomorrow during the day.
By the way, I had ordered .24 ohm resistors since I got a little impatient waiting for the .12, so will be stuck with 10 once I receive them in a couple days. If someone needs one, PM me.
Here are some pics of the resistors:
Old 09-19-2011, 08:46 PM
  #306
xavier25's Avatar
If anyone needs a .24ohm resistor let me know... I just received them, so have 10. Here's a pic if you need the color scale. Thanks to all for this great and easy mod!
sauceja (09-20-2011)
Old 09-20-2011, 09:29 AM
  #307
tehloxely's Avatar
I think the first post of this topic should be updated with all the found data and a how-to.
Old 09-20-2011, 06:13 PM
  #308
Chapter Leader (Houston)
TLDude876's Avatar
I have LED's only in the rear. Do I need 1 or 2 .12 ohm resistors? Can a .24 ohm be used?
Old 09-20-2011, 06:25 PM
  #309
Might as well just do the .24ohm in case you want to put LEDs in the front ever. Shouldn't hurt it.
Old 09-20-2011, 09:43 PM
  #310
07TL-S's Avatar
I received my bulbs today, and I seem to be having a problem. The bulb is white when the parking lights are on, however the white stays on and the amber flashes when I use my signal. It doesn't alternate or anything, constant white and flashing amber. Any ideas why this is?
Old 09-20-2011, 10:12 PM
  #311
Looks like you got the Type 1
Old 09-21-2011, 10:24 AM
  #312
07TL-S's Avatar
I thought that with Type 1, when you signal it goes white-amber-white-amber...but mine the amber is constantly on and the white flashes..or is that how type 1's work?
Old 09-21-2011, 10:53 AM
  #313
So which way is it? lol Sometimes it just looks like one color stays on while the other flashes, but I'm pretty sure it just alternates so fast (being LED and all) that it gives the illusion that the one color is staying on the whole time. Look at it closely during the day and you should be able to tell if the whole tower of LEDs is actually on at the same time during the flashing stage. If it is...I don't know what type that is lol
Old 09-21-2011, 11:14 AM
  #314
TYPE 1 SWITCHBACKS http://www.youtube.com/watch?v=SJKEB...layer_embedded
TYPE 2 SWITCHBACKS http://youtu.be/HbNYqw1FCmI
Old 09-21-2011, 11:16 AM
  #315
This ^^^
Your links are workin 50% lol
Old 09-21-2011, 02:11 PM
  #316
07TL-S's Avatar
lol sorry, the white constantly stays on and the amber flashes...so i'm guessing its an issue with the bulbs
Old 09-21-2011, 03:04 PM
  #317
Engineer
lights's Avatar
no, type 1 is like that. i have the same thing. the older style.
the first video he posted for type 1 is not even like that, plus hyper flash FTL.
the white constantly stays on while amber flashes, that's type 1.
Old 09-21-2011, 07:54 PM
  #318
I have LED's only in the rear.Can a .24 ohm be used?
I have the same question... except I have LEDs only in the front.
Old 09-21-2011, 09:08 PM
  #319
Having them in just the front or just the back shouldn't matter. Yes it should still work.
Old 09-22-2011, 12:33 AM
  #320
Engineer
lights's Avatar
Yes, it'll still work with only front OR rear LEDs.
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
