Old 04-19-2011, 11:14 AM
OCD
Roger555's Avatar
Paperboy I sent your resistor out today
Hey Cuban did you get yours yet?
Old 04-19-2011, 04:15 PM
BSpecialist's Avatar
Hey Roger555, I sent you a PM about maybe buying a resistor off you, but I'm not sure it went through as I'm a noob to this forum. Let me know, thanks!
Old 04-19-2011, 04:34 PM
paperboy42190's Avatar
thanks man, i hope they come by this weekend. i installed switchback leds on my car last night and all this hyperflashing makes me feel like a ricer lol
Old 04-19-2011, 06:41 PM
Engineer
lights's Avatar
roger,
i think i'll give this a try, but it's gonna take me more time to take all the resistors out from my trunk that i've installed before....lol
Old 04-20-2011, 02:25 AM
under renovations....
CubanLynx84's Avatar
Yeah I did get mine thanks Roger. I liked the Homer stamp too lol. I recently had a death in the family so me getting to this won't be for awhile though but I will take pics and post them up when I do.
Old 04-20-2011, 05:42 AM
OCD
Roger555's Avatar
Originally Posted by lights
roger,
Its worth it! Get all those power sucking resistors out of there you will feel much better!
Old 04-20-2011, 08:47 AM
  #47
Land of 10,000 lakes
nate_0022's Avatar
Will these be the cure to all four corner to prevent the hyperflash, or just the front or just the back?
Old 04-20-2011, 08:57 AM
ajs800's Avatar
is it possible that many other vehicles can be changed this easily to convert to LED? It seems to me that most newer cars will have similar setups. I'll have to check out my 07 Tahoe's relay this evening as I currently have LED tails with resistors. Talk about simple...Thanks for the DIY!
Old 04-20-2011, 01:21 PM
  #49
ajs800's Avatar
someone will chime in, but I'm pretty sure this will cover both sets front and rear, and it appears like it will work with the 07+ with the mirror signals as well.
Old 04-20-2011, 08:27 PM
  #50
OCD
Roger555's Avatar
It should I but I haven't tried that specifically. I know it blinks normal without any bulbs up front though.
I might have a chance this weekend to maybe pull the rear incandescent bulb to see what it does.
Old 04-25-2011, 02:52 PM
  #51
I successfully did this mod with a .12 ohm resistor from roger, came out nice and clean! no messy wiring behind the headlights and dont need to worry about connections coming loose or mounting the resistor!
Old 04-25-2011, 06:51 PM
  #52
KiWiLiT43's Avatar
For sure get ahold of Tyler you guys can stop over whenever he's been to my place a fee times.
Hey BobbyLight if you and Tyler plan on doing this let me know. Tyler has my number, I would like to tag along.
BTW is Bobby Light a Rob And Big reference? Lol!
Old 04-25-2011, 09:18 PM
  #53
OCD
Roger555's Avatar
Alright MODERATORS can we please give this a spot in the garage now?
Old 04-25-2011, 10:14 PM
  #54
ajs800's Avatar
are you running LEDs for both front and rear signals?
Old 04-25-2011, 11:18 PM
  #55
no, just switchback leds in the front
Old 04-29-2011, 05:17 PM
  #56
Dave88712's Avatar
Hey guys I just tried this on my 06 TL with switchbacks up front and red LEDs for rears. After using new resistor it was still hyper flashing. Then I replaced the rear LEDs back to bulbs and no more hyper flash. So I guess it only works for just fronts or just rears not all four. Still way easier doing it this way though only took 5 min total.
Old 04-29-2011, 06:00 PM
  #57
nate_0022's Avatar
What size resistor would we need to replace the .12 to get all four running properly? My logical guess would be a 24 OHM resistor.
Old 04-29-2011, 08:09 PM
  #58
OCD
Roger555's Avatar
Nate .12 ohm should work for all four if you give me your address I will send you one to try out.
Old 04-29-2011, 08:11 PM
  #59
Engineer
lights's Avatar
Roger, please chime in.
I'm not gonna take out my resistors until it's confirmed that this will work with four LED bulbs.
Old 04-29-2011, 08:18 PM
  #60
nate_0022's Avatar
If you read post #56 above my previous one, Dave tried it but still gets a hyperflash. I'll still take one if you have spares Roger
Old 04-29-2011, 08:48 PM
  #61
OCD
Roger555's Avatar
I'll see if I can get the resistance value for all 4 ! But in all honestly none of you guys should be using LEDs as rear turn signals unless its like an elef bulb that shit is not bright enough.
Old 04-29-2011, 08:53 PM
  #62
Engineer
lights's Avatar
i will not have any halogen bulbs for my TL!!
Old 04-29-2011, 09:05 PM
  #63
nate_0022's Avatar
The reason I need to use LEDs in the rear is because I have clear tinted corner lenses and I can't find a 7443 red bulb. I used transparent glass paint onthe clear bulbs but the look pinkish.
Old 04-29-2011, 09:43 PM
  #64
pwr2panda's Avatar
Could someone do this mod for me? I would do this myself...but I do not know how to solder
Old 04-29-2011, 09:44 PM
  #65
sodaks2k's Avatar
http://www.eautoworks.com/product-Raybrig-113885.htm
http://www.tunersdepot.com/Lighting/...SAL-62106.html
http://cgi.ebay.com/ebaymotors/7443-...Q5fAccessories
http://cgi.ebay.com/ebaymotors/2x-74...Q5fAccessories
Old 04-29-2011, 10:24 PM
  #66
nate_0022's Avatar
Guess I should've been specific. I can't find any 7443 red bulbs locally, if I'm buying them offline I'd prefer LEDs.
Also, when I tested out my amber LED bulbs I use for my turn signals, they wouldn't fit into the housing of the taillights. Is there a different diameter stalk for the LEDs we need to order for the taillights ?
Old 05-01-2011, 02:00 AM
  #67
vietxquangstah's Avatar
please do, i'm interested in doing this, but only if it works for front and rear.
and you don't think these http://www.v-leds.com/Exterior-LED/B...10374-1-2.html are bright enough to be rear turn signals?
my brother uses them in his 09 camry as his brake lights and they seem pretty bright.
Old 05-01-2011, 08:16 AM
  #68
UA7Beast's Avatar
Nice DIY!
Old 05-01-2011, 07:46 PM
  #69
AM To WDP In My Garage
acura_dipset_tl's Avatar
I might attempt this in the near future. Nice work Roger.
Old 05-01-2011, 11:02 PM
  #70
Sal's Type S's Avatar
What about using an adjustable resister.
Old 05-02-2011, 09:45 AM
  #71
tehloxely's Avatar
I'm anxious to see when/if a different resister will be able to handle front and back leds.
Old 05-02-2011, 07:08 PM
  #72
Vegas TL's Avatar
Well got my special ordered .12 ohm resister today. Looking forward to installing in the next couple of weeks. Got a sodering gun in my tool box ready to go. Will check back after I'm done.
Old 05-02-2011, 10:41 PM
  #73
TripAcez's Avatar
Hmm, id like to give this a try, roger can you send me a resistor?
Old 05-03-2011, 09:29 AM
  #74
ajs800's Avatar
I'm curious about changing out the resistor as well for all four. If running a high count SMD LED, they can be much brighter than the standard incandescent bulb.
Any idea what ohm resistor will be required to run all four? Thanks again!
Old 05-03-2011, 03:58 PM
  #75
OCD
Roger555's Avatar
Sorry guys ever sense the tornadoes messed up a few plants at work I have been working 12 hour days going on 3 weeks now! Haven't had much time to even sleep let alone mess with my car. A variable resistor would be a good option if someone wants to try that in the meantime. Just make sure it can go higher/lower then the .12 ohm
Old 05-03-2011, 10:42 PM
  #76
King of NYC
rockyfeller's Avatar
Roger you are a genius. We have a dead thread back in the day on this very topic of modding the flasher to stop the hyperflash. We said somebody would figure it out eventually. And you finally did it! I am totally for this mod because I use my signals for limited periods of time fully aware of the energy waste and heat generation of my 4 resistors.
Looking at your pics it is so easy to tell this mod will be a breeze. I did your DRL mod too which LOOKED complicated but was actually quite simple, straightforward, efficient and a durable mod compared to the alternatives. This flasher mod is no exception.
By the way LEDs in the rear are DEFINITELY bright enough. You just have to buy the right kind. I have an old video up somewhere in the archives. If you look it up you will see that LEDs in the rear can be plenty bright.
I too want to do this mod once someone figures what the proper resistor value is needed for LEDs in all 4 corners.
Old 05-03-2011, 10:55 PM
  #77
B A N N E D
friesm2000's Avatar
as OP mentioned, with how previous hondas you could do this (i knew you could, i remember seeing it a long time ago), anyways for doing it to a newer model of car
Elegant TYPE S (08-11-2011)
Old 05-03-2011, 10:58 PM
  #78
B A N N E D
friesm2000's Avatar
This is one seriously of the easiest mods I'v had to do. I don't know about you but I'd rather have a proper fix then a band aid fix like a load resistor, even if it did like me longer to do.
let alone being able to also GAIN the ADVANTAGE of the less power draw of LED's, may not be much but it adds up though
Old 05-04-2011, 03:34 AM
  #79
SSM FTW
luder917's Avatar
resistors in parallel 1/R3=1/R1+1/R2
the reason i use this formula because it works for the load resistors.
EX.
1/R3=1/6 OHMS + 1/6 OHMS
1/R3=1/3 OHMS
R3=3 OHMS
a shortcut is when you use the same resistors you just divide by the number of resistors.
EX.
R3=R/NUMBER OF RESISTORS
R3=6 OHMS/2
R3=3 OHMS
this is why you run two 3 ohms load resistors when you have LEDs in all four corners.
so using the same formula for the resistors for the relays it would be....
R3=0.12 OHMS/2
R3=0.06 OHMS
what im try to say is if you have two of the 0.12 ohm resistors, put them in parallel if you want to run LEDs in all four corner. or you can just order some 0.06 ohm resistors.
i dont plan on running LEDs in the rear and im still waiting for my resistors, so someone should try it out and post results...
yeah... im bored
BSpecialist (06-15-2011)
Old 05-04-2011, 01:40 PM
  #80
ajs800's Avatar
.06 ohm is exactly what I was thinking...didn't use the formula above, but figured if .12 worked for two, doubling the resistance would be .06. I found some .06 ohm through hole resistors but are rated at 2W...I'm thinking it would work, but not totally sure. However, doubling up two of the .12 that Roger linked is not a bad idea and just as easy.
resistor specs:
Watts: 2
Ohms: 0.06
Tolerance: 3
Lead/Terminal Type: Axial
Number Leads/Terminals: 2
Material: Wirewound
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
