#81
B A N N E D
.06 ohm is exactly what I was thinking...didn't use the formula above, but figured if .12 worked for two, doubling the resistance would be .06. I found some .06 ohm through hole resistors but are rated at 2W...I'm thinking it would work, but not totally sure. However, doubling up two of the .12 that Roger linked is not a bad idea and just as easy.
resistor specs:
Watts: 2
Ohms: 0.06
Tolerance: 3
Lead/Terminal Type: Axial
Number Leads/Terminals: 2
Material: Wirewound
resistor specs:
Watts: 2
Ohms: 0.06
Tolerance: 3
Material: Wirewound
#82
What would be the easiest way to solder them in parallel? Just have them both bridge the holes and solder them? Or would it be a more involved process?
#85
SSM FTW
This guy solder his in parallel cause he couldn't find a 0.12 ohm resistor locally so he work with what he could find.
#87
Added to the 3G Garage/Service Dept. G-109
Roger555 (06-07-2011)
Steve 21 (06-13-2011)
#90
panditobinbin
theyre like 10 bucks at radioshack. Its not hard to do. Im a complete noob with a soldering iron but i got it done. it was a pretty easy mod with some help from youtube on soldering
The following 8 users liked this post by Roger555:
614erich (06-22-2012),
dwb993 (10-16-2011),
gogators22 (11-07-2011),
paperboy42190 (04-04-2013),
Slpr04UA6 (05-30-2021),
and 3 others liked this post.
#92
Man this mod was fairly easy, alot cleaner as stated as opposed to the load resistors. Ever since i put my type1 switchbacks on, its been a head turner! i live around the new brunswick,nj area and i can only imagine how many people around there have probably been searching frantically for them(thats how they do there, they "copy") thanks ALOT roger for sure this mod made me realize i wasted money on the load resistors.
con5tant (06-08-2011)
#101
Lol you guys are helpless I posted a link already to where I bought them but here it is again
http://parts.digikey.com/1/parts/169...r-52-0r12.html
You can buy them from any of the other major electronics distributors but digikey has $2 dollar shipping on small orders
www.Mouser.com
www.Newark.com
www.Mouser.com
www.Newark.com
wusty23jd (09-16-2015)
#102
panditobinbin
www.Mouser.com
www.Newark.com
www.Mouser.com
www.Newark.com
Im out now too. i got mine from digikey tho. Thanks again, Roger.
Mafyoso (06-09-2011)
#107
Just installed my switchbacks tonight and it worked great. I installed 2 of the .12ohm resistors in because I am planning on adding rear LED signals as well. With that said, it still functions great with both resistors in there. The hardest part was getting the module out from under the dash, I'm not sure why but it was a PITA.
Thank you Roger for figuring this out, and thank you ervin for the resistors!
#110
Balling in the...
OK But has anyone attempted this with both Switchbacks and LEDs in the rear? BSpecialist said he just added both resistors with switchbacks only. I have some resistors on their way so hopefully this does work cause this hyper flash is a PITA when both switchbacks and rear LEDS
#114
My rear LED bulbs are coming from Hong Kong and won't be here until later this month. That's when I will be able to confirm that 2 of the .12ohm resistors work...that is unless Mafyoso beats me to it. So hurry up Mafyoso!
#119
Balling in the...
I want to first thank luder917 for mailing me the resistors
So YES the Two .12 Ohmz Resistors Worked with Switchback LEDs In the Headlights and Red Turn LEDs in the Tail lights
Hell Yea no more Hyper Flashing. Here is a picture and a Video to show PROOF that it works
P.S. It took my longer to UPLOAD the damn video from my Cell phone to Youtube (over WiFi) Then it did to do this MOD. Took maybe 15 minutes. The hardest part was trying to get the Relay out of its slot near the Fuse panel. Other than that I used a cheap ass Soldering Kit from Radio Shack and the Resistors Luder917 sent me. GL
http://www.flickr.com/photos/63529687@N04/5834495631/
The following 4 users liked this post by Mafyoso:
